2016-08-18 | psxtests: Adjust sporadic server tests | Sebastian Huber | 1 | -10/+8 | |
According to POSIX priority value returned from pthread_getschedparam() shall be the value specified by the most recent pthread_setschedparam(), pthread_setschedprio(), or pthread_create() call affecting the target thread. Read this as though a temporary lower priority due to the sporadic server policy shall not be visible through pthread_getschedparam(). Thus, use rtems_task_set_priority() to get the current priority of the threads. Use a priority ceiling mutex to prevent sporadic server priority adjustments. | |||||
2009-08-19 | 2009-08-19 Joel Sherrill <joel.sherrill@OARcorp.com> | Joel Sherrill | 1 | -11/+11 | |
* psx09/init.c, psx09/psx09.scn: Correct test following decision of when not to change ssporadic scheduler so it does not touch a task's priority when it is holding a mutex or its priority would be impacted adversely. | |||||
2002-11-14 | 2002-11-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn, psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn, psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn: Per PR239 update the IDs in the various screens. | |||||
1998-12-03 | Removed spaces. | Joel Sherrill | 1 | -1/+0 | |
1996-08-23 | Filled in the screen | Mark Johannes | 1 | -0/+23 | |
1996-08-07 | basic sporadic server test. | Joel Sherrill | 1 | -0/+0 | |
sporadic server with priority ceiling mutex test. | |||||
1996-05-24 | new files | Joel Sherrill | 1 | -0/+0 | |
