<jsg@coulomb.eng.ohio-state.edu> of the rest of the 68000-ish support
for interrupt handling and bfffo support, the two BSPs he submitted
(efi68k and efi332), and SGI Irix 5.3 host support.
like signal dispatching.
correct Information block.
IDLE task priority changed from 0 to 255 during initialization.
