* psx02/init.c, psx04/init.c, psx13/test.c, psxchroot01/test.c,
psxhdrs/pthread07.c, psxmsgq01/init.c, psxreaddir/test.c,
psxtimer/psxtimer.c: Removed warnings.
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn,
psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn,
psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn:
Per PR239 update the IDs in the various screens.
* psx01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx02/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx03/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx04/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx05/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx06/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx07/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx08/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx09/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx10/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx11/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx12/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx13/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmount/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxstat/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtime/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/init.c, psx04/psx04.scn, psx07/init.c, psx07/psx07.scn,
psxfile01/psxfile01.scn, psxmsgq01/psxmsgq01.scn,
psxreaddir/test.c, psxstat/psxstat.scn, psxstat/test.c,
psxtime/psxtime.scn, psxtimer/psxtimer.scn:
Various adjustments so test output matches screens more reliably.
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
to convert the psxtests directory from Makefile.in to Makefile.am.
thread which has the signal unblocked.
