* mp01/Makefile.am: Reformat.
* mp01/node1/Makefile.am: Remove all-local: $(ARCH).
* mp01/node2/Makefile.am: Remove all-local: $(ARCH).
* mp02/Makefile.am: Reformat.
* mp02/node1/Makefile.am: Remove all-local: $(ARCH).
* mp02/node2/Makefile.am: Remove all-local: $(ARCH).
* mp03/Makefile.am: Reformat.
* mp03/node1/Makefile.am: Remove all-local: $(ARCH).
* mp03/node2/Makefile.am: Remove all-local: $(ARCH).
* mp04/Makefile.am: Reformat.
* mp04/node1/Makefile.am: Remove all-local: $(ARCH).
* mp04/node2/Makefile.am: Remove all-local: $(ARCH).
* mp05/Makefile.am: Reformat.
* mp05/node1/Makefile.am: Remove all-local: $(ARCH).
* mp05/node2/Makefile.am: Remove all-local: $(ARCH).
* mp06/Makefile.am: Reformat.
* mp06/node1/Makefile.am: Remove all-local: $(ARCH).
* mp06/node2/Makefile.am: Remove all-local: $(ARCH).
* mp07/Makefile.am: Reformat.
* mp07/node1/Makefile.am: Remove all-local: $(ARCH).
* mp07/node2/Makefile.am: Remove all-local: $(ARCH).
* mp08/Makefile.am: Reformat.
* mp08/node1/Makefile.am: Remove all-local: $(ARCH).
* mp08/node2/Makefile.am: Remove all-local: $(ARCH).
* mp09/Makefile.am: Reformat.
* mp09/node1/Makefile.am: Remove all-local: $(ARCH).
* mp09/node2/Makefile.am: Remove all-local: $(ARCH).
* mp10/Makefile.am: Reformat.
* mp10/node1/Makefile.am: Remove all-local: $(ARCH).
* mp10/node2/Makefile.am: Remove all-local: $(ARCH).
* mp11/Makefile.am: Reformat.
* mp11/node1/Makefile.am: Remove all-local: $(ARCH).
* mp11/node2/Makefile.am: Remove all-local: $(ARCH).
* mp12/Makefile.am: Reformat.
* mp12/node1/Makefile.am: Remove all-local: $(ARCH).
* mp12/node2/Makefile.am: Remove all-local: $(ARCH).
* mp13/Makefile.am: Reformat.
* mp13/node1/Makefile.am: Remove all-local: $(ARCH).
* mp13/node2/Makefile.am: Remove all-local: $(ARCH).
* mp14/Makefile.am: Reformat.
* mp14/node1/Makefile.am: Remove all-local: $(ARCH).
* mp14/node2/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* mp01/init.c, mp01/system.h, mp01/task1.c, mp01/node1/mp01.doc,
mp01/node2/mp01.doc, mp02/init.c, mp02/system.h, mp02/task1.c,
mp02/node1/mp02.doc, mp02/node2/mp02.doc, mp03/delay.c, mp03/init.c,
mp03/system.h, mp03/task1.c, mp03/node1/mp03.doc,
mp03/node2/mp03.doc, mp04/init.c, mp04/system.h, mp04/task1.c,
mp04/node1/mp04.doc, mp04/node2/mp04.doc, mp05/asr.c, mp05/init.c,
mp05/system.h, mp05/task1.c, mp05/node1/mp05.doc,
mp05/node2/mp05.doc, mp06/init.c, mp06/system.h, mp06/task1.c,
mp06/node1/mp06.doc, mp06/node2/mp06.doc, mp07/init.c, mp07/system.h,
mp07/task1.c, mp07/node1/mp07.doc, mp07/node2/mp07.doc, mp08/init.c,
mp08/system.h, mp08/task1.c, mp08/node1/mp08.doc,
mp08/node2/mp08.doc, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c,
mp09/system.h, mp09/task1.c, mp09/node1/mp09.doc,
mp09/node2/mp09.doc, mp10/init.c, mp10/system.h, mp10/task1.c,
mp10/task2.c, mp10/task3.c, mp10/node1/mp10.doc, mp10/node2/mp10.doc,
mp11/init.c, mp11/system.h, mp11/node1/mp11.doc, mp11/node2/mp11.doc,
mp12/init.c, mp12/system.h, mp12/node1/mp12.doc, mp12/node2/mp12.doc,
mp13/init.c, mp13/system.h, mp13/task1.c, mp13/task2.c,
mp13/node1/mp13.doc, mp13/node2/mp13.doc, mp14/delay.c,
mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c,
mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h,
mp14/node1/mp14.doc, mp14/node2/mp14.doc: URL for license changed.
mp01/Makefile.am: Reflect having moved automake.
mp01/node1/Makefile.am: Reflect having moved automake.
mp01/node2/Makefile.am: Reflect having moved automake.
mp02/Makefile.am: Reflect having moved automake.
mp02/node1/Makefile.am: Reflect having moved automake.
mp02/node2/Makefile.am: Reflect having moved automake.
mp03/Makefile.am: Reflect having moved automake.
mp03/node1/Makefile.am: Reflect having moved automake.
mp03/node2/Makefile.am: Reflect having moved automake.
mp04/Makefile.am: Reflect having moved automake.
mp04/node1/Makefile.am: Reflect having moved automake.
mp04/node2/Makefile.am: Reflect having moved automake.
mp05/Makefile.am: Reflect having moved automake.
mp05/node1/Makefile.am: Reflect having moved automake.
mp05/node2/Makefile.am: Reflect having moved automake.
mp06/Makefile.am: Reflect having moved automake.
mp06/node1/Makefile.am: Reflect having moved automake.
mp06/node2/Makefile.am: Reflect having moved automake.
mp07/Makefile.am: Reflect having moved automake.
mp07/node1/Makefile.am: Reflect having moved automake.
mp07/node2/Makefile.am: Reflect having moved automake.
mp08/Makefile.am: Reflect having moved automake.
mp08/node1/Makefile.am: Reflect having moved automake.
mp08/node2/Makefile.am: Reflect having moved automake.
mp09/Makefile.am: Reflect having moved automake.
mp09/node1/Makefile.am: Reflect having moved automake.
mp09/node2/Makefile.am: Reflect having moved automake.
mp10/Makefile.am: Reflect having moved automake.
mp10/node1/Makefile.am: Reflect having moved automake.
mp10/node2/Makefile.am: Reflect having moved automake.
mp11/Makefile.am: Reflect having moved automake.
mp11/node1/Makefile.am: Reflect having moved automake.
mp11/node2/Makefile.am: Reflect having moved automake.
mp12/Makefile.am: Reflect having moved automake.
mp12/node1/Makefile.am: Reflect having moved automake.
mp12/node2/Makefile.am: Reflect having moved automake.
mp13/Makefile.am: Reflect having moved automake.
mp13/node1/Makefile.am: Reflect having moved automake.
mp13/node2/Makefile.am: Reflect having moved automake.
mp14/Makefile.am: Reflect having moved automake.
mp14/node1/Makefile.am: Reflect having moved automake.
mp14/node2/Makefile.am: Reflect having moved automake.
* configure.ac: Remove CC_CFLAGS_DEBUG_V.
CC_CFLAGS_DEFAULT (obsolete).
* configure.ac: Remove CC_CFLAGS_PROFILE_V.
Remove CC_LDFLAGS_PROFILE_V.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp04/task1.c, mp05/task1.c,
mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/task1.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp13/task2.c: Modified.
* mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
Tracked as PR72 but related to the object id problem (PR36)
reported by Todor.Todorov@barco.com.
* mp03/delay.c: Dispatch disable level is actually 1 not 0.
* mp13/system.h: Configure enough tasks (CONFIGURE_MAXIMUM_TASKS=3).
* mp14/delay.c: Dispatch disable level may be arbitrarily > 0.
* configure.in: Remove.
* mptests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mptests.am: Remove DEFS.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
<corsepiu@faw.uni-ulm.de> which converted fiels to automake.
Addtional major bugs:
more accurate.
