mp01/Makefile.am: Reflect having moved automake.
mp01/node1/Makefile.am: Reflect having moved automake.
mp01/node2/Makefile.am: Reflect having moved automake.
mp02/Makefile.am: Reflect having moved automake.
mp02/node1/Makefile.am: Reflect having moved automake.
mp02/node2/Makefile.am: Reflect having moved automake.
mp03/Makefile.am: Reflect having moved automake.
mp03/node1/Makefile.am: Reflect having moved automake.
mp03/node2/Makefile.am: Reflect having moved automake.
mp04/Makefile.am: Reflect having moved automake.
mp04/node1/Makefile.am: Reflect having moved automake.
mp04/node2/Makefile.am: Reflect having moved automake.
mp05/Makefile.am: Reflect having moved automake.
mp05/node1/Makefile.am: Reflect having moved automake.
mp05/node2/Makefile.am: Reflect having moved automake.
mp06/Makefile.am: Reflect having moved automake.
mp06/node1/Makefile.am: Reflect having moved automake.
mp06/node2/Makefile.am: Reflect having moved automake.
mp07/Makefile.am: Reflect having moved automake.
mp07/node1/Makefile.am: Reflect having moved automake.
mp07/node2/Makefile.am: Reflect having moved automake.
mp08/Makefile.am: Reflect having moved automake.
mp08/node1/Makefile.am: Reflect having moved automake.
mp08/node2/Makefile.am: Reflect having moved automake.
mp09/Makefile.am: Reflect having moved automake.
mp09/node1/Makefile.am: Reflect having moved automake.
mp09/node2/Makefile.am: Reflect having moved automake.
mp10/Makefile.am: Reflect having moved automake.
mp10/node1/Makefile.am: Reflect having moved automake.
mp10/node2/Makefile.am: Reflect having moved automake.
mp11/Makefile.am: Reflect having moved automake.
mp11/node1/Makefile.am: Reflect having moved automake.
mp11/node2/Makefile.am: Reflect having moved automake.
mp12/Makefile.am: Reflect having moved automake.
mp12/node1/Makefile.am: Reflect having moved automake.
mp12/node2/Makefile.am: Reflect having moved automake.
mp13/Makefile.am: Reflect having moved automake.
mp13/node1/Makefile.am: Reflect having moved automake.
mp13/node2/Makefile.am: Reflect having moved automake.
mp14/Makefile.am: Reflect having moved automake.
mp14/node1/Makefile.am: Reflect having moved automake.
mp14/node2/Makefile.am: Reflect having moved automake.
* mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp04/task1.c, mp05/task1.c,
mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/task1.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp13/task2.c: Modified.
* mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
like signal dispatching.
