index
4.11
4.8
4.9
5
master
RTEMS Kernel, file-systems, drivers, BSPs, samples, and testsuite.
devel@rtems.org
summary
refs
log
tree
commit
diff
stats
log msg
author
committer
range
path:
root
testsuites
psxtests
psx05
task.c
unfollow
Commit message (
Collapse
Author
Lines
1998-02-17
updated copyright to 1998
Joel Sherrill
1
-1
+1
1997-10-08
Fixed typo in the pointer to the license terms.
Joel Sherrill
1
-2
+2
1997-04-22
headers updated to reflect new style copyright notice as part
Joel Sherrill
1
-5
+5
1996-08-08
Task_1: changed comment and task name to task1.
Mark Johannes
1
-2
+2
1996-07-04
added test case for timeout using pthread_mutex_timedlock
Joel Sherrill
1
-0
+6
1996-07-04
first test cases for mutex manager pass
Joel Sherrill
1
-14
+15
1996-06-10
moved the time macros to pmacros.h.
Joel Sherrill
1
-1
+2
1996-06-04
added basic test cases for pthread_self and pthread_equal
Joel Sherrill
1
-14
+14
1996-05-29
simple version of test which shows pthread_create, pthread_exit, and exit
Joel Sherrill
1
-1
+6
are basically working. This test will be enhanced further.
1996-05-29
Gutted test of rtems api calls and added comments to indicate what the test
Joel Sherrill
1
-16
+11
should do in their place. It now compiles and links.
1996-05-24
new file
Joel Sherrill
1
-0
+0
