* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 3 | -6/+3 |
* | This is another pass at making sure that nothing outside the BSP | Joel Sherrill | 1999-11-05 | 1 | -3/+1 |
| | | | | | | | | | | | | unnecessarily uses any variables defined by the BSP. On this sweep, use of BSP_Configuration and Cpu_table was eliminated. A significant part of this modification was the addition of macros to access fields in the RTEMS configuration structures. This is necessary to strengthen the division between the BSP independent parts of RTEMS and the BSPs themselves. This started after comments and analysis by Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | ||||
* | Removed spaces. | Joel Sherrill | 1998-12-03 | 1 | -9/+0 |
* | Reset the pthread attributes structure so the proper error would be | Joel Sherrill | 1998-04-27 | 1 | -1/+5 |
| | | | | generated. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 3 | -3/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 3 | -6/+6 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 3 | -15/+15 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 1 | -0/+105 |
* | updated to support ENOTSUP | Mark Johannes | 1996-08-21 | 1 | -10/+10 |
* | changed error code | Joel Sherrill | 1996-08-15 | 1 | -2/+2 |
* | added test cases for NULL being passed to pthread attribute get routines | Joel Sherrill | 1996-08-14 | 1 | -0/+20 |
* | added test case for pthread_attr_getscope being passed a NULL contentionscope | Joel Sherrill | 1996-08-14 | 1 | -0/+4 |
* | pthread_attr_setscope: returns ENOTSUP not ENOSYS for unsupport scope | Joel Sherrill | 1996-08-14 | 1 | -2/+2 |
* | added test case for stack too large | Joel Sherrill | 1996-08-12 | 1 | -0/+7 |
* | added cases to increase coverage of pthread_create. cases added tested | Joel Sherrill | 1996-08-08 | 3 | -0/+98 |
| | | | | error paths as well as inherit scheduling attributes. | ||||
* | Init: spacing | Mark Johannes | 1996-08-08 | 1 | -1/+0 |
* | added complete test cases for pthread_attr_getschedparam, | Joel Sherrill | 1996-08-07 | 1 | -9/+137 |
| | | | | | | pthread_attr_setschedparam, and pthread_getschedparam. added test cases for error paths for pthread_setschedparam. | ||||
* | removed unused prototypes | Joel Sherrill | 1996-08-02 | 1 | -9/+0 |
* | test successfully exercises all of pthread_attr_* set and get routines | Joel Sherrill | 1996-08-01 | 3 | -0/+329 |
