Updates #3053.
Update #2514.
Update #3409.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Close 2241.
Conflicts:
testsuites/psxtests/psx07/init.c
Close #2240.
* psx07/init.c: Remove unused var "clock_allowed".
PR 1981/cpukit
* configure.ac: Remove checks for pthread_attr_getcputime,
pthread_attr_setcputime.
* psx07/init.c: Remove references to pthread_attr_getcputime,
* psx01/init.c, psx07/init.c, psx09/init.c, psx12/init.c,
psxclock/init.c, psxtimer01/psxtimer.c: Include "pritime.h".
Use PRIdtime_t to print time_t.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
* psx07/init.c: Add HAVE_DECL_PTHREAD_ATTR_SETGUARDSIZE guard around
guardsize.
* Makefile.am, configure.ac, psx07/init.c, psx07/psx07.scn,
psxhdrs/Makefile.am, psxstack01/init.c: Add pthread_attr_getstack,
pthread_attr_setstack, pthread_attr_getguardsize, and
pthread_attr_setguardsize.
* psxstack02/.cvsignore, psxstack02/Makefile.am, psxstack02/init.c,
psxstack02/psxstack02.doc, psxstack02/psxstack02.scn: New files.
* psx07/init.c, psx07/task.c: Introduce enough of a delay so the Init()
thread can reliably reach the pthread_join() call.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* psx07/init.c: Include <sched.h>, <pthread.h>.
* psx07/init.c, psx07/psx07.scn, psx07/system.h, psx07/task.c: Update
test to reflect not allowing poriority changes when mutex is locked.
* psx07/init.c, psx07/psx07.scn, psx07/task.c: Add test for budget and
replenish period of zero.
* psx07/init.c: Slight test fix to ensure state of sched_param
structure.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c:
Run all tests successfully with maxixum number of priorities as 16
instead of 256. This was done by temporarily modifying the score
priority.h maximum. This allowed testing of all API code to ensure
that it worked properly with a reduced number of priorities. Most
modifications were to switch from hard-coded maximum to using the API
provided methods to determine maximum number of priority levels.
* psx07/init.c, psx07/system.h: Test cleanup and added testing for
pthread_attr_[get|set]clock.
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c,
psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h,
psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h,
psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c,
psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c,
psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h,
psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c,
psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c,
psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c,
psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c,
psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c,
psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c,
psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c,
psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c,
psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c,
psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c,
psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c,
psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c,
psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c,
psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c,
psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c,
psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c,
psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c,
psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c,
psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c,
psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c,
psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c,
psxtimer/system.h: URL for license changed.
enable this support.
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn,
psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn,
psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c,
psxtime/psxtime.scn, psxtimer/psxtimer.scn:
Various adjustments so test output matches screens more reliably.
generated.
error paths as well as inherit scheduling attributes.
pthread_attr_setschedparam, and pthread_getschedparam.
added test cases for error paths for pthread_setschedparam.
