* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | This test was enhanced to test for the case in sigtimedwait() where it | Joel Sherrill | 2000-01-11 | 2 | -0/+32 |
| | | | | | | | must deal with a pending process oriented signal. Prior to the addition of this testcase, sigtimedwait() did not return properly when a process oriented signal was pending. The problem was reported by Wayne Bullaughey <wayneb@cacdsp.com>. | ||||
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+44 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 3 | -6/+3 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 3 | -3/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 3 | -6/+6 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 3 | -15/+15 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 1 | -0/+17 |
* | corrected problem in which sigtimedwait() was being invoked with | Joel Sherrill | 1996-08-13 | 1 | -60/+3 |
| | | | | | | the wrong mask. removed code which was commented out. This code was in another test. | ||||
* | chenaged format of output | Joel Sherrill | 1996-08-13 | 1 | -2/+6 |
* | initial modifications to test sigtimedwait. | Joel Sherrill | 1996-06-15 | 1 | -0/+2 |
* | first successful run. Has test cases for a simple sigtimedwait() timeout, | Mark Johannes | 1996-06-13 | 4 | -0/+347 |
a sigtimewait() timeout because it was pthread_kill'ed with a blocked signal, and a sigtimedwait which is satisfied. |
