path: root/testsuites/psxtests/psx01/Makefile.am (follow)
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-9/+6
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * psx02/Makefile.am: Ditto. * psx03/Makefile.am: Ditto. * psx04/Makefile.am: Ditto. * psx05/Makefile.am: Ditto. * psx06/Makefile.am: Ditto. * psx07/Makefile.am: Ditto. * psx08/Makefile.am: Ditto. * psx09/Makefile.am: Ditto. * psx10/Makefile.am: Ditto. * psx11/Makefile.am: Ditto. * psx12/Makefile.am: Ditto. * psx13/Makefile.am: Ditto. * psxcancel/Makefile.am: Ditto. * psxchroot01/Makefile.am: Ditto. * psxfile01/Makefile.am: Ditto. * psxmount/Makefile.am: Ditto. * psxmsgq01/Makefile.am: Ditto. * psxreaddir/Makefile.am: Ditto. * psxsem01/Makefile.am: Ditto. * psxstat/Makefile.am: Ditto. * psxtime/Makefile.am: Ditto. * psxtimer/Makefile.am: Ditto.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | * include/Makefile.am: Reformat. * psx01/Makefile.am: Remove all-local: $(ARCH). * psx02/Makefile.am: Remove all-local: $(ARCH). * psx03/Makefile.am: Remove all-local: $(ARCH). * psx04/Makefile.am: Remove all-local: $(ARCH). * psx05/Makefile.am: Remove all-local: $(ARCH). * psx06/Makefile.am: Remove all-local: $(ARCH). * psx07/Makefile.am: Remove all-local: $(ARCH). * psx08/Makefile.am: Remove all-local: $(ARCH). * psx09/Makefile.am: Remove all-local: $(ARCH). * psx10/Makefile.am: Remove all-local: $(ARCH). * psx11/Makefile.am: Remove all-local: $(ARCH). * psx12/Makefile.am: Remove all-local: $(ARCH). * psx13/Makefile.am: Remove all-local: $(ARCH). * psxcancel/Makefile.am: Remove all-local: $(ARCH). * psxchroot01/Makefile.am: Remove all-local: $(ARCH). * psxfile01/Makefile.am: Remove all-local: $(ARCH). * psxhdrs/Makefile.am: Remove all-local: $(ARCH). * psxmount/Makefile.am: Remove all-local: $(ARCH). * psxmsgq01/Makefile.am: Remove all-local: $(ARCH). * psxreaddir/Makefile.am: Remove all-local: $(ARCH). * psxsem01/Makefile.am: Remove all-local: $(ARCH). * psxstat/Makefile.am: Remove all-local: $(ARCH). * psxtime/Makefile.am: Remove all-local: $(ARCH). * psxtimer/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. include/Makefile.am: Reflect having moved automake. psx01/Makefile.am: Reflect having moved automake. psx02/Makefile.am: Reflect having moved automake. psx03/Makefile.am: Reflect having moved automake. psx04/Makefile.am: Reflect having moved automake. psx05/Makefile.am: Reflect having moved automake. psx06/Makefile.am: Reflect having moved automake. psx07/Makefile.am: Reflect having moved automake. psx08/Makefile.am: Reflect having moved automake. psx09/Makefile.am: Reflect having moved automake. psx10/Makefile.am: Reflect having moved automake. psx11/Makefile.am: Reflect having moved automake. psx12/Makefile.am: Reflect having moved automake. psx13/Makefile.am: Reflect having moved automake. psxcancel/Makefile.am: Reflect having moved automake. psxchroot01/Makefile.am: Reflect having moved automake. psxfile01/Makefile.am: Reflect having moved automake. psxhdrs/Makefile.am: Reflect having moved automake. psxmount/Makefile.am: Reflect having moved automake. psxmsgq01/Makefile.am: Reflect having moved automake. psxreaddir/Makefile.am: Reflect having moved automake. psxsem01/Makefile.am: Reflect having moved automake. psxstat/Makefile.am: Reflect having moved automake. psxtime/Makefile.am: Reflect having moved automake. psxtimer/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: Use .$(OBJEXT) instead of .o. * psx02/Makefile.am: Use .$(OBJEXT) instead of .o. * psx03/Makefile.am: Use .$(OBJEXT) instead of .o. * psx04/Makefile.am: Use .$(OBJEXT) instead of .o. * psx05/Makefile.am: Use .$(OBJEXT) instead of .o. * psx06/Makefile.am: Use .$(OBJEXT) instead of .o. * psx07/Makefile.am: Use .$(OBJEXT) instead of .o. * psx08/Makefile.am: Use .$(OBJEXT) instead of .o. * psx09/Makefile.am: Use .$(OBJEXT) instead of .o. * psx10/Makefile.am: Use .$(OBJEXT) instead of .o. * psx11/Makefile.am: Use .$(OBJEXT) instead of .o. * psx12/Makefile.am: Use .$(OBJEXT) instead of .o. * psx13/Makefile.am: Use .$(OBJEXT) instead of .o. * psxcancel/Makefile.am: Use .$(OBJEXT) instead of .o. * psxchroot01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxfile01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxhdrs/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmount/Makefile.am: Use .$(OBJEXT) instead of .o. * psxmsgq01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxreaddir/Makefile.am: Use .$(OBJEXT) instead of .o. * psxsem01/Makefile.am: Use .$(OBJEXT) instead of .o. * psxstat/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtime/Makefile.am: Use .$(OBJEXT) instead of .o. * psxtimer/Makefile.am: Use .$(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * Makefile.am: Remove AUTOMAKE_OPTIONS. * include/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx02/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx03/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx04/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx05/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx06/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx07/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx08/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx09/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx10/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx11/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx12/Makefile.am: Remove AUTOMAKE_OPTIONS. * psx13/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxcancel/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxchroot01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxfile01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxhdrs/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmount/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxmsgq01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxreaddir/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxsem01/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxstat/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtime/Makefile.am: Remove AUTOMAKE_OPTIONS. * psxtimer/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | * psx01/Makefile.am: include leaf.am instead of leaf.cfg. * psx11/Makefile.am: include leaf.am instead of leaf.cfg. * psxcancel/Makefile.am: include leaf.am instead of leaf.cfg. * psx02/Makefile.am: include leaf.am instead of leaf.cfg. * psx13/Makefile.am: include leaf.am instead of leaf.cfg. * psxtime/Makefile.am: include leaf.am instead of leaf.cfg. * psxchroot01/Makefile.am: include leaf.am instead of leaf.cfg. * psx07/Makefile.am: include leaf.am instead of leaf.cfg. * psxmsgq01/Makefile.am: include leaf.am instead of leaf.cfg. * psxtimer/Makefile.am: include leaf.am instead of leaf.cfg. * psx10/Makefile.am: include leaf.am instead of leaf.cfg. * psx08/Makefile.am: include leaf.am instead of leaf.cfg. * psxhdrs/Makefile.am: include leaf.am instead of leaf.cfg. * psxfile01/Makefile.am: include leaf.am instead of leaf.cfg. * psx05/Makefile.am: include leaf.am instead of leaf.cfg. * psx09/Makefile.am: include leaf.am instead of leaf.cfg. * psxmount/Makefile.am: include leaf.am instead of leaf.cfg. * psxstat/Makefile.am: include leaf.am instead of leaf.cfg. * psx12/Makefile.am: include leaf.am instead of leaf.cfg. * psxreaddir/Makefile.am: include leaf.am instead of leaf.cfg. * psxsem01/Makefile.am: include leaf.am instead of leaf.cfg. * psx03/Makefile.am: include leaf.am instead of leaf.cfg. * psx04/Makefile.am: include leaf.am instead of leaf.cfg. * psx06/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psx13/Makefile.am, psxcancel/Makefile.am, psxfile01/Makefile.am, psxhdrs/Makefile.am, psxmount/Makefile.am, psxmsgq01/Makefile.am, psxreaddir/Makefile.am, psxsem01/Makefile.am, psxstat/Makefile.am, psxtime/Makefile.am, psxtimer/Makefile.am: Include compile.am
* 2000-08-31 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-011-1/+1
| | | | | | | | | | * psx01/Makefile.am, psx02/Makefile.am, psx03/Makefile.am, psx04/Makefile.am, psx05/Makefile.am, psx06/Makefile.am, psx07/Makefile.am, psx08/Makefile.am, psx09/Makefile.am, psx10/Makefile.am, psx11/Makefile.am, psx11/Makefile.am, psx12/Makefile.am, psxcancel/Makefile.am, psxmsgq01/Makefile.am, psxsem01/Makefile.am, psxsem01/Makefile.am, psxtimer/Makefile.am: Use AM_CPPFLAGS += instead of AM_CPPFLAGS =
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+4
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Moved pmacros.h to include not support/include.Joel Sherrill1999-11-231-1/+1
* Patch rtems-rc-19991117-14.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+44
to convert the psxtests directory from Makefile.in to Makefile.am.
