* psx05/init.c, psx05/psx05.scn: Add test case for process scope now
that the assert has been removed in the source.
* psxstat/psxstat.scn, psxstat/test.c: Disable test for error on wrong
mode bits being set. This behavior was not POSIX compliant and has
been corrected in the filesystem code.
* psx04/task3.c: Declare unions volatile to workaround the H8300
gcc bug.
* Makefile.am, configure.ac: Add mq_send to full queue from ISR case.
* psxmsgq03/.cvsignore, psxmsgq03/Makefile.am, psxmsgq03/init.c,
psxmsgq03/psxmsgq03.doc, psxmsgq03/psxmsgq03.scn, psxmsgq03/system.h: New files.
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Add test case for
NULL attribute pointer on init.
* psxsem01/Makefile.am, psxsem01/init.c, psxsem01/psxsem01.scn,
psxtimer01/psxtimer.c, psxtimer01/system.h, psxtimer02/psxtimer.c:
Improved so coverage is better.
* psx04/init.c: Correct errors introduced by using different variable
for return type when correcting typing warnings.
* Makefile.am, configure.ac: Add new test to provide coverage analysis
of the current implementation of getitimer() and setitimer().
* psxitimer/.cvsignore, psxitimer/Makefile.am, psxitimer/init.c,
psxitimer/psxitimer.scn: New files.
* psxsysconf/init.c, psxsysconf/psxsysconf.scn: Add missing error test
case to improve coverage analysis.
* psx01/init.c, psx01/task.c, psx02/init.c, psx02/task.c, psx03/init.c,
psx04/init.c, psx04/task1.c, psx04/task3.c, psx05/init.c,
psx06/init.c, psx07/init.c, psx08/init.c, psx09/init.c, psx11/task.c,
psx12/init.c, psx13/main.c, psx13/test.c, psxbarrier01/test.c,
psxcancel/init.c, psxcleanup/psxcleanup.c, psxenosys/init.c,
psxmsgq02/init.c, psxtime/main.c, psxtime/test.c,
psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Fix warnings.
* psxhdrs/clock01.c, psxhdrs/clock02.c, psxhdrs/clock03.c,
psxhdrs/clock04.c, psxhdrs/clock05.c, psxhdrs/clock06.c,
psxhdrs/cond01.c, psxhdrs/cond02.c, psxhdrs/cond03.c,
psxhdrs/cond04.c, psxhdrs/cond05.c, psxhdrs/cond06.c,
psxhdrs/cond07.c, psxhdrs/cond08.c, psxhdrs/cond09.c,
psxhdrs/cond10.c, psxhdrs/key01.c, psxhdrs/key02.c, psxhdrs/key03.c,
psxhdrs/key04.c, psxhdrs/mutex01.c, psxhdrs/mutex02.c,
psxhdrs/mutex03.c, psxhdrs/mutex04.c, psxhdrs/mutex05.c,
psxhdrs/mutex06.c, psxhdrs/mutex07.c, psxhdrs/mutex08.c,
psxhdrs/mutex09.c, psxhdrs/mutex10.c, psxhdrs/mutex11.c,
psxhdrs/mutex12.c, psxhdrs/mutex13.c, psxhdrs/mutex14.c,
psxhdrs/mutex15.c, psxhdrs/mutex16.c, psxhdrs/proc01.c,
psxhdrs/proc02.c, psxhdrs/proc03.c, psxhdrs/proc04.c,
psxhdrs/proc05.c, psxhdrs/proc06.c, psxhdrs/proc07.c,
psxhdrs/proc08.c, psxhdrs/proc09.c, psxhdrs/proc10.c,
psxhdrs/proc11.c, psxhdrs/proc12.c, psxhdrs/proc13.c,
psxhdrs/proc14.c, psxhdrs/pthread01.c, psxhdrs/pthread02.c,
psxhdrs/pthread03.c, psxhdrs/pthread04.c, psxhdrs/pthread05.c,
psxhdrs/pthread06.c, psxhdrs/pthread07.c, psxhdrs/pthread08.c,
psxhdrs/pthread09.c, psxhdrs/pthread10.c, psxhdrs/pthread11.c,
psxhdrs/pthread12.c, psxhdrs/pthread13.c, psxhdrs/pthread14.c,
psxhdrs/pthread15.c, psxhdrs/pthread16.c, psxhdrs/pthread17.c,
psxhdrs/pthread18.c, psxhdrs/pthread19.c, psxhdrs/pthread20.c,
psxhdrs/pthread21.c, psxhdrs/pthread22.c, psxhdrs/pthread23.c,
psxhdrs/pthread24.c, psxhdrs/pthread25.c, psxhdrs/pthread26.c,
psxhdrs/pthread27.c, psxhdrs/pthread28.c, psxhdrs/pthread29.c,
psxhdrs/pthread30.c, psxhdrs/pthread31.c, psxhdrs/pthread32.c,
psxhdrs/pthread33.c, psxhdrs/pthread34.c, psxhdrs/pthread35.c,
psxhdrs/pthread36.c, psxhdrs/sched01.c, psxhdrs/sched02.c,
psxhdrs/sched03.c, psxhdrs/sched04.c, psxhdrs/sched05.c,
psxhdrs/sched06.c, psxhdrs/sched07.c, psxhdrs/sched08.c,
psxhdrs/signal01.c, psxhdrs/signal02.c, psxhdrs/signal03.c,
psxhdrs/signal04.c, psxhdrs/signal05.c, psxhdrs/signal06.c,
psxhdrs/signal07.c, psxhdrs/signal08.c, psxhdrs/signal09.c,
psxhdrs/signal10.c, psxhdrs/signal11.c, psxhdrs/signal12.c,
psxhdrs/signal13.c, psxhdrs/signal14.c, psxhdrs/signal15.c,
psxhdrs/signal16.c, psxhdrs/signal17.c, psxhdrs/signal18.c,
psxhdrs/signal19.c, psxhdrs/signal20.c, psxhdrs/signal21.c,
psxhdrs/signal22.c, psxhdrs/signal23.c, psxhdrs/sync01.c,
psxhdrs/sync02.c, psxhdrs/sync03.c, psxhdrs/time01.c,
psxhdrs/time02.c, psxhdrs/time03.c, psxhdrs/time04.c,
psxhdrs/time05.c, psxhdrs/time06.c, psxhdrs/time07.c,
psxhdrs/time08.c, psxhdrs/time09.c, psxhdrs/time10.c,
psxhdrs/time11.c, psxhdrs/time12.c, psxhdrs/time13.c,
psxhdrs/timer01.c, psxhdrs/timer02.c, psxhdrs/timer03.c,
psxhdrs/timer04.c, psxhdrs/timer05.c, psxhdrs/timer06.c,
psxhdrs/timer07.c: Fix warnings.
* psxfile01/test.c: Change from int to size_t.
psx13/Makefile.am, psx14/Makefile.am, psxbarrier01/Makefile.am,
psxcancel/Makefile.am, psxchroot01/Makefile.am,
psxcleanup/Makefile.am, psxenosys/Makefile.am,
psxfatal01/Makefile.am, psxfatal02/Makefile.am,
psxfile01/Makefile.am, psxkey01/Makefile.am,
psxmount/Makefile.am, psxmsgq01/Makefile.am,
psxmsgq02/Makefile.am, psxrdwrv/Makefile.am,
psxreaddir/Makefile.am, psxrwlock01/Makefile.am,
psxsem01/Makefile.am, psxsignal01/Makefile.am,
psxspin01/Makefile.am, psxstat/Makefile.am, psxsysconf/Makefile.am,
psxtime/Makefile.am, psxtimer01/Makefile.am, psxtimer02/Makefile.am,
psxualarm/Makefile.am: Eliminate _exe_/.exe.
* psxmsgq02/init.c, psxmsgq02/psxmsgq02.scn: Open the message queue
with create option so we are sure it will get a control block and
proceed to allocate other memory. Clean up screen output.
* psx05/init.c: Add parameter to call to sched_get_priority_max().
* psx05/init.c, psx07/init.c, psx09/init.c, psx11/init.c, psx12/init.c:
Run all tests successfully with maxixum number of priorities as 16
instead of 256. This was done by temporarily modifying the score
priority.h maximum. This allowed testing of all API code to ensure
that it worked properly with a reduced number of priorities. Most
modifications were to switch from hard-coded maximum to using the API
provided methods to determine maximum number of priority levels.
* psxtimer01/psxtimer.c, psxtimer02/psxtimer.c: Obtain TOD with
clock_gettime() NOT by reaching into the SuperCore.
* psx01/psx01.scn: Bump version to 4.9.99.0
* psxcleanup/psxcleanup.c, psxfatal_support/init.c,
psxfatal_support/system.h: Convert to "bool".
PR 1296/cpukit.
* psxtimer01/psxtimer.c, psxtimer01/psxtimer01.scn: POSIX timers use
incorrect repeat interval. This patch fixes the following problems in
the test.
(1) Adds test for value of it_interval.tv_nsec.
(2) Corrects test for absolute timer in past.
(3) Modifies test to use different initial and repeat periods.
(4) Updates psxtimer01.scn to match results.
PR 1297/cpukit
* psxrwlock01/psxrwlock01.scn, psxrwlock01/test.c: Fix NULL attribute
pointer handling.
* psxsem01/init.c: Spacing.
PR 1293/tests
* psx10/init.c: Make sure we do not let tv_nsec go to -1.
PR 1291/cpukit
* psx05/init.c, psxmsgq01/init.c: As part of addressing timeouts and
POSIX services taking relative instead of absolute time for timeouts,
these tests were updated.
* psxfile01/test.c: truncate on /dev/console now works.
* psxrwlock01/main.c, psxspin01/main.c: Now accounts for extra stack
requested for initialization task.
* psxstat/psxstat.scn, psxstat/test.c: Eliminate patterns that look
like CVS conflict markers.
* psxchroot01/main.c, psxmount/main.c, psxreaddir/main.c: Use
CONFIGURE_APPLICATION_DOES_NOT_NEED_CLOCK_DRIVER where needed.
* psxmsgq02/init.c, psxsignal01/init.c: Corrent end of test messages.
* psxkey01/task.c: Fix warnings.
* psxkey01/.cvsignore, psxmsgq02/.cvsignore: New files.
* Makefile.am, configure.ac, psxmsgq01/Makefile.am, psxmsgq01/init.c:
Added tests for failure path coverages. Consolidated methods used in
multiple places into support routines.
* psxkey01/Makefile.am, psxkey01/init.c, psxkey01/psxkey01.scn,
psxkey01/system.h, psxkey01/task.c, psxmsgq02/Makefile.am,
psxmsgq02/init.c, psxmsgq02/psxmsgq02.scn, psxmsgq02/system.h: New files.
* include/pmacros.h, psx01/init.c, psx01/system.h, psx13/main.c,
psxbarrier01/main.c, psxchroot01/main.c, psxfatal_support/init.c,
psxfile01/main.c, psxfile01/test.c, psxmount/main.c, psxrdwrv/main.c,
psxreaddir/main.c, psxrwlock01/main.c, psxspin01/main.c,
psxstat/main.c, psxtime/main.c: Change TEST_INIT to CONFIGURE_INIT.
Make tmacros.h available to all POSIX tests. Add a clock_settime case
for < 1988.
* Makefile.am, configure.ac: New tests.
* psxfatal01/.cvsignore, psxfatal01/Makefile.am,
psxfatal01/psxfatal01.scn, psxfatal01/testcase.h,
psxfatal02/.cvsignore, psxfatal02/Makefile.am,
psxfatal02/psxfatal02.scn, psxfatal02/testcase.h,
psxfatal_support/init.c, psxfatal_support/system.h: New files.
* Makefile.am, configure.ac: Add psx14 to exercise POSIX API specific
portions of Object Services added to API.
* psx14/.cvsignore, psx14/Makefile.am, psx14/init.c, psx14/psx14.scn,
psx14/system.h: New files.
* psx07/init.c, psx07/system.h: Test cleanup and added testing for
pthread_attr_[get|set]clock.
* psxenosys/init.c, psxenosys/psxenosys.scn: Add test for stub
implementation mprotect().
* psxcleanup/.cvsignore: New file.
* psxcleanup/system.h: New file.
* psxcleanup/Makefile.am, psxcleanup/psxcleanup.c,
psxcleanup/psxcleanup.scn: New files.
* psx01/init.c, psxmsgq01/init.c, psxtimer01/psxtimer.c,
psxtimer01/psxtimer01.scn, psxtimer02/psxtimer.c:
* psxsignal01/.cvsignore, psxualarm/.cvsignore: New files.
* Makefile.am, configure.ac: Added test for ualarm
* psxualarm/Makefile.am, psxualarm/init.c, psxualarm/psxualarm.scn,
psxualarm/system.h: New files.
* Makefile.am, configure.ac: Added posix signal test
* psxsignal01/Makefile.am, psxsignal01/init.c,
psxsignal01/psxsignal01.scn, psxsignal01/system.h,
psxsignal01/task1.c: New files.
* Makefile.am, configure.ac: Add test for sysconf().
* psxsysconf/.cvsignore, psxsysconf/Makefile.am, psxsysconf/init.c,
psxsysconf/psxsysconf.scn, psxsysconf/system.h: New files.
* psx01/init.c, psx01/psx01.scn: Add more test cases for
sched_rr_get_interval() and sched_get_priority_max().
* psxenosys/init.c: Fix typo.
* Makefile.am, configure.ac: Rename psxtimer to psxtimer01 to indicate
addition of second POSIX Timer test. Add initial version of
psxtimer02 to cover some conditions missed in psxtimer01. More cases
left to add.
* psxtimer01/.cvsignore, psxtimer01/Makefile.am, psxtimer01/psxtimer.c,
psxtimer01/psxtimer01.scn, psxtimer01/system.h,
psxtimer02/.cvsignore, psxtimer02/Makefile.am, psxtimer02/psxtimer.c,
psxtimer02/psxtimer02.scn, psxtimer02/system.h: New files.
* psxtimer/.cvsignore, psxtimer/Makefile.am, psxtimer/psxtimer.c,
psxtimer/psxtimer.scn, psxtimer/system.h: Removed.
* psx01/init.c, psx01/psx01.scn: Add usleep() test.
* Makefile.am, configure.ac: New test to cover all RTEMS POSIX
functions that return ENOSYS.
* psxenosys/.cvsignore, psxenosys/Makefile.am, psxenosys/init.c,
psxenosys/psxenosys.scn, psxenosys/system.h: New files.
