Updates #3053.
These files had no file header, copyright, or license. Based on git
history, added appropriate copyrights and licenses.
Updates #3053.
Close #3250.
Close #4081.
Update #3841.
Update #3818.
Update #3818.
Update #3382
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
call to printk.
Updates #3170.
for details.
LINK_OBJS =
instead of
LINK_OBJS = $(mp01_node1_OBJECTS)
PR 1589/build
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove obsolete
optional manager capability.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp05/task1.c, mp06/task1.c,
mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c,
mp09/task1.c, mp10/init.c, mp12/init.c, mp13/init.c, mp13/task1.c,
mp13/task2.c, mp14/evtask1.c, mp14/init.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* mp01/init.c, mp02/init.c, mp03/init.c, mp04/init.c, mp05/init.c,
mp06/init.c, mp07/init.c, mp08/init.c, mp09/init.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c: Change TEST_INIT
to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a
clock_settime case for < 1988.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
* mp12/node2/mp12-node2.scn: Redo screen to not have cvs conflict
marker.
Remove $(LIB_VARIANT).
* mp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp02/task1.c, mp03/system.h, mp03/task1.c, mp04/task1.c,
mp05/system.h, mp06/task1.c, mp07/task1.c, mp08/task1.c,
mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/task1.c,
mp11/init.c, mp12/init.c, mp13/task1.c, mp14/evtask1.c,
mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c,
mp14/smtask1.c, mp14/system.h: Convert to using c99 fixed size
types.
* mp01/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* mp01/node2/Makefile.am: Ditto.
* mp02/node1/Makefile.am: Ditto.
* mp02/node2/Makefile.am: Ditto.
* mp03/node1/Makefile.am: Ditto.
* mp03/node2/Makefile.am: Ditto.
* mp04/node1/Makefile.am: Ditto.
* mp04/node2/Makefile.am: Ditto.
* mp05/node1/Makefile.am: Ditto.
* mp05/node2/Makefile.am: Ditto.
* mp06/node1/Makefile.am: Ditto.
* mp06/node2/Makefile.am: Ditto.
* mp07/node1/Makefile.am: Ditto.
* mp07/node2/Makefile.am: Ditto.
* mp08/node1/Makefile.am: Ditto.
* mp08/node2/Makefile.am: Ditto.
* mp09/node1/Makefile.am: Ditto.
* mp09/node2/Makefile.am: Ditto.
* mp10/node1/Makefile.am: Ditto.
* mp10/node2/Makefile.am: Ditto.
* mp11/node1/Makefile.am: Ditto.
* mp11/node2/Makefile.am: Ditto.
* mp12/node1/Makefile.am: Ditto.
* mp12/node2/Makefile.am: Ditto.
* mp13/node1/Makefile.am: Ditto.
* mp13/node2/Makefile.am: Ditto.
* mp14/node1/Makefile.am: Ditto.
* mp14/node2/Makefile.am: Ditto.
* mptests.am: Add dirstamp support.
* mptests/mp01/node1/Makefile.am: Eliminate VPATH.
* mptests/mp01/node2/Makefile.am: Eliminate VPATH.
* mptests/mp02/node1/Makefile.am: Eliminate VPATH.
* mptests/mp02/node2/Makefile.am: Eliminate VPATH.
* mptests/mp03/node1/Makefile.am: Eliminate VPATH.
* mptests/mp03/node2/Makefile.am: Eliminate VPATH.
* mptests/mp04/node1/Makefile.am: Eliminate VPATH.
* mptests/mp04/node2/Makefile.am: Eliminate VPATH.
* mptests/mp05/node1/Makefile.am: Eliminate VPATH.
* mptests/mp05/node2/Makefile.am: Eliminate VPATH.
* mptests/mp06/node1/Makefile.am: Eliminate VPATH.
* mptests/mp06/node2/Makefile.am: Eliminate VPATH.
* mptests/mp07/node1/Makefile.am: Eliminate VPATH.
* mptests/mp07/node2/Makefile.am: Eliminate VPATH.
* mptests/mp08/node1/Makefile.am: Eliminate VPATH.
* mptests/mp08/node2/Makefile.am: Eliminate VPATH.
* mptests/mp09/node1/Makefile.am: Eliminate VPATH.
* mptests/mp09/node2/Makefile.am: Eliminate VPATH.
* mptests/mp10/node1/Makefile.am: Eliminate VPATH.
* mptests/mp10/node2/Makefile.am: Eliminate VPATH.
* mptests/mp11/node1/Makefile.am: Eliminate VPATH.
* mptests/mp11/node2/Makefile.am: Eliminate VPATH.
* mptests/mp12/node1/Makefile.am: Eliminate VPATH.
* mptests/mp12/node2/Makefile.am: Eliminate VPATH.
* mptests/mp13/node1/Makefile.am: Eliminate VPATH.
* mptests/mp13/node2/Makefile.am: Eliminate VPATH.
* mptests/mp14/node1/Makefile.am: Eliminate VPATH.
* mptests/mp14/node2/Makefile.am: Eliminate VPATH.
