path: root/testsuites/mptests/mp12/node1 (unfollow)
2018-04-10testsuite/mptests: Merged nested Makefile.am files into one Makefile.amChris Johns3-76/+0
This change is part of the testsuite Makefile.am reorganization. Update #3382
2014-03-21Change all references of rtems.com to rtems.org.Chris Johns1-1/+1
2012-05-11Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2-7/+0
Script does what is expected and tries to do it as smartly as possible. + remove occurrences of two blank comment lines next to each other after Id string line removed. + remove entire comment blocks which only exited to contain CVS Ids + If the processing left a blank line at the top of a file, it was removed.
2012-05-07Revert: Remove CVS IdsJoel Sherrill1-0/+4
See http://www.rtems.org/pipermail/rtems-devel/2012-May/001006.html for details.
2012-05-04mptests - Makefile.am did not set LINK_OBJSJoel Sherrill1-1/+1
LINK_OBJS = instead of LINK_OBJS = $(mp01_node1_OBJECTS)
2012-05-04Remove CVS-Ids.Ralf Corsépius1-4/+0
2012-02-01Remove all .cvsignore files.Joel Sherrill1-2/+0
2011-12-082011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill1-5/+1
PR 1589/build * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove obsolete optional manager capability.
2009-04-03Eliminate _exe_/.exe.Ralf Corsepius1-7/+7
2008-01-302008-01-30 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill1-1/+1
* mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
2006-07-11Eliminate scndir, docdir. Use rtems_testsdir instead.Ralf Corsepius1-4/+2
2005-11-13Convert to using *_PROGRAMS.Ralf Corsepius1-12/+9
2005-11-11Rework.Ralf Corsepius1-34/+8
2005-11-11Cosmetics.Ralf Corsepius1-3/+0
2005-11-11Various cleanups.Ralf Corsepius1-4/+3
2005-11-11Hard-code node number.Ralf Corsepius1-11/+10
2005-11-11Fix typo in previous patch.Ralf Corsepius1-2/+2
2005-11-11Eliminate TEST.Ralf Corsepius1-7/+6
2005-11-11Expand mptests.am.Ralf Corsepius1-1/+22
2005-11-10Eliminate DOCTYPES.Ralf Corsepius1-2/+1
2005-11-10Reflect changes to TEST variable contents.Ralf Corsepius1-2/+2
2005-11-10New.Ralf Corsepius2-0/+57
2005-11-10Removed (Renamed to *-node<N>.*).Ralf Corsepius2-57/+0
2005-11-09AM_CPPFLAGS += -I..../support/include.Ralf Corsepius1-0/+2
2005-11-07Misc. bugfixes.Ralf Corsepius1-1/+1
2005-11-07Remove SRC, PRINT_SRC.Ralf Corsepius1-2/+0
2005-11-07Switch back to include compile.am instead of amcompile.amRalf Corsepius1-1/+1
2005-11-07Partial conversion to automake.Ralf Corsepius1-10/+5
2005-01-062005-01-06 Ralf Corsepius <ralf.corsepius@rtems.org>Ralf Corsepius1-1/+1
* mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Remove $(LIB_VARIANT).
2004-01-142004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-0/+2
* mp01/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * mp01/node2/Makefile.am: Ditto. * mp02/node1/Makefile.am: Ditto. * mp02/node2/Makefile.am: Ditto. * mp03/node1/Makefile.am: Ditto. * mp03/node2/Makefile.am: Ditto. * mp04/node1/Makefile.am: Ditto. * mp04/node2/Makefile.am: Ditto. * mp05/node1/Makefile.am: Ditto. * mp05/node2/Makefile.am: Ditto. * mp06/node1/Makefile.am: Ditto. * mp06/node2/Makefile.am: Ditto. * mp07/node1/Makefile.am: Ditto. * mp07/node2/Makefile.am: Ditto. * mp08/node1/Makefile.am: Ditto. * mp08/node2/Makefile.am: Ditto. * mp09/node1/Makefile.am: Ditto. * mp09/node2/Makefile.am: Ditto. * mp10/node1/Makefile.am: Ditto. * mp10/node2/Makefile.am: Ditto. * mp11/node1/Makefile.am: Ditto. * mp11/node2/Makefile.am: Ditto. * mp12/node1/Makefile.am: Ditto. * mp12/node2/Makefile.am: Ditto. * mp13/node1/Makefile.am: Ditto. * mp13/node2/Makefile.am: Ditto. * mp14/node1/Makefile.am: Ditto. * mp14/node2/Makefile.am: Ditto.
2003-12-182003-12-18 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-4/+5
* mptests.am: Add dirstamp support. * mptests/mp01/node1/Makefile.am: Eliminate VPATH. * mptests/mp01/node2/Makefile.am: Eliminate VPATH. * mptests/mp02/node1/Makefile.am: Eliminate VPATH. * mptests/mp02/node2/Makefile.am: Eliminate VPATH. * mptests/mp03/node1/Makefile.am: Eliminate VPATH. * mptests/mp03/node2/Makefile.am: Eliminate VPATH. * mptests/mp04/node1/Makefile.am: Eliminate VPATH. * mptests/mp04/node2/Makefile.am: Eliminate VPATH. * mptests/mp05/node1/Makefile.am: Eliminate VPATH. * mptests/mp05/node2/Makefile.am: Eliminate VPATH. * mptests/mp06/node1/Makefile.am: Eliminate VPATH. * mptests/mp06/node2/Makefile.am: Eliminate VPATH. * mptests/mp07/node1/Makefile.am: Eliminate VPATH. * mptests/mp07/node2/Makefile.am: Eliminate VPATH. * mptests/mp08/node1/Makefile.am: Eliminate VPATH. * mptests/mp08/node2/Makefile.am: Eliminate VPATH. * mptests/mp09/node1/Makefile.am: Eliminate VPATH. * mptests/mp09/node2/Makefile.am: Eliminate VPATH. * mptests/mp10/node1/Makefile.am: Eliminate VPATH. * mptests/mp10/node2/Makefile.am: Eliminate VPATH. * mptests/mp11/node1/Makefile.am: Eliminate VPATH. * mptests/mp11/node2/Makefile.am: Eliminate VPATH. * mptests/mp12/node1/Makefile.am: Eliminate VPATH. * mptests/mp12/node2/Makefile.am: Eliminate VPATH. * mptests/mp13/node1/Makefile.am: Eliminate VPATH. * mptests/mp13/node2/Makefile.am: Eliminate VPATH. * mptests/mp14/node1/Makefile.am: Eliminate VPATH. * mptests/mp14/node2/Makefile.am: Eliminate VPATH.
2003-12-012003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-2/+1
* mp01/Makefile.am: Reformat. * mp01/node1/Makefile.am: Remove all-local: $(ARCH). * mp01/node2/Makefile.am: Remove all-local: $(ARCH). * mp02/Makefile.am: Reformat. * mp02/node1/Makefile.am: Remove all-local: $(ARCH). * mp02/node2/Makefile.am: Remove all-local: $(ARCH). * mp03/Makefile.am: Reformat. * mp03/node1/Makefile.am: Remove all-local: $(ARCH). * mp03/node2/Makefile.am: Remove all-local: $(ARCH). * mp04/Makefile.am: Reformat. * mp04/node1/Makefile.am: Remove all-local: $(ARCH). * mp04/node2/Makefile.am: Remove all-local: $(ARCH). * mp05/Makefile.am: Reformat. * mp05/node1/Makefile.am: Remove all-local: $(ARCH). * mp05/node2/Makefile.am: Remove all-local: $(ARCH). * mp06/Makefile.am: Reformat. * mp06/node1/Makefile.am: Remove all-local: $(ARCH). * mp06/node2/Makefile.am: Remove all-local: $(ARCH). * mp07/Makefile.am: Reformat. * mp07/node1/Makefile.am: Remove all-local: $(ARCH). * mp07/node2/Makefile.am: Remove all-local: $(ARCH). * mp08/Makefile.am: Reformat. * mp08/node1/Makefile.am: Remove all-local: $(ARCH). * mp08/node2/Makefile.am: Remove all-local: $(ARCH). * mp09/Makefile.am: Reformat. * mp09/node1/Makefile.am: Remove all-local: $(ARCH). * mp09/node2/Makefile.am: Remove all-local: $(ARCH). * mp10/Makefile.am: Reformat. * mp10/node1/Makefile.am: Remove all-local: $(ARCH). * mp10/node2/Makefile.am: Remove all-local: $(ARCH). * mp11/Makefile.am: Reformat. * mp11/node1/Makefile.am: Remove all-local: $(ARCH). * mp11/node2/Makefile.am: Remove all-local: $(ARCH). * mp12/Makefile.am: Reformat. * mp12/node1/Makefile.am: Remove all-local: $(ARCH). * mp12/node2/Makefile.am: Remove all-local: $(ARCH). * mp13/Makefile.am: Reformat. * mp13/node1/Makefile.am: Remove all-local: $(ARCH). * mp13/node2/Makefile.am: Remove all-local: $(ARCH). * mp14/Makefile.am: Reformat. * mp14/node1/Makefile.am: Remove all-local: $(ARCH). * mp14/node2/Makefile.am: Remove all-local: $(ARCH).
2003-09-042003-09-04 Joel Sherrill <joel@OARcorp.com>Joel Sherrill1-1/+1
* mp01/init.c, mp01/system.h, mp01/task1.c, mp01/node1/mp01.doc, mp01/node2/mp01.doc, mp02/init.c, mp02/system.h, mp02/task1.c, mp02/node1/mp02.doc, mp02/node2/mp02.doc, mp03/delay.c, mp03/init.c, mp03/system.h, mp03/task1.c, mp03/node1/mp03.doc, mp03/node2/mp03.doc, mp04/init.c, mp04/system.h, mp04/task1.c, mp04/node1/mp04.doc, mp04/node2/mp04.doc, mp05/asr.c, mp05/init.c, mp05/system.h, mp05/task1.c, mp05/node1/mp05.doc, mp05/node2/mp05.doc, mp06/init.c, mp06/system.h, mp06/task1.c, mp06/node1/mp06.doc, mp06/node2/mp06.doc, mp07/init.c, mp07/system.h, mp07/task1.c, mp07/node1/mp07.doc, mp07/node2/mp07.doc, mp08/init.c, mp08/system.h, mp08/task1.c, mp08/node1/mp08.doc, mp08/node2/mp08.doc, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c, mp09/system.h, mp09/task1.c, mp09/node1/mp09.doc, mp09/node2/mp09.doc, mp10/init.c, mp10/system.h, mp10/task1.c, mp10/task2.c, mp10/task3.c, mp10/node1/mp10.doc, mp10/node2/mp10.doc, mp11/init.c, mp11/system.h, mp11/node1/mp11.doc, mp11/node2/mp11.doc, mp12/init.c, mp12/system.h, mp12/node1/mp12.doc, mp12/node2/mp12.doc, mp13/init.c, mp13/system.h, mp13/task1.c, mp13/task2.c, mp13/node1/mp13.doc, mp13/node2/mp13.doc, mp14/delay.c, mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h, mp14/node1/mp14.doc, mp14/node2/mp14.doc: URL for license changed.
2003-08-162003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-3/+3
Makefile.am: Reflect having moved automake. mp01/Makefile.am: Reflect having moved automake. mp01/node1/Makefile.am: Reflect having moved automake. mp01/node2/Makefile.am: Reflect having moved automake. mp02/Makefile.am: Reflect having moved automake. mp02/node1/Makefile.am: Reflect having moved automake. mp02/node2/Makefile.am: Reflect having moved automake. mp03/Makefile.am: Reflect having moved automake. mp03/node1/Makefile.am: Reflect having moved automake. mp03/node2/Makefile.am: Reflect having moved automake. mp04/Makefile.am: Reflect having moved automake. mp04/node1/Makefile.am: Reflect having moved automake. mp04/node2/Makefile.am: Reflect having moved automake. mp05/Makefile.am: Reflect having moved automake. mp05/node1/Makefile.am: Reflect having moved automake. mp05/node2/Makefile.am: Reflect having moved automake. mp06/Makefile.am: Reflect having moved automake. mp06/node1/Makefile.am: Reflect having moved automake. mp06/node2/Makefile.am: Reflect having moved automake. mp07/Makefile.am: Reflect having moved automake. mp07/node1/Makefile.am: Reflect having moved automake. mp07/node2/Makefile.am: Reflect having moved automake. mp08/Makefile.am: Reflect having moved automake. mp08/node1/Makefile.am: Reflect having moved automake. mp08/node2/Makefile.am: Reflect having moved automake. mp09/Makefile.am: Reflect having moved automake. mp09/node1/Makefile.am: Reflect having moved automake. mp09/node2/Makefile.am: Reflect having moved automake. mp10/Makefile.am: Reflect having moved automake. mp10/node1/Makefile.am: Reflect having moved automake. mp10/node2/Makefile.am: Reflect having moved automake. mp11/Makefile.am: Reflect having moved automake. mp11/node1/Makefile.am: Reflect having moved automake. mp11/node2/Makefile.am: Reflect having moved automake. mp12/Makefile.am: Reflect having moved automake. mp12/node1/Makefile.am: Reflect having moved automake. mp12/node2/Makefile.am: Reflect having moved automake. mp13/Makefile.am: Reflect having moved automake. mp13/node1/Makefile.am: Reflect having moved automake. mp13/node2/Makefile.am: Reflect having moved automake. mp14/Makefile.am: Reflect having moved automake. mp14/node1/Makefile.am: Reflect having moved automake. mp14/node2/Makefile.am: Reflect having moved automake.
2002-08-112002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius1-1/+1
* mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
2002-03-282002-03-27 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
* configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
2001-09-192001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+1
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
2000-09-052000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+1
* mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
2000-07-13Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-2/+2
that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
2000-06-12Merged from 4.5.0-beta3aJoel Sherrill1-3/+3
2000-04-13Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill1-0/+2
2000-01-31Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-1/+0
that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
1999-12-21Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-7/+0
which does minor cleanup for Makefile.ams below mptests, which only removes some bogus comments from the Makefile.ams. To apply: patch -p1 < rtems-rc-19991203-8.diff ./bootstrap
1999-11-24Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1-0/+58
1999-11-17Updated copyright notice.Joel Sherrill1-2/+1
1998-02-17updated copyright to 1998Joel Sherrill1-1/+1
1997-10-08Fixed typo in the pointer to the license terms.Joel Sherrill1-2/+2
1997-04-22headers updated to reflect new style copyright notice as partJoel Sherrill1-5/+5
