* | This test was enhanced to test for the case in sigtimedwait() where it | Joel Sherrill | 2000-01-11 | 1 | -0/+4 |
| | | | | | | | must deal with a pending process oriented signal. Prior to the addition of this testcase, sigtimedwait() did not return properly when a process oriented signal was pending. The problem was reported by Wayne Bullaughey <wayneb@cacdsp.com>. | ||||
* | Filled in the screen | Mark Johannes | 1996-08-23 | 1 | -0/+17 |
* | first successful run. Has test cases for a simple sigtimedwait() timeout, | Mark Johannes | 1996-06-13 | 1 | -0/+0 |
a sigtimewait() timeout because it was pthread_kill'ed with a blocked signal, and a sigtimedwait which is satisfied. |
