path: root/testsuites/mptests (follow)
* testsuite: Add a common test configuration. Fix configure.ac and Makefile.am ↵Chris Johns2017-04-041-3/+15
| | | | | | | | | | | | | | | | | | | | | | | | | | errors. - Add a top level test configuration file for test states that are common to all BSPs. This saves adding a test configuration (tcfg) file for every BSP. - Add the test states 'user-input' and 'benchmark'. This lets 'rtems-test' stop the test rather than waiting for a timeout or letting a benchmark run without the user asking for it to run. - Implement rtems-test-check in Python to make it faster. The shell script had grown to a point it was noticably slowing the build down. - Fix the configure.ac and Makefile.am files for a number of the test directories. The files are difficiult to keep in sync with the number of tests and mistakes can happen such as tests being left out of the build. The test fsrofs01 is an example. Also a there was a mix of SUBDIRS and _SUBDIRS being used and only _SUBDIRS should be used. - Fix the test fsrofs01 so it compiles. Closes #2963.
* mptests/mp03/task1.c: Make method static to fix warningJoel Sherrill2016-06-161-1/+1
* mptests: Fix message queue configurationSebastian Huber2016-03-295-0/+10
* mptests/*/*.c: Fix warningsJoel Sherrill2016-03-244-4/+4
* api: Remove deprecated NotepadsAun-Ali Zaidi2015-12-2412-352/+1
| | | | | | | | | | | | | | | | | | | | | | | Notepads where a feature of RTEMS' tasks that simply functioned in the same way as POSIX keys or threaded local storage (TLS). They were introduced well before per task variables, which are also deprecated, and were barely used in favor of their POSIX alternatives. In addition to their scarce usage, Notepads took up unnecessary memory. For each task: - 16 32-bit integers were allocated. - A total of 64 bytes per task per thread. This is especially critical in low memory and safety-critical applications. They are also defined as uint32_t, and therefore are not guaranteed to hold a pointer. Lastly, they are not portable solutions for SMP and uniprocessor systems, like POSIX keys and TLS. updates #2493.
* cpukit: deprecate notepadsGedare Bloom2015-03-101-0/+2
| | | | | | | | | | | | | | | Deprecate Classic API Notepads. Mark task_set/get_note() with the deprecated attribute, and also mark the notepads field. Replace disable with enable option for notepads in confdefs.h, and make notepads disabled by default. The previous option CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and will emit a compile-time warning. A new option CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn on notepads, but it also will emit a compile-time warning to indicate that notepads are deprecated. Closes #2265
* Update bug report URLSebastian Huber2014-12-051-1/+1
* Eliminate use of /*PAGE and clean up formattingJoel Sherrill2014-10-092-35/+5
* testsuite: Add a per BSP test check for tests not to build.Chris Johns2014-05-051-2/+2
| | | | | | | | Provide a file per BSP to list tests that do not build for a BSP. This change removes the BSP_SMALL_MEMORY hack from the code. That hack was a mistake. Provide configuration files for each BSP with tests that cannot build.
* Change all references of rtems.com to rtems.org.Chris Johns2014-03-2181-81/+81
* RTEMS: Delete ChangeLog files.Gedare Bloom2013-03-081-856/+0
| | | | | | | | | This commit deletes all RTEMS ChangeLog files. These files have been abandoned since converting to git version control. The historical data may be recovered by checking out any commit before this one. Most of the contents of these ChangeLog files can also be found in the git log. Two external ChangeLog files, ChangeLog.slac and ChangeLog.zlib, remain.
* Revert "Add config.h.in."Gedare Bloom2012-08-061-19/+0
| | | | This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
* Require automake-1.12.2.Ralf Corsépius2012-07-191-1/+1
* Require autoconf-2.69.Ralf Corsépius2012-07-191-1/+1
* Add config.h.in.Ralf Corsépius2012-05-241-0/+19
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-11126-368/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-0744-0/+174
* mptests - Makefile.am did not set LINK_OBJSJoel Sherrill2012-05-0428-28/+28
| | | | | | | | LINK_OBJS = instead of LINK_OBJS = $(mp01_node1_OBJECTS)
* Remove CVS-Ids.Ralf Corsépius2012-05-0444-174/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-0143-99/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-0829-140/+47
| | | | | | | | | | | | | | | | | | | PR 1589/build * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove obsolete optional manager capability.
* Add config.h.inRalf Corsepius2011-03-011-0/+1
* 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-222-1/+6
| | | | * configure.ac: Add AC_CONFIG_HEADER(config.h).
* 2011-02-22 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-221-0/+12
| | | | | | | | | | | | * mp01/init.c, mp01/task1.c, mp02/init.c, mp02/task1.c, mp03/delay.c, mp03/init.c, mp03/task1.c, mp04/init.c, mp04/task1.c, mp05/asr.c, mp05/init.c, mp05/task1.c, mp06/init.c, mp06/task1.c, mp07/init.c, mp07/task1.c, mp08/init.c, mp08/task1.c, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/init.c, mp10/task1.c, mp10/task2.c, mp10/task3.c, mp11/init.c, mp12/init.c, mp13/init.c, mp13/task1.c, mp13/task2.c, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c: Add HAVE_CONFIG_H.
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-2239-0/+156
* 2011-02-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2011-02-022-2/+6
| | | | * configure.ac: Require autoconf-2.68, automake-1.11.1.
* 2009-10-30 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-10-304-7/+13
| | | | | | * mp03/task1.c, mp10/init.c, mp13/task1.c: Use rtems_clock_get_ticks_per_second() instead of the obsoleted TICKS_PER_SECOND.
* 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-301-0/+5
| | | | | | | | * mp01/init.c, mp02/init.c, mp02/task1.c, mp03/init.c, mp04/init.c, mp05/init.c, mp06/init.c, mp07/init.c, mp08/init.c, mp09/init.c, mp09/task1.c, mp10/init.c, mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c: Use PRI*32 to print uint32_ts.
* Use PRI*32 to print uint32_ts.Ralf Corsepius2009-10-3016-18/+18
* 2009-10-30 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-301-0/+3
| | | | | | * mp04/task1.c: Include "tmacros.h". Use PRIxrtems_task_priority to print rtems_task_prioritys. Use PRI*32 to print uint32_ts.
* Include "tmacros.h".Ralf Corsepius2009-10-301-1/+2
| | | | | * mp05/asr.c: Include "tmacros.h". Use PRIxrtems_signal_set to print rtems_signal_set's.
| | | | Use PRIxrtems_signal_set to print rtems_signal_sets.
* 2009-10-20 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-10-202-1/+5
| | | | * configure.ac: Don't add -ansi -fasm to CFLAGS.
* 2009-08-12 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-1218-46/+55
| | | | | | | | | * mp01/task1.c, mp02/task1.c, mp03/task1.c, mp05/task1.c, mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/init.c, mp12/init.c, mp13/init.c, mp13/task1.c, mp13/task2.c, mp14/evtask1.c, mp14/init.c: Eliminate test routines TICKS_PER_SECOND and get_ticks_per_second() in favor of new rtems_clock_get_ticks_per_second().
* 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-104-18/+24
| | | | | | * mp01/task1.c, mp01/node1/mp01-node1.scn, mp01/node2/mp01-node2.scn: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* 2009-04-03 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2009-04-031-0/+18
| | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Eliminate _exe_/.exe.
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-0328-196/+196
* 2008-09-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-086-15/+20
| | | | | * mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c, mp14/msgtask1.c: Correct types to eliminate warnings.
* 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-054-12/+20
| | | | | | * mp14/delay.c, mp14/evtmtask.c: Pass task Id to TSR. * mp14/system.h: Semaphore_task_id and Semaphore_task_name arrays were one entry too short.
* 2008-09-05 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-09-055-4/+20
| | | | | * mp03/delay.c, mp06/task1.c, mp06/node2/mp06-node2.scn, mp07/task1.c: Updating and fixing while running them on psim.
* 2008-09-03 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-09-0314-33/+40
| | | | | | | * mp05/system.h, mp05/task1.c, mp06/system.h, mp06/task1.c, mp07/system.h, mp07/task1.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h: Convert to bool type.
* 2008-01-31 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-02-0115-14/+22
| | | | | | | | * mp01/init.c, mp02/init.c, mp03/init.c, mp04/init.c, mp05/init.c, mp06/init.c, mp07/init.c, mp08/init.c, mp09/init.c, mp10/init.c, mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c: Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a clock_settime case for < 1988.
* 2008-01-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2008-01-3029-28/+45
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
* 2008-01-29 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2008-01-293-18/+18
| | | | | | * mp02/task1.c, mp14/delay.c: Add new Object Services collection. This changed the name of a few previously public but undocumented services and added a some new services.
* 2007-03-28 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2007-03-282-1/+6
| | | | | * mp12/node2/mp12-node2.scn: Redo screen to not have cvs conflict marker.
* 2006-12-02 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-12-022-1/+5
| | | | * configure.ac: New BUG-REPORT address.
* 2006-10-17 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-10-172-2/+6
| | | | * configure.ac: Require autoconf-2.60. Require automake-1.10.
* Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius2006-07-1128-112/+56
* 2006-07-11 Ralf Corsépius <ralf.corsepius@rtems.org>Ralf Corsepius2006-07-111-0/+18
| | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Eliminate scndir, docdir. Use rtems_testsdir instead.
