2002-11-14 | 2002-11-14 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 1 | -1/+1 | |
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn, psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn, psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn: Per PR239 update the IDs in the various screens. | |||||
2000-01-11 | This test was enhanced to test for the case in sigtimedwait() where it | Joel Sherrill | 1 | -0/+4 | |
must deal with a pending process oriented signal. Prior to the addition of this testcase, sigtimedwait() did not return properly when a process oriented signal was pending. The problem was reported by Wayne Bullaughey <wayneb@cacdsp.com>. | |||||
1996-08-23 | Filled in the screen | Mark Johannes | 1 | -0/+17 | |
1996-06-13 | first successful run. Has test cases for a simple sigtimedwait() timeout, | Mark Johannes | 1 | -0/+0 | |
a sigtimewait() timeout because it was pthread_kill'ed with a blocked signal, and a sigtimedwait which is satisfied. | |||||
1996-05-24 | new files | Joel Sherrill | 1 | -0/+0 | |
