* | 2001-01-25 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2001-01-25 | 1 | -5/+3 |
| | | | | * psx01/psx01.scn: Corrected to reflect clock_getres() now working. | ||||
* | 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-05 | 1 | -0/+1 |
| | | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am | ||||
* | 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-09-01 | 1 | -1/+1 |
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS = | ||||
* | Merged from 4.5.0-beta3a | Joel Sherrill | 2000-06-12 | 3 | -10/+11 |
* | Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>. | Joel Sherrill | 2000-04-13 | 1 | -0/+2 |
| | | | | adds .cvsignore. | ||||
* | Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 2000-01-31 | 1 | -1/+0 |
| | | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams). | ||||
* | Corrected order of output. | Joel Sherrill | 1999-12-13 | 1 | -1/+1 |
* | Moved pmacros.h to include not support/include. | Joel Sherrill | 1999-11-23 | 1 | -1/+1 |
* | Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de> | Joel Sherrill | 1999-11-23 | 1 | -0/+44 |
| | | | | to convert the psxtests directory from Makefile.in to Makefile.am. | ||||
* | Updated copyright notice. | Joel Sherrill | 1999-11-17 | 3 | -6/+3 |
* | Added test cases for uname(). | Joel Sherrill | 1999-11-16 | 2 | -0/+25 |
* | Updated scn files to match present expected test output. | Jennifer Averett | 1998-12-03 | 1 | -1/+1 |
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 3 | -3/+3 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 3 | -6/+6 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 3 | -15/+15 |
* | Modified to reflect change from 255 posix priority levels to 254. | Joel Sherrill | 1997-04-18 | 1 | -1/+1 |
* | nanosleep no longer consider a negative value of tv_sec to be an error. | Joel Sherrill | 1996-09-05 | 1 | -6/+7 |
| | | | | Instead it is an indication of a request for a small delay. | ||||
* | Filled in the screen | Mark Johannes | 1996-08-23 | 1 | -0/+46 |
* | Added build_time statement to provide a tm for the test | Mark Johannes | 1996-08-23 | 1 | -2/+4 |
* | changed error for too many threads to EAGAIN | Joel Sherrill | 1996-08-15 | 1 | -2/+2 |
* | added test cases for clock_getres | Joel Sherrill | 1996-08-12 | 1 | -9/+27 |
* | added test cases for clock_gettime (invalid id), clock_settime (invalid_id), | Joel Sherrill | 1996-08-12 | 1 | -0/+48 |
| | | | | nanosleep (yield cpu), and numerous error cases in nanosleep | ||||
* | added test case for non-NULL parameter to time() | Joel Sherrill | 1996-08-12 | 1 | -0/+6 |
* | lowered maximum number of threads to 2 to make test case easier. | Joel Sherrill | 1996-08-09 | 1 | -0/+3 |
| | | | | include sched.h so test can invoke scheduler routines. | ||||
* | added test case for sched_yield. | Joel Sherrill | 1996-08-09 | 1 | -6/+14 |
| | | | | changed format of some output. | ||||
* | added test cases for errors in sched_get_priority_min and | Joel Sherrill | 1996-08-09 | 1 | -5/+30 |
| | | | | | | sched_get_priority_max. added test case for sched_yield. | ||||
* | added complete test cases for pthread_once. | Joel Sherrill | 1996-08-08 | 3 | -16/+44 |
* | added more error cases to complete testing of pthread_equal when | Joel Sherrill | 1996-08-07 | 1 | -0/+8 |
| | | | | RTEMS_DEBUG is enabled. | ||||
* | moved the time macros to pmacros.h. | Joel Sherrill | 1996-06-10 | 3 | -38/+4 |
* | added include of <sched.h> and fixed warnings | Joel Sherrill | 1996-06-06 | 1 | -2/+3 |
* | added test case for sched_get_priority_min, sched_get_priority_max, | Joel Sherrill | 1996-06-04 | 1 | -0/+23 |
| | | | | and sched_rr_get_interval. | ||||
* | added basic test cases for pthread_self and pthread_equal | Joel Sherrill | 1996-06-04 | 3 | -14/+28 |
* | added test code for return of remaining time from sleep(). | Joel Sherrill | 1996-06-03 | 1 | -2/+8 |
* | added test case for nanosleep filling in the time remaining structure. | Joel Sherrill | 1996-06-03 | 1 | -0/+1 |
* | added test code for nanosleep and return code from sleep. | Joel Sherrill | 1996-06-03 | 1 | -2/+27 |
* | added code to test clock and time related functionality. | Joel Sherrill | 1996-05-30 | 2 | -17/+63 |
* | tests now specify whether using posix initialization threads table | Joel Sherrill | 1996-05-29 | 2 | -5/+3 |
| | | | | or rtems initialization table in configuration table | ||||
* | simple version of test which shows pthread_create, pthread_exit, and exit | Joel Sherrill | 1996-05-29 | 3 | -4/+19 |
| | | | | are basically working. This test will be enhanced further. | ||||
* | Gutted test of rtems api calls and added comments to indicate what the test | Joel Sherrill | 1996-05-29 | 3 | -77/+31 |
| | | | | should do in their place. It now compiles and links. | ||||
* | new file | Joel Sherrill | 1996-05-24 | 1 | -0/+50 |
* | new files | Joel Sherrill | 1996-05-24 | 3 | -4/+111 |
* | new file | Mark Johannes | 1996-05-24 | 1 | -0/+22 |
