Signed-off-by: Eshan Dhawan <eshandhawan51@gmail.com>
+ Modify POSIX thread create extension to ensure expected
initial signal mask is provided to system threads, initial
tasks and threads, and inheritied by tasks and threads.
+ Adds psxsignal07 to verify functionality when using a POSIX
Initialization thread and POSIX threads.
+ Adds psxsignal08 to verify functionality when using a Classic API
Initialization task and Classic API tasks.
Closes #3794.
Note that this test requires a functional fenv implementation. Some
targets have multilib variants where the fenv implementation is not
100% passing.
Joel Sherrill <joel@rtems.org> modified the patch to
add autoconf logic to avoid building this new test
unless the tool chain include <ndbm.h>. The ensures
that git bisect continues to work and that the addition
of this test does not immediately force the entire
community to update their tools.
Update #3409.
upgrade to that version.
Close #3387.
Update #3382
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
Update #3182.
Updates #2859
errors.
- Add a top level test configuration file for test states that are common
to all BSPs. This saves adding a test configuration (tcfg) file for
every BSP.
- Add the test states 'user-input' and 'benchmark'. This
lets 'rtems-test' stop the test rather than waiting for a timeout or
letting a benchmark run without the user asking for it to run.
- Implement rtems-test-check in Python to make it faster. The shell script
had grown to a point it was noticably slowing the build down.
- Fix the configure.ac and Makefile.am files for a number of the
test directories. The files are difficiult to keep in sync with the
number of tests and mistakes can happen such as tests being left
out of the build. The test fsrofs01 is an example. Also a there was
a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be
used.
- Fix the test fsrofs01 so it compiles.
Closes #2963.
Add POSIX shared memory manager (Shm). Includes a hook-based
approach for the backing memory storage that defaults to the
Workspace, and a test is provided using the heap. A test is
also provided for the basic use of mmap'ing a shared memory
object. This test currently fails at the mmap stage due to
no support for mmap.
Add pthread_getname_np() and pthread_setname_np().
Update #2858.
Turn pthread_spinlock_t into a self-contained object. On uni-processor
configurations, interrupts are disabled in the lock/trylock operations
and the previous interrupt status is restored in the corresponding
unlock operations. On SMP configurations, a ticket lock is a acquired
and released in addition.
The self-contained pthread_spinlock_t object is defined by Newlib in
<sys/_pthreadtypes.h>.
typedef struct {
struct _Ticket_lock_Control _lock;
__uint32_t _interrupt_state;
} pthread_spinlock_t;
This implementation is simple and efficient. However, this test case of
the Linux Test Project would fail due to call of printf() and sleep()
during spin lock ownership:
https://github.com/linux-test-project/ltp/blob/master/testcases/open_posix_testsuite/conformance/interfaces/pthread_spin_lock/1-2.c
There is only limited support for profiling on SMP configurations.
Delete CORE spinlock implementation.
Update #2674.
updates #2608.
This is the very simple implementation specified by the Open Group
for implementations with 1:1 kernel thread to user thread mappings.
http://pubs.opengroup.org/onlinepubs/9699919799/functions/pthread_getconcurrency.html
updates #2680.
Closes #2182
Ensure that the global construction is performed in the context of the
first initialization thread. On SMP this was not guaranteed in the
previous implementation.
This patch enables unlimited model in POSIX key manger and have a decent
runtime on POSIX key searching, adding and deleting operations. Memory
overhead is lower than current implementation when the size of key and key
value becomes big.
for details.
* configure.ac: Check for getrusage decl.
* psxgetrusage01/init.c:
Fix header file inclusion order.
Move configuration section up.
Apply HAVE_DECL_GETRUSAGE.
* psxconfig01/.cvsignore, psxconfig01/Makefile.am, psxconfig01/init.c,
psxconfig01/psxconfig01.doc, psxconfig01/psxconfig01.scn: New files.
* Makefile.am, configure.ac: Reflect changes above.
PR 1981/cpukit
* configure.ac: Remove checks for pthread_attr_getcputime,
pthread_attr_setcputime.
* psx07/init.c: Remove references to pthread_attr_getcputime,
* configure.ac: Check for size of mode_t.
* psxfile01/test.c, psxstat/test.c: Include "primode.h".
Use PRIomode_t to print mode_t.
* configure.ac: Check for size of time_t.
PR 1855/cpukit
* Makefile.am, configure.ac: Correct signal processing during
pthread_join. We are supposed to unblock the thread waiting on a
pthread_join(), dispatch the signal handler, account for it
potentially overwriting errno, and then have the thread return to
blocking within pthread_join().
* psxeintr_join/.cvsignore, psxeintr_join/Makefile.am,
psxeintr_join/init.c, psxeintr_join/psxeintr_join.doc,
psxeintr_join/psxeintr_join.scn: New files.
PR 1867/cpukit
* Makefile.am, configure.ac, psx12/task.c, psxkey03/init.c,
psxrwlock01/test.c: Correct implementation of pthread_exit() and
pthread_join() to support the case where a thread is joinable but
calls pthread_exit() before a thread has attempted to join.
PR 1759/cpukit
* Makefile.am, configure.ac: Add test to use some pthread calls with
Classic Tasks.
* psxclassic01/.cvsignore, psxclassic01/Makefile.am,
psxclassic01/init.c, psxclassic01/psxclassic01.doc,
psxclassic01/psxclassic01.scn: New files.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* include/pmacros.h: Add PRIxblksize_t, PRIxblkcnt_t.
* configure.ac: Add AC_CHECK_SIZEOF([blksize_t]),
AC_CHECK_SIZEOF([blkcnt_t]).
* Makefile.am, configure.ac: Add psxaio03/.
* psxaio03/Makefile.am, psxaio03/init.c, psxaio03/psxaio03.scn
psxaio03/system.h: New.
* Makefile.am, configure.ac: New test to ensure pthread_cond_wait() and
sleep() (e.g. interruptible blocking and sleeping) are interruptible
by signal.
* psxsignal06/.cvsignore, psxsignal06/Makefile.am, psxsignal06/init.c,
psxsignal06/psxsignal06.doc, psxsignal06/psxsignal06.scn: New files.
* Makefile.am, configure.ac, psx07/init.c, psx07/psx07.scn,
psxhdrs/Makefile.am, psxstack01/init.c: Add pthread_attr_getstack,
pthread_attr_setstack, pthread_attr_getguardsize, and
pthread_attr_setguardsize.
* psxstack02/.cvsignore, psxstack02/Makefile.am, psxstack02/init.c,
psxstack02/psxstack02.doc, psxstack02/psxstack02.scn: New files.
* configure.ac: Check for pthread_attr_{get,set}cputime instead of
pthread_pthread_attr_{get,set}cputime (Typo).
