* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 2 | -6/+7 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+44 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 3 | -6/+3 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 3 | -3/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 3 | -6/+6 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 3 | -15/+15 |
* | Filled in the screen | Mark Johannes | 1996-08-23 | 1 | -0/+26 |
* | added include of errno.h so the test can check for EINTR. | Joel Sherrill | 1996-08-13 | 1 | -0/+1 |
* | nanosleep now returns -1 and EINTR when a signal interrupts EINTR. | Joel Sherrill | 1996-08-13 | 1 | -2/+8 |
* | Added test case which blocks a signal, sees what signals are pending, sends | Joel Sherrill | 1996-06-11 | 1 | -1/+44 |
| | | | | | that same signal to the executing thread, sees what is pending, then unblocks that signal so the handler can execute. | ||||
* | modified to test pthread_kill() to self and pthread_kill() to a blocked | Joel Sherrill | 1996-06-11 | 2 | -8/+24 |
| | | | | thread. nanosleep() can be interrupted and return the time remaining. | ||||
* | new files. | Joel Sherrill | 1996-06-10 | 4 | -0/+177 |
This test does a basic checkout of signals with a thread-directed signal (pthread_kill()) used to interrupt a nanosleep(). |
