* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+1 |
| | | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am | ||||
* | 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-01 | 1 | -1/+1 |
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS = | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -10/+9 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+44 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 5 | -10/+5 |
* | Removed spaces. | Joel Sherrill | 1998-12-03 | 1 | -4/+0 |
* | Fixed screen to match actual output. | Joel Sherrill | 1998-04-27 | 1 | -3/+2 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 5 | -5/+5 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 5 | -10/+10 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 5 | -25/+25 |
* | Fixed test to match change to pthread_cond_timedwait which now takes a wall | Mark Johannes | 1996-09-12 | 1 | -26/+32 |
| | | | | | | | time. Commented out calls to pthread_cond_wait and pthread_cond_timedwait without the mutex locked before calling. | ||||
* | Filled in screen | Mark Johannes | 1996-08-23 | 1 | -0/+60 |
* | Changed test 5 to test 10 at bottom | Mark Johannes | 1996-08-23 | 1 | -1/+1 |
* | Commented out the EINVAL for mutex not acquired befor cond_wait call | Mark Johannes | 1996-08-22 | 1 | -4/+9 |
* | system.h: added task3 and changed condition variable config to 1 | Mark Johannes | 1996-08-14 | 1 | -1/+6 |
* | task3: added to test error case in Wait_support for lock on mutex | Mark Johannes | 1996-08-14 | 1 | -0/+46 |
* | init: added error case for wait timedwait, and wait support | Mark Johannes | 1996-08-14 | 1 | -8/+153 |
* | task_2: added comments and print statement for task exit | Mark Johannes | 1996-08-13 | 1 | -0/+1 |
* | task_1: added comments and print statement for task exit | Mark Johannes | 1996-08-13 | 1 | -0/+5 |
* | Init.c: added timewait case, added broadcast case | Mark Johannes | 1996-08-13 | 1 | -3/+28 |
* | task_1: added to handle cases of waiting tasks on condition variables | Mark Johannes | 1996-08-12 | 1 | -0/+60 |
* | system.h: added protoypes for task and task2, added mutex id, and task ids | Mark Johannes | 1996-08-12 | 1 | -1/+10 |
* | Init.c: added cases for signal, wait and broadcast | Mark Johannes | 1996-08-12 | 1 | -7/+26 |
* | Task2: new task for broadcast case | Mark Johannes | 1996-08-12 | 1 | -0/+46 |
* | Init: added pthread_cond_init with an attr non-NULL, initialized the attr again | Mark Johannes | 1996-08-12 | 1 | -0/+8 |
* | Init: added prliminary phtread_cond_init and destroy cases. | Mark Johannes | 1996-08-12 | 1 | -0/+9 |
* | system.h: added condition variable #define for 10 condition variables | Mark Johannes | 1996-08-12 | 1 | -0/+2 |
* | system.h: initial cvs | Mark Johannes | 1996-08-09 | 1 | -0/+53 |
* | Init: added condattr - destroy, init, set and get cases | Mark Johannes | 1996-08-09 | 1 | -5/+6 |
* | Init: Original file - tests for condition variables. | Mark Johannes | 1996-08-08 | 1 | -0/+94 |
