path: root/testsuites/mptests/mp12/system.h (follow)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+4
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* changes remerged after lost in disk crash -- recovered from snapshot, ↵Joel Sherrill1995-12-201-0/+53
| | | | partially recovered working tree, etc
* changes remerged after disk crash -- history lostJoel Sherrill1995-12-191-53/+0
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-111-5/+29
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-111-0/+30
