* Makefile.am, configure.ac, psx01/init.c, psx01/psx01.scn: Add new
test to exercise clock and delay services enabled when POSIX threads
are disabled. This is split from psx01. POSIX test suite now enabled
when POSIX threads are disabled so only enable tests which are
appropriate.
* psxclock/.cvsignore, psxclock/Makefile.am, psxclock/init.c,
psxclock/psxclock.doc, psxclock/psxclock.scn: New files.
* psx01/init.c, psx01/psx01.scn: Add test case for nanosleep with NULL
remaining pointer.
* psx01/psx01.scn: Bump version to 4.9.99.0
* psx01/init.c, psx01/psx01.scn: Add more test cases for
sched_rr_get_interval() and sched_get_priority_max().
* psx01/init.c, psx01/psx01.scn: Add usleep() test.
* psx01/init.c, psx01/psx01.scn: Adjust test to account for nanosleep()
behavior more closely matching GNU/Linux.
* psx01/psx01.scn, psx02/psx02.scn, psx03/psx03.scn, psx04/psx04.scn,
psx05/psx05.scn, psx06/psx06.scn, psx07/psx07.scn, psx08/psx08.scn,
psx09/psx09.scn, psx10/psx10.scn, psx11/psx11.scn, psx12/psx12.scn:
Per PR239 update the IDs in the various screens.
* psx01/psx01.scn: Corrected to reflect clock_getres() now working.
