* | 2002-08-01 Joel Sherrill <joel@OARcorp.com> | Joel Sherrill | 2002-08-02 | 1 | -1/+1 |
| | | | | | | | | | | | | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * include/pmacros.h, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c, psx04/init.c, psx05/init.c, psx06/init.c, psx07/init.c, psx08/task3.c, psx09/init.c, psx10/init.c, psx11/init.c, psx12/init.c, psx13/Makefile.am, psx13/main.c, psx13/test.c, psxcancel/init.c, psxchroot01/Makefile.am, psxchroot01/main.c, psxchroot01/test.c, psxfile01/Makefile.am, psxfile01/main.c, psxfile01/test.c, psxfile01/test_cat.c, psxfile01/test_extend.c, psxfile01/test_write.c, psxmount/Makefile.am, psxmount/main.c, psxmount/test.c, psxmsgq01/init.c, psxreaddir/Makefile.am, psxreaddir/main.c, psxreaddir/test.c, psxsem01/init.c, psxstat/Makefile.am, psxstat/main.c, psxstat/test.c, psxtime/main.c, psxtime/test.c, psxtimer/psxtimer.c: Modified. | ||||
* | updated copyright to 1998 | Joel Sherrill | 1998-02-17 | 1 | -1/+1 |
* | Fixed typo in the pointer to the license terms. | Joel Sherrill | 1997-10-08 | 1 | -2/+2 |
* | headers updated to reflect new style copyright notice as part | Joel Sherrill | 1997-04-22 | 1 | -5/+5 |
* | added test case for sched_yield. | Joel Sherrill | 1996-08-09 | 1 | -6/+14 |
| | | | | changed format of some output. | ||||
* | added complete test cases for pthread_once. | Joel Sherrill | 1996-08-08 | 1 | -8/+35 |
* | added more error cases to complete testing of pthread_equal when | Joel Sherrill | 1996-08-07 | 1 | -0/+8 |
| | | | | RTEMS_DEBUG is enabled. | ||||
* | moved the time macros to pmacros.h. | Joel Sherrill | 1996-06-10 | 1 | -1/+2 |
* | added basic test cases for pthread_self and pthread_equal | Joel Sherrill | 1996-06-04 | 1 | -14/+14 |
* | simple version of test which shows pthread_create, pthread_exit, and exit | Joel Sherrill | 1996-05-29 | 1 | -1/+6 |
| | | | | are basically working. This test will be enhanced further. | ||||
* | Gutted test of rtems api calls and added comments to indicate what the test | Joel Sherrill | 1996-05-29 | 1 | -16/+11 |
| | | | | should do in their place. It now compiles and links. | ||||
* | new file | Joel Sherrill | 1996-05-24 | 1 | -0/+50 |
