index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
testsuites
psxtests
psx05
follow
Commit message (
Collapse
Author
Age
Lines
headers updated to reflect new style copyright notice as part
Joel Sherrill
1997-04-22
5
-25
+25
Modified to reflect change from 255 posix priority levels to 254.
Joel Sherrill
1997-04-18
2
-5
+5
corrected printf format to avoid warning
Joel Sherrill
1997-04-02
1
-1
+1
added printf of status when not successful
Joel Sherrill
1996-09-05
1
-1
+3
Filled in the screen
Mark Johannes
1996-08-23
1
-0
+111
Added Einval case for mutex not initialized
Mark Johannes
1996-08-20
1
-0
+10
pthread_mutex_init returns EAGAIN not ENOMEM when there are too many mutexes.
Joel Sherrill
1996-08-14
1
-2
+2
added numerous error test cases.
Joel Sherrill
1996-08-12
2
-14
+157
added test cases for errors in pthread_mutexattr_getpshared
Joel Sherrill
1996-08-09
1
-1
+16
added test cases for EINVAL cases in pthread_mutexattr_destroy
Joel Sherrill
1996-08-09
1
-1
+21
added test case for pthread_mutexattr_init being passed a null pointer.
Joel Sherrill
1996-08-09
1
-0
+4
changed style of output to match other tests
Joel Sherrill
1996-08-09
1
-40
+51
split test into multiple tasks.
Joel Sherrill
1996-08-08
3
-1
+110
Task_1: changed comment and task name to task1.
Mark Johannes
1996-08-08
1
-2
+2
Init.c: added priority ceiling task cases.
Mark Johannes
1996-08-08
1
-20
+204
added test case for timeout using pthread_mutex_timedlock
Joel Sherrill
1996-07-04
2
-0
+19
first test cases for mutex manager pass
Joel Sherrill
1996-07-04
4
-0
+277
