for details.
PR 1589/build
psx13/Makefile.am, psx14/Makefile.am, psx15/Makefile.am,
psx16/Makefile.am, psxaio01/Makefile.am, psxaio02/Makefile.am,
psxaio03/Makefile.am, psxalarm01/Makefile.am,
psxautoinit01/Makefile.am, psxautoinit02/Makefile.am,
psxbarrier01/Makefile.am, psxcancel/Makefile.am,
psxcancel01/Makefile.am, psxchroot01/Makefile.am,
psxclassic01/Makefile.am, psxcleanup/Makefile.am,
psxcleanup01/Makefile.am, psxclock/Makefile.am,
psxcond01/Makefile.am, psxeintr_join/Makefile.am,
psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfchx01/Makefile.am, psxfile01/Makefile.am,
psxfile02/Makefile.am, psxfilelock01/Makefile.am,
psxgetrusage01/Makefile.am, psxid01/Makefile.am,
psximfs01/Makefile.am, psximfs02/Makefile.am,
psxintrcritical01/Makefile.am, psxitimer/Makefile.am,
psxkey01/Makefile.am, psxkey02/Makefile.am, psxkey03/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am, psxmsgq02/Makefile.am,
psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxmutexattr01/Makefile.am, psxobj01/Makefile.am,
psxpasswd01/Makefile.am, psxpasswd02/Makefile.am,
psxpipe01/Makefile.am, psxrdwrv/Makefile.am, psxreaddir/Makefile.am,
psxrwlock01/Makefile.am, psxsem01/Makefile.am,
psxsignal01/Makefile.am, psxsignal02/Makefile.am,
psxsignal03/Makefile.am, psxsignal04/Makefile.am,
psxsignal05/Makefile.am, psxsignal06/Makefile.am,
psxspin01/Makefile.am, psxspin02/Makefile.am, psxstack01/Makefile.am,
psxstack02/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxtimes01/Makefile.am, psxualarm/Makefile.am, psxusleep/Makefile.am:
Remove obsolete optional manager capability.
* psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c,
psx04/task1.c, psx04/task2.c, psx04/task3.c, psx05/init.c,
psx05/task.c, psx05/task2.c, psx05/task3.c, psx06/init.c,
psx06/task.c, psx06/task2.c, psx07/init.c, psx08/init.c,
psx08/task2.c, psx08/task3.c, psx09/init.c, psx10/init.c,
psx10/task.c, psx10/task2.c, psx10/task3.c, psx11/init.c,
psx11/task.c, psx12/init.c, psxalarm01/init.c, psxbarrier01/test.c,
psxcancel01/init.c, psxchroot01/test.c, psxitimer/init.c,
psxkey01/task.c, psxkey02/init.c, psxkey03/init.c, psxmount/test.c,
psxmsgq01/init.c, psxmsgq03/init.c, psxmsgq04/init.c,
psxrwlock01/test.c, psxsem01/init.c, psxsignal01/init.c,
psxsignal01/task1.c, psxsignal02/init.c, psxsignal03/init.c,
psxsignal05/init.c, psxspin01/test.c, psxspin02/test.c,
psxstack01/init.c, psxstack02/init.c, psxualarm/init.c: Eliminate
double space after parenthesis on rtems_test_assert().
psx13/Makefile.am, psx14/Makefile.am, psxalarm01/Makefile.am,
psxcleanup/Makefile.am, psxcleanup01/Makefile.am,
psxclock/Makefile.am, psxcond01/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxintrcritical01/Makefile.am,
psxitimer/Makefile.am, psxkey01/Makefile.am, psxkey02/Makefile.am,
psxkey03/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxmsgq03/Makefile.am, psxmsgq04/Makefile.am,
psxpasswd01/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxsignal02/Makefile.am, psxsignal03/Makefile.am,
psxsignal04/Makefile.am, psxsignal05/Makefile.am,
psxstat/Makefile.am, psxsysconf/Makefile.am, psxtime/Makefile.am,
psxualarm/Makefile.am, psxusleep/Makefile.am: Revert accidentally
committed patch.
* Makefile.am, configure.ac, psx01/Makefile.am, psx02/Makefile.am,
psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am,
psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am,
psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psx13/Makefile.am, psx14/Makefile.am,
psxalarm01/Makefile.am, psxautoinit01/Makefile.am,
psxautoinit02/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxcancel01/Makefile.am,
psxchroot01/Makefile.am, psxcleanup/Makefile.am,
psxcond01/Makefile.am, psxenosys/Makefile.am, psxfatal01/Makefile.am,
psxfatal02/Makefile.am, psxfile01/Makefile.am, psxfile02/init.c,
psxfile02/psxfile02.doc, psxfile02/psxfile02.scn,
psxualarm/Makefile.am, psxusleep/Makefile.am: Add test for fd greater
than number of file descriptors configured.
* include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c,
psx03/init.c, psx03/task.c, psx04/init.c, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/task.c,
psx05/task2.c, psx05/task3.c, psx06/init.c, psx06/task.c,
psx06/task2.c, psx07/init.c, psx08/init.c, psx08/task2.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/task.c,
psxcancel01/init.c, psxchroot01/test.c, psxclock/init.c,
psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c,
psxfile01/test_write.c, psxitimer/init.c, psxkey01/task.c,
psxkey02/init.c, psxkey03/init.c, psxmount/test.c, psxmsgq01/init.c,
psxmsgq03/init.c, psxmsgq04/init.c, psxreaddir/test.c,
psxstack01/init.c, psxstat/test.c, psxtime/test.c, psxualarm/init.c:
Use rtems_test_assert() consistently instead of system assert().
rtems_test_assert() is designed to integrate into the RTEMS test
suite infrastructure.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psx02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx13/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxcancel/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxchroot01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxfile01/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmount/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxmsgq01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxreaddir/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxsem01/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxstat/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtime/main.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psxtimer/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* psx02/Makefile.am: Ditto.
* psx03/Makefile.am: Ditto.
* psx04/Makefile.am: Ditto.
* psx05/Makefile.am: Ditto.
* psx06/Makefile.am: Ditto.
* psx07/Makefile.am: Ditto.
* psx08/Makefile.am: Ditto.
* psx09/Makefile.am: Ditto.
* psx10/Makefile.am: Ditto.
* psx11/Makefile.am: Ditto.
* psx12/Makefile.am: Ditto.
* psx13/Makefile.am: Ditto.
* psxcancel/Makefile.am: Ditto.
* psxchroot01/Makefile.am: Ditto.
* psxfile01/Makefile.am: Ditto.
* psxmount/Makefile.am: Ditto.
* psxmsgq01/Makefile.am: Ditto.
* psxreaddir/Makefile.am: Ditto.
* psxsem01/Makefile.am: Ditto.
* psxstat/Makefile.am: Ditto.
* psxtime/Makefile.am: Ditto.
* psxtimer/Makefile.am: Ditto.
* include/Makefile.am: Reformat.
* psx01/Makefile.am: Remove all-local: $(ARCH).
* psx02/Makefile.am: Remove all-local: $(ARCH).
* psx03/Makefile.am: Remove all-local: $(ARCH).
* psx04/Makefile.am: Remove all-local: $(ARCH).
* psx05/Makefile.am: Remove all-local: $(ARCH).
* psx06/Makefile.am: Remove all-local: $(ARCH).
* psx07/Makefile.am: Remove all-local: $(ARCH).
* psx08/Makefile.am: Remove all-local: $(ARCH).
* psx09/Makefile.am: Remove all-local: $(ARCH).
* psx10/Makefile.am: Remove all-local: $(ARCH).
* psx11/Makefile.am: Remove all-local: $(ARCH).
* psx12/Makefile.am: Remove all-local: $(ARCH).
* psx13/Makefile.am: Remove all-local: $(ARCH).
* psxcancel/Makefile.am: Remove all-local: $(ARCH).
* psxchroot01/Makefile.am: Remove all-local: $(ARCH).
* psxfile01/Makefile.am: Remove all-local: $(ARCH).
* psxhdrs/Makefile.am: Remove all-local: $(ARCH).
* psxmount/Makefile.am: Remove all-local: $(ARCH).
* psxmsgq01/Makefile.am: Remove all-local: $(ARCH).
* psxreaddir/Makefile.am: Remove all-local: $(ARCH).
* psxsem01/Makefile.am: Remove all-local: $(ARCH).
* psxstat/Makefile.am: Remove all-local: $(ARCH).
* psxtime/Makefile.am: Remove all-local: $(ARCH).
* psxtimer/Makefile.am: Remove all-local: $(ARCH).
* psx01/init.c, psx01/system.h, psx01/task.c, psx02/init.c,
psx02/system.h, psx02/task.c, psx03/init.c, psx03/system.h,
psx03/task.c, psx04/init.c, psx04/system.h, psx04/task1.c,
psx04/task2.c, psx04/task3.c, psx05/init.c, psx05/system.h,
psx06/system.h, psx06/task.c, psx06/task2.c, psx07/init.c,
psx07/system.h, psx07/task.c, psx08/init.c, psx08/system.h,
psx08/task1.c, psx08/task2.c, psx08/task3.c, psx09/init.c,
psx09/system.h, psx10/init.c, psx10/system.h, psx10/task.c,
psx10/task2.c, psx10/task3.c, psx11/init.c, psx11/system.h,
psx11/task.c, psx12/init.c, psx12/system.h, psx12/task.c,
psx13/main.c, psx13/test.c, psxcancel/init.c, psxfile01/main.c,
psxfile01/test.c, psxhdrs/clock01.c, psxhdrs/clock02.c,
psxhdrs/clock03.c, psxhdrs/clock04.c, psxhdrs/clock05.c,
psxhdrs/clock06.c, psxhdrs/cond01.c, psxhdrs/cond02.c,
psxhdrs/cond03.c, psxhdrs/cond04.c, psxhdrs/cond05.c,
psxhdrs/cond06.c, psxhdrs/cond07.c, psxhdrs/cond08.c,
psxhdrs/cond09.c, psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c,
psxhdrs/key03.c, psxhdrs/key04.c, psxhdrs/mutex01.c,
psxhdrs/mutex02.c, psxhdrs/mutex03.c, psxhdrs/mutex04.c,
psxhdrs/mutex05.c, psxhdrs/mutex06.c, psxhdrs/mutex07.c,
psxhdrs/mutex08.c, psxhdrs/mutex09.c, psxhdrs/mutex10.c,
psxhdrs/mutex11.c, psxhdrs/mutex12.c, psxhdrs/mutex13.c,
psxhdrs/mutex14.c, psxhdrs/mutex15.c, psxhdrs/mutex16.c,
psxhdrs/proc01.c, psxhdrs/proc02.c, psxhdrs/proc03.c,
psxhdrs/proc04.c, psxhdrs/proc05.c, psxhdrs/proc06.c,
psxhdrs/proc07.c, psxhdrs/proc08.c, psxhdrs/proc09.c,
psxhdrs/proc10.c, psxhdrs/proc11.c, psxhdrs/proc12.c,
psxhdrs/proc13.c, psxhdrs/proc14.c, psxhdrs/pthread01.c,
psxhdrs/pthread02.c, psxhdrs/pthread03.c, psxhdrs/pthread04.c,
psxhdrs/pthread05.c, psxhdrs/pthread06.c, psxhdrs/pthread07.c,
psxhdrs/pthread08.c, psxhdrs/pthread09.c, psxhdrs/pthread10.c,
psxhdrs/pthread11.c, psxhdrs/pthread12.c, psxhdrs/pthread13.c,
psxhdrs/pthread14.c, psxhdrs/pthread15.c, psxhdrs/pthread16.c,
psxhdrs/pthread17.c, psxhdrs/pthread18.c, psxhdrs/pthread19.c,
psxhdrs/pthread20.c, psxhdrs/pthread21.c, psxhdrs/pthread22.c,
psxhdrs/pthread23.c, psxhdrs/pthread24.c, psxhdrs/pthread25.c,
psxhdrs/pthread26.c, psxhdrs/pthread27.c, psxhdrs/pthread28.c,
psxhdrs/pthread29.c, psxhdrs/pthread30.c, psxhdrs/pthread31.c,
psxhdrs/pthread32.c, psxhdrs/pthread33.c, psxhdrs/pthread34.c,
psxhdrs/pthread35.c, psxhdrs/pthread36.c, psxhdrs/sched01.c,
psxhdrs/sched02.c, psxhdrs/sched03.c, psxhdrs/sched04.c,
psxhdrs/sched05.c, psxhdrs/sched06.c, psxhdrs/sched07.c,
psxhdrs/sched08.c, psxhdrs/signal01.c, psxhdrs/signal02.c,
psxhdrs/signal03.c, psxhdrs/signal04.c, psxhdrs/signal05.c,
psxhdrs/signal06.c, psxhdrs/signal07.c, psxhdrs/signal08.c,
psxhdrs/signal09.c, psxhdrs/signal10.c, psxhdrs/signal11.c,
psxhdrs/signal12.c, psxhdrs/signal13.c, psxhdrs/signal14.c,
psxhdrs/signal15.c, psxhdrs/signal16.c, psxhdrs/signal17.c,
psxhdrs/signal18.c, psxhdrs/signal19.c, psxhdrs/signal20.c,
psxhdrs/signal21.c, psxhdrs/signal22.c, psxhdrs/signal23.c,
psxhdrs/sync01.c, psxhdrs/sync02.c, psxhdrs/sync03.c,
psxhdrs/time01.c, psxhdrs/time02.c, psxhdrs/time03.c,
psxhdrs/time04.c, psxhdrs/time05.c, psxhdrs/time06.c,
psxhdrs/time07.c, psxhdrs/time08.c, psxhdrs/time09.c,
psxhdrs/time10.c, psxhdrs/time11.c, psxhdrs/time12.c,
psxhdrs/time13.c, psxhdrs/timer01.c, psxhdrs/timer02.c,
psxhdrs/timer03.c, psxhdrs/timer04.c, psxhdrs/timer05.c,
psxhdrs/timer06.c, psxhdrs/timer07.c, psxmsgq01/init.c,
psxmsgq01/system.h, psxsem01/system.h, psxstat/main.c,
psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c,
psxtimer/system.h: URL for license changed.
psx01/Makefile.am: Reflect having moved automake.
psx02/Makefile.am: Reflect having moved automake.
psx03/Makefile.am: Reflect having moved automake.
psx04/Makefile.am: Reflect having moved automake.
psx05/Makefile.am: Reflect having moved automake.
psx06/Makefile.am: Reflect having moved automake.
psx07/Makefile.am: Reflect having moved automake.
psx08/Makefile.am: Reflect having moved automake.
psx09/Makefile.am: Reflect having moved automake.
psx10/Makefile.am: Reflect having moved automake.
psx11/Makefile.am: Reflect having moved automake.
psx12/Makefile.am: Reflect having moved automake.
psx13/Makefile.am: Reflect having moved automake.
psxcancel/Makefile.am: Reflect having moved automake.
psxchroot01/Makefile.am: Reflect having moved automake.
psxfile01/Makefile.am: Reflect having moved automake.
psxhdrs/Makefile.am: Reflect having moved automake.
psxmount/Makefile.am: Reflect having moved automake.
psxmsgq01/Makefile.am: Reflect having moved automake.
psxreaddir/Makefile.am: Reflect having moved automake.
psxsem01/Makefile.am: Reflect having moved automake.
psxstat/Makefile.am: Reflect having moved automake.
psxtime/Makefile.am: Reflect having moved automake.
psxtimer/Makefile.am: Reflect having moved automake.
* psx02/init.c, psx04/init.c, psx13/test.c, psxchroot01/test.c,
psxhdrs/pthread07.c, psxmsgq01/init.c, psxreaddir/test.c,
psxtimer/psxtimer.c: Removed warnings.
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn,
psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn,
psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn:
Per PR239 update the IDs in the various screens.
* psx01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx02/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx03/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx04/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx05/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx06/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx07/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx08/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx09/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx10/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx11/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx12/Makefile.am: Use .$(OBJEXT) instead of .o.
* psx13/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmount/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxstat/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtime/Makefile.am: Use .$(OBJEXT) instead of .o.
* psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
enable this support.
psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c,
psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c,
psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c,
psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c,
psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c,
psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c,
psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am,
psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c,
psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c,
psxtime/test.c, psxtimer/psxtimer.c: Modified.
* psx01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* psx01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx11/Makefile.am: include leaf.am instead of leaf.cfg.
* psxcancel/Makefile.am: include leaf.am instead of leaf.cfg.
* psx02/Makefile.am: include leaf.am instead of leaf.cfg.
* psx13/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtime/Makefile.am: include leaf.am instead of leaf.cfg.
* psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx07/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg.
* psxtimer/Makefile.am: include leaf.am instead of leaf.cfg.
* psx10/Makefile.am: include leaf.am instead of leaf.cfg.
* psx08/Makefile.am: include leaf.am instead of leaf.cfg.
* psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg.
* psxfile01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx05/Makefile.am: include leaf.am instead of leaf.cfg.
* psx09/Makefile.am: include leaf.am instead of leaf.cfg.
* psxmount/Makefile.am: include leaf.am instead of leaf.cfg.
* psxstat/Makefile.am: include leaf.am instead of leaf.cfg.
* psx12/Makefile.am: include leaf.am instead of leaf.cfg.
* psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg.
* psxsem01/Makefile.am: include leaf.am instead of leaf.cfg.
* psx03/Makefile.am: include leaf.am instead of leaf.cfg.
* psx04/Makefile.am: include leaf.am instead of leaf.cfg.
* psx06/Makefile.am: include leaf.am instead of leaf.cfg.
psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am,
psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am,
psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am,
psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am,
psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am:
Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
to convert the psxtests directory from Makefile.in to Makefile.am.
