path: root/testsuites/mptests/mp11/node2 (follow)
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. mp01/Makefile.am: Reflect having moved automake. mp01/node1/Makefile.am: Reflect having moved automake. mp01/node2/Makefile.am: Reflect having moved automake. mp02/Makefile.am: Reflect having moved automake. mp02/node1/Makefile.am: Reflect having moved automake. mp02/node2/Makefile.am: Reflect having moved automake. mp03/Makefile.am: Reflect having moved automake. mp03/node1/Makefile.am: Reflect having moved automake. mp03/node2/Makefile.am: Reflect having moved automake. mp04/Makefile.am: Reflect having moved automake. mp04/node1/Makefile.am: Reflect having moved automake. mp04/node2/Makefile.am: Reflect having moved automake. mp05/Makefile.am: Reflect having moved automake. mp05/node1/Makefile.am: Reflect having moved automake. mp05/node2/Makefile.am: Reflect having moved automake. mp06/Makefile.am: Reflect having moved automake. mp06/node1/Makefile.am: Reflect having moved automake. mp06/node2/Makefile.am: Reflect having moved automake. mp07/Makefile.am: Reflect having moved automake. mp07/node1/Makefile.am: Reflect having moved automake. mp07/node2/Makefile.am: Reflect having moved automake. mp08/Makefile.am: Reflect having moved automake. mp08/node1/Makefile.am: Reflect having moved automake. mp08/node2/Makefile.am: Reflect having moved automake. mp09/Makefile.am: Reflect having moved automake. mp09/node1/Makefile.am: Reflect having moved automake. mp09/node2/Makefile.am: Reflect having moved automake. mp10/Makefile.am: Reflect having moved automake. mp10/node1/Makefile.am: Reflect having moved automake. mp10/node2/Makefile.am: Reflect having moved automake. mp11/Makefile.am: Reflect having moved automake. mp11/node1/Makefile.am: Reflect having moved automake. mp11/node2/Makefile.am: Reflect having moved automake. mp12/Makefile.am: Reflect having moved automake. mp12/node1/Makefile.am: Reflect having moved automake. mp12/node2/Makefile.am: Reflect having moved automake. mp13/Makefile.am: Reflect having moved automake. mp13/node1/Makefile.am: Reflect having moved automake. mp13/node2/Makefile.am: Reflect having moved automake. mp14/Makefile.am: Reflect having moved automake. mp14/node1/Makefile.am: Reflect having moved automake. mp14/node2/Makefile.am: Reflect having moved automake.
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o. * mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o. * mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-131-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-121-3/+3
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-211-7/+0
| | | | | | | | | which does minor cleanup for Makefile.ams below mptests, which only removes some bogus comments from the Makefile.ams. To apply: patch -p1 < rtems-rc-19991203-8.diff ./bootstrap
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-241-0/+58
| | | | which (among other things) converted the mptests to automake.
* Initial revisionJoel Sherrill1995-05-112-0/+15
