* mp04/task1.c: Include "tmacros.h".
Use PRIxrtems_task_priority to print rtems_task_prioritys.
Use PRI*32 to print uint32_ts.
* mp05/asr.c: Include "tmacros.h".
Use PRIxrtems_signal_set to print rtems_signal_set's.
Use PRIxrtems_signal_set to print rtems_signal_sets.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp05/task1.c, mp06/task1.c,
mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c,
mp09/task1.c, mp10/init.c, mp12/init.c, mp13/init.c, mp13/task1.c,
mp13/task2.c, mp14/evtask1.c, mp14/init.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* mp01/task1.c, mp01/node1/mp01-node1.scn, mp01/node2/mp01-node2.scn:
Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD,
..) to rtems_clock_get_tod(..).
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am:
Eliminate _exe_/.exe.
* mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c,
mp14/msgtask1.c: Correct types to eliminate warnings.
* mp14/delay.c, mp14/evtmtask.c: Pass task Id to TSR.
* mp14/system.h: Semaphore_task_id and Semaphore_task_name arrays
were one entry too short.
* mp03/delay.c, mp06/task1.c, mp06/node2/mp06-node2.scn, mp07/task1.c:
Updating and fixing while running them on psim.
* mp05/system.h, mp05/task1.c, mp06/system.h, mp06/task1.c,
mp07/system.h, mp07/task1.c, mp14/evtask1.c, mp14/evtmtask.c,
mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c,
mp14/system.h: Convert to bool type.
* mp01/init.c, mp02/init.c, mp03/init.c, mp04/init.c, mp05/init.c,
mp06/init.c, mp07/init.c, mp08/init.c, mp09/init.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c: Change TEST_INIT
to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a
clock_settime case for < 1988.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
* mp02/task1.c, mp14/delay.c: Add new Object Services collection. This
changed the name of a few previously public but undocumented services
and added a some new services.
* mp12/node2/mp12-node2.scn: Redo screen to not have cvs conflict
marker.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Eliminate scndir,
docdir. Use rtems_testsdir instead.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
Convert to using *_PROGRAMS.
* mp01/node2/Makefile.am: Rework.
* mp02/node1/Makefile.am: Rework.
* mp02/node2/Makefile.am: Rework.
* mp03/node1/Makefile.am: Rework.
* mp03/node2/Makefile.am: Rework.
* mp04/node1/Makefile.am: Rework.
* mp04/node2/Makefile.am: Rework.
* mp05/node1/Makefile.am: Rework.
* mp05/node2/Makefile.am: Rework.
* mp06/node1/Makefile.am: Rework.
* mp06/node2/Makefile.am: Rework.
* mp07/node1/Makefile.am: Rework.
* mp07/node2/Makefile.am: Rework.
* mp08/node1/Makefile.am: Rework.
* mp08/node2/Makefile.am: Rework.
* mp09/node1/Makefile.am: Rework.
* mp09/node2/Makefile.am: Rework.
* mp10/node1/Makefile.am: Rework.
* mp10/node2/Makefile.am: Rework.
* mp11/node1/Makefile.am: Rework.
* mp11/node2/Makefile.am: Rework.
* mp12/node1/Makefile.am: Rework.
* mp12/node2/Makefile.am: Rework.
* mp13/node1/Makefile.am: Rework.
* mp13/node2/Makefile.am: Rework.
* mp14/node1/Makefile.am: Rework.
* mp14/node2/Makefile.am: Rework.
* mptests.am: Remove.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Expand mptests.am.
* mp03/node1/mp03-node1.doc, mp03/node1/mp03-node1.scn,
mp03/node2/mp03-node2.scn, mp03/node2/mp03-node2.doc,
mp10/node1/mp10-node1.doc, mp10/node1/mp10-node1.scn,
mp10/node2/mp10-node2.scn, mp10/node2/mp10-node2.doc,
mp11/node1/mp11-node1.doc, mp11/node1/mp11-node1.scn,
mp11/node2/mp11-node2.doc, mp11/node2/mp11-node2.scn,
mp08/node1/mp08-node1.scn, mp08/node1/mp08-node1.doc,
mp08/node2/mp08-node2.scn, mp08/node2/mp08-node2.doc,
mp01/node1/mp01-node1.doc, mp01/node1/mp01-node1.scn,
mp01/node2/mp01-node2.doc, mp01/node2/mp01-node2.scn,
mp12/node1/mp12-node1.doc, mp12/node1/mp12-node1.scn,
mp12/node2/mp12-node2.doc, mp12/node2/mp12-node2.scn,
mp14/node1/mp14-node1.scn, mp14/node1/mp14-node1.doc,
mp14/node2/mp14-node2.scn, mp14/node2/mp14-node2.doc,
mp02/node1/mp02-node1.scn, mp02/node1/mp02-node1.doc,
mp02/node2/mp02-node2.scn, mp02/node2/mp02-node2.doc,
mp13/node1/mp13-node1.scn, mp13/node1/mp13-node1.doc,
mp13/node2/mp13-node2.scn, mp13/node2/mp13-node2.doc,
mp05/node1/mp05-node1.doc, mp05/node1/mp05-node1.scn,
mp05/node2/mp05-node2.scn, mp05/node2/mp05-node2.doc,
mp04/node1/mp04-node1.scn, mp04/node1/mp04-node1.doc,
mp04/node2/mp04-node2.scn, mp04/node2/mp04-node2.doc,
mp06/node1/mp06-node1.doc, mp06/node1/mp06-node1.scn,
mp06/node2/mp06-node2.scn, mp06/node2/mp06-node2.doc,
mp09/node1/mp09-node1.scn, mp09/node1/mp09-node1.doc,
mp09/node2/mp09-node2.scn, mp09/node2/mp09-node2.doc,
mp07/node1/mp07-node1.doc, mp07/node1/mp07-node1.scn,
mp07/node2/mp07-node2.doc, mp07/node2/mp07-node2.scn: New.
* mp03/node1/mp03.doc, mp03/node1/mp03.scn, mp03/node2/mp03.scn,
mp03/node2/mp03.doc, mp10/node1/mp10.doc, mp10/node1/mp10.scn,
mp10/node2/mp10.scn, mp10/node2/mp10.doc, mp11/node1/mp11.doc,
mp11/node1/mp11.scn, mp11/node2/mp11.doc, mp11/node2/mp11.scn,
mp08/node1/mp08.scn, mp08/node1/mp08.doc, mp08/node2/mp08.scn,
mp08/node2/mp08.doc, mp01/node1/mp01.doc, mp01/node1/mp01.scn,
mp01/node2/mp01.doc, mp01/node2/mp01.scn, mp12/node1/mp12.doc,
mp12/node1/mp12.scn, mp12/node2/mp12.doc, mp12/node2/mp12.scn,
mp14/node1/mp14.scn, mp14/node1/mp14.doc, mp14/node2/mp14.scn,
mp14/node2/mp14.doc, mp02/node1/mp02.scn, mp02/node1/mp02.doc,
mp02/node2/mp02.scn, mp02/node2/mp02.doc, mp13/node1/mp13.scn,
mp13/node1/mp13.doc, mp13/node2/mp13.scn, mp13/node2/mp13.doc,
mp05/node1/mp05.doc, mp05/node1/mp05.scn, mp05/node2/mp05.scn,
mp05/node2/mp05.doc, mp04/node1/mp04.scn, mp04/node1/mp04.doc,
mp04/node2/mp04.scn, mp04/node2/mp04.doc, mp06/node1/mp06.doc,
mp06/node1/mp06.scn, mp06/node2/mp06.scn, mp06/node2/mp06.doc,
mp09/node1/mp09.scn, mp09/node1/mp09.doc, mp09/node2/mp09.scn,
mp09/node2/mp09.doc, mp07/node1/mp07.doc, mp07/node1/mp07.scn,
mp07/node2/mp07.doc, mp07/node2/mp07.scn:
Removed (Renamed to *-node<N>.*).
AM_CPPFLAGS += -I..../support/include.
* configure.ac: Apply RTEMS_CHECK_CPUOPTS.
* mptests.am: Set project_bspdir=$(PROJECT_ROOT)
mp02/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am:
Misc bugfixes.
* mptests.am: Remove LIB_VARIANT.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove SRC,
PRINT_SRC.
