path: root/testsuites/psxtests/psx05 (follow)
* posix: Fix rwlock auto initializationSebastian Huber2018-07-161-0/+6
| | | | Add more test cases.
* testsuite/psxtests: Merged nested Makefile.am files into one Makefile.amChris Johns2018-04-101-22/+0
| | | | | | This change is part of the testsuite Makefile.am reorganization. Update #3382
* psx05: Remove CONFIGURE_DISABLE_SMP_CONFIGURATIONSebastian Huber2017-11-161-2/+0
| | | | Update #3020.
* tests: Use simple console driverSebastian Huber2017-11-061-1/+1
| | | | | Update #3170. Update #3199.
* tests: Remove TEST_INITSebastian Huber2017-10-281-2/+0
| | | | | | | | The TEST_EXTERN is a used only by the system.h style tests and they use CONFIGURE_INIT appropriately. Update #3170. Update #3199.
* testsuite: Use printk for all test output where possible.Chris Johns2017-10-231-0/+2
| | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170.
* psxtests/psx05: Fix timeout calculationSebastian Huber2017-10-091-9/+3
| | | | Update #3111.
* posix: Implement self-contained POSIX mutexSebastian Huber2017-10-053-15/+188
| | | | | | | | POSIX mutexes are now available in all configurations and no longer depend on --enable-posix. Update #2514. Update #3112.
* posix: Allow PTHREAD_PROCESS_SHARED for mutexesSebastian Huber2017-09-152-4/+7
| | | | Close #3125.
* confdefs.h: CONFIGURE_DISABLE_SMP_CONFIGURATIONSebastian Huber2017-05-111-0/+2
| | | | | | | | | | | Enable the SMP configuration by default in case SMP is enabled. Add configuration option CONFIGURE_DISABLE_SMP_CONFIGURATION to disable it explicitly. Add CONFIGURE_DISABLE_SMP_CONFIGURATION to all test which would fail otherwise. Update #3001.
* testsuites: Increase invalid priority valuesSebastian Huber2016-06-241-1/+1
| | | | | | Increase the invalid priority values to support test runs with alternative schedulers offering a significant higher maximum priority value, e.g. EDF.
* posix: pthread_mutexattr_setprioceiling()Sebastian Huber2016-06-222-13/+23
| | | | | | | Accept all priority values in pthread_mutexattr_setprioceiling(). This is in line with POSIX and FreeBSD. The priority is validated in pthread_mutex_init(). Validate the priority only for priority ceiling mutexes.
* posix: Add pthread_setschedprio()Sebastian Huber2016-06-131-0/+30
| | | | Close #2734.
* posix: Fix pthread_setschedparam()Sebastian Huber2016-06-131-0/+54
| | | | Close #2735.
* posix: Fix pthread_getschedparam()Sebastian Huber2016-06-131-0/+46
| | | | | | Return the unmodified thread priority value according to POSIX. Close #2736.
* psxtests/psx05: Adjust test caseSebastian Huber2015-02-261-2/+2
| | | | Update #2170.
* tests/psxtests: Use <rtems/test.h>Sebastian Huber2014-03-252-2/+6
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-216-6/+6
* psxtests: add documentation for psx05Chirayu Desai2013-11-292-1/+39
* score: Rename tod.h to todimpl.hSebastian Huber2013-08-011-1/+1
* score: Merge tod implementation into one fileSebastian Huber2013-07-261-0/+2
| | | | | Delete TOD_MICROSECONDS_PER_SECOND, TOD_MICROSECONDS_TO_TICKS() and TOD_MILLISECONDS_TO_TICKS().
* posix: Create priority implementation headerSebastian Huber2013-07-221-1/+0
| | | | | | Move implementation specific parts of priority.h and priority.inl into new header file priorityimpl.h. Remove priority.h since there is no application visible API.
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-116-14/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | PR 1589/build * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am, psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am, psxaio03/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxclassic01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxeintr_join/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am, psxfile02/Makefile.am, psxfilelock01/Makefile.am, psxgetrusage01/Makefile.am, psxid01/Makefile.am, psximfs01/Makefile.am, psximfs02/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxpasswd02/Makefile.am, psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxsignal06/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Remove obsolete optional manager capability.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-224-0/+16
* 2011-01-02 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2011-01-031-1/+1
| | | | * psx05/init.c: Spacing.
* 2010-10-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-211-2/+2
| | | | | | | * psx05/init.c: Check for correct status returned. * psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Add test code to exercise path when attempting to lock for reading but there is at least one writer blocked waiting for access.
* 2010-10-21 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2010-10-214-107/+107
| | | | | | | | | | | | | | | | | | * psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate double space after parenthesis on rtems_test_assert().
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-0/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally committed patch.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am, psxautoinit01/Makefile.am, psxautoinit02/Makefile.am, psxbarrier01/Makefile.am, psxcancel/Makefile.am, psxcancel01/Makefile.am, psxchroot01/Makefile.am, psxcleanup/Makefile.am, psxcleanup01/Makefile.am, psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am, psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c, psxfile02/psxfile02.doc, psxfile02/psxfile02.scn, psxintrcritical01/Makefile.am, psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am, psxmutexattr01/Makefile.am, psxobj01/Makefile.am, psxpasswd01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am, psxrwlock01/Makefile.am, psxsem01/Makefile.am, psxsignal01/Makefile.am, psxsignal02/Makefile.am, psxsignal03/Makefile.am, psxsignal04/Makefile.am, psxsignal05/Makefile.am, psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater than number of file descriptors configured.
* 2009-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-12-084-110/+110
| | | | | | | | | | | | | | | | | | | | | | | * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c, psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c, psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c, psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c, psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c, psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c: Use rtems_test_assert() consistently instead of system assert(). rtems_test_assert() is designed to integrate into the RTEMS test suite infrastructure.
* Whitespace removal.Ralf Corsepius2009-11-301-3/+3
* Use PRIxpthread_t to print pthread_t's.Ralf Corsepius2009-10-271-1/+1
* 2009-10-25 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-251-0/+2
| | | | * psx05/init.c: Include <sched.h>.
* 2009-10-11 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-10-122-0/+10
| | | | * psx05/init.c, psx05/psx05.scn: Add test for bad mutex type.
* 2009-08-17 Santosh G Vattam <vattam.santosh@gmail.com>Joel Sherrill2009-08-172-0/+19
| | | | | * configure.ac, psx05/init.c, psx05/psx05.scn: Add test case for initializing a recursize mutex.
* 2009-07-28 Santosh G Vattam <vattam.santosh@gmail.com>Joel Sherrill2009-07-282-1/+10
| | | | | * psx05/init.c, psx05/psx05.scn: Add test for pthread_mutex_timedlock with timeout in the past.
* 2009-07-06 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2009-07-062-0/+22
| | | | * psx05/init.c, psx05/psx05.scn: Add a couple of invalid Id cases.
* 2009-06-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-06-292-0/+18
| | | | | * psx05/init.c, psx05/psx05.scn: Add test case for process scope now that the assert has been removed in the source.
* 2009-05-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-05-111-2/+13
| | | | | | | | | | * psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c, psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c, psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c, psxmsgq02/init.c, psxtime/main.c, psxtime/test.c, psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-141-1/+1
| | | | * psx05/init.c: Add parameter to call to sched_get_priority_max().
* 2008-12-14 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-12-141-6/+14
| | | | | | | | | | * psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c: Run all tests successfully with maxixum number of priorities as 16 instead of 256. This was done by temporarily modifying the score priority.h maximum. This allowed testing of all API code to ensure that it worked properly with a reduced number of priorities. Most modifications were to switch from hard-coded maximum to using the API provided methods to determine maximum number of priority levels.
* 2008-07-18 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-07-181-5/+26
| | | | | | | PR 1291/cpukit * psx05/init.c, psxmsgq01/init.c: As part of addressing timeouts and POSIX services taking relative instead of absolute time for timeouts, these tests were updated.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-111-2/+1
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-12/+8
* Rework.Ralf Corsepius2005-11-111-30/+6
