* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 3 | -3/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 3 | -6/+6 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 3 | -15/+15 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 1 | -0/+17 |
* | corrected problem in which sigtimedwait() was being invoked with | Joel Sherrill | 1996-08-13 | 1 | -60/+3 |
| | | | | | | the wrong mask. removed code which was commented out. This code was in another test. | ||||
* | chenaged format of output | Joel Sherrill | 1996-08-13 | 1 | -2/+6 |
* | initial modifications to test sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -0/+2 |
* | first successful run. Has test cases for a simple sigtimedwait() timeout, | Mark Johannes | 1996-06-13 | 4 | -0/+347 |
a sigtimewait() timeout because it was pthread_kill'ed with a blocked signal, and a sigtimedwait which is satisfied. |
