* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp05/task1.c, mp06/task1.c,
mp07/task1.c, mp08/task1.c, mp09/recvmsg.c, mp09/sendmsg.c,
mp09/task1.c, mp10/init.c, mp12/init.c, mp13/init.c, mp13/task1.c,
mp13/task2.c, mp14/evtask1.c, mp14/init.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* mp09/recvmsg.c, mp09/task1.c, mp10/task1.c, mp13/task1.c,
mp14/msgtask1.c: Correct types to eliminate warnings.
* mp01/init.c, mp02/init.c, mp03/init.c, mp04/init.c, mp05/init.c,
mp06/init.c, mp07/init.c, mp08/init.c, mp09/init.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp14/init.c: Change TEST_INIT
to CONFIGURE_INIT. Make tmacros.h available to all POSIX tests. Add a
clock_settime case for < 1988.
* mp01/node1/Makefile.am, mp01/node2/Makefile.am,
mp02/node1/Makefile.am, mp02/node2/Makefile.am,
mp03/node1/Makefile.am, mp03/node2/Makefile.am,
mp04/node1/Makefile.am, mp04/node2/Makefile.am,
mp05/node1/Makefile.am, mp05/node2/Makefile.am,
mp06/node1/Makefile.am, mp06/node2/Makefile.am,
mp07/node1/Makefile.am, mp07/node2/Makefile.am,
mp08/node1/Makefile.am, mp08/node2/Makefile.am,
mp09/node1/Makefile.am, mp09/node2/Makefile.am,
mp10/node1/Makefile.am, mp10/node2/Makefile.am,
mp11/node1/Makefile.am, mp11/node2/Makefile.am,
mp12/node1/Makefile.am, mp12/node2/Makefile.am,
mp13/node1/Makefile.am, mp13/node2/Makefile.am,
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Use all managers.
Remove $(LIB_VARIANT).
* mp02/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp03/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp04/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp05/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp06/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp07/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp08/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp09/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp10/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp11/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp12/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp13/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp14/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* mp02/task1.c, mp03/system.h, mp03/task1.c, mp04/task1.c,
mp05/system.h, mp06/task1.c, mp07/task1.c, mp08/task1.c,
mp09/recvmsg.c, mp09/sendmsg.c, mp09/task1.c, mp10/task1.c,
mp11/init.c, mp12/init.c, mp13/task1.c, mp14/evtask1.c,
mp14/evtmtask.c, mp14/init.c, mp14/msgtask1.c, mp14/pttask1.c,
mp14/smtask1.c, mp14/system.h: Convert to using c99 fixed size
types.
* mp01/node1/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* mp01/node2/Makefile.am: Ditto.
* mp02/node1/Makefile.am: Ditto.
* mp02/node2/Makefile.am: Ditto.
* mp03/node1/Makefile.am: Ditto.
* mp03/node2/Makefile.am: Ditto.
* mp04/node1/Makefile.am: Ditto.
* mp04/node2/Makefile.am: Ditto.
* mp05/node1/Makefile.am: Ditto.
* mp05/node2/Makefile.am: Ditto.
* mp06/node1/Makefile.am: Ditto.
* mp06/node2/Makefile.am: Ditto.
* mp07/node1/Makefile.am: Ditto.
* mp07/node2/Makefile.am: Ditto.
* mp08/node1/Makefile.am: Ditto.
* mp08/node2/Makefile.am: Ditto.
* mp09/node1/Makefile.am: Ditto.
* mp09/node2/Makefile.am: Ditto.
* mp10/node1/Makefile.am: Ditto.
* mp10/node2/Makefile.am: Ditto.
* mp11/node1/Makefile.am: Ditto.
* mp11/node2/Makefile.am: Ditto.
* mp12/node1/Makefile.am: Ditto.
* mp12/node2/Makefile.am: Ditto.
* mp13/node1/Makefile.am: Ditto.
* mp13/node2/Makefile.am: Ditto.
* mp14/node1/Makefile.am: Ditto.
* mp14/node2/Makefile.am: Ditto.
* mptests.am: Add dirstamp support.
* mptests/mp01/node1/Makefile.am: Eliminate VPATH.
* mptests/mp01/node2/Makefile.am: Eliminate VPATH.
* mptests/mp02/node1/Makefile.am: Eliminate VPATH.
* mptests/mp02/node2/Makefile.am: Eliminate VPATH.
* mptests/mp03/node1/Makefile.am: Eliminate VPATH.
* mptests/mp03/node2/Makefile.am: Eliminate VPATH.
* mptests/mp04/node1/Makefile.am: Eliminate VPATH.
* mptests/mp04/node2/Makefile.am: Eliminate VPATH.
* mptests/mp05/node1/Makefile.am: Eliminate VPATH.
* mptests/mp05/node2/Makefile.am: Eliminate VPATH.
* mptests/mp06/node1/Makefile.am: Eliminate VPATH.
* mptests/mp06/node2/Makefile.am: Eliminate VPATH.
* mptests/mp07/node1/Makefile.am: Eliminate VPATH.
* mptests/mp07/node2/Makefile.am: Eliminate VPATH.
* mptests/mp08/node1/Makefile.am: Eliminate VPATH.
* mptests/mp08/node2/Makefile.am: Eliminate VPATH.
* mptests/mp09/node1/Makefile.am: Eliminate VPATH.
* mptests/mp09/node2/Makefile.am: Eliminate VPATH.
* mptests/mp10/node1/Makefile.am: Eliminate VPATH.
* mptests/mp10/node2/Makefile.am: Eliminate VPATH.
* mptests/mp11/node1/Makefile.am: Eliminate VPATH.
* mptests/mp11/node2/Makefile.am: Eliminate VPATH.
* mptests/mp12/node1/Makefile.am: Eliminate VPATH.
* mptests/mp12/node2/Makefile.am: Eliminate VPATH.
* mptests/mp13/node1/Makefile.am: Eliminate VPATH.
* mptests/mp13/node2/Makefile.am: Eliminate VPATH.
* mptests/mp14/node1/Makefile.am: Eliminate VPATH.
* mptests/mp14/node2/Makefile.am: Eliminate VPATH.
* mp01/Makefile.am: Reformat.
* mp01/node1/Makefile.am: Remove all-local: $(ARCH).
* mp01/node2/Makefile.am: Remove all-local: $(ARCH).
* mp02/Makefile.am: Reformat.
* mp02/node1/Makefile.am: Remove all-local: $(ARCH).
* mp02/node2/Makefile.am: Remove all-local: $(ARCH).
* mp03/Makefile.am: Reformat.
* mp03/node1/Makefile.am: Remove all-local: $(ARCH).
* mp03/node2/Makefile.am: Remove all-local: $(ARCH).
* mp04/Makefile.am: Reformat.
* mp04/node1/Makefile.am: Remove all-local: $(ARCH).
* mp04/node2/Makefile.am: Remove all-local: $(ARCH).
* mp05/Makefile.am: Reformat.
* mp05/node1/Makefile.am: Remove all-local: $(ARCH).
* mp05/node2/Makefile.am: Remove all-local: $(ARCH).
* mp06/Makefile.am: Reformat.
* mp06/node1/Makefile.am: Remove all-local: $(ARCH).
* mp06/node2/Makefile.am: Remove all-local: $(ARCH).
* mp07/Makefile.am: Reformat.
* mp07/node1/Makefile.am: Remove all-local: $(ARCH).
* mp07/node2/Makefile.am: Remove all-local: $(ARCH).
* mp08/Makefile.am: Reformat.
* mp08/node1/Makefile.am: Remove all-local: $(ARCH).
* mp08/node2/Makefile.am: Remove all-local: $(ARCH).
* mp09/Makefile.am: Reformat.
* mp09/node1/Makefile.am: Remove all-local: $(ARCH).
* mp09/node2/Makefile.am: Remove all-local: $(ARCH).
* mp10/Makefile.am: Reformat.
* mp10/node1/Makefile.am: Remove all-local: $(ARCH).
* mp10/node2/Makefile.am: Remove all-local: $(ARCH).
* mp11/Makefile.am: Reformat.
* mp11/node1/Makefile.am: Remove all-local: $(ARCH).
* mp11/node2/Makefile.am: Remove all-local: $(ARCH).
* mp12/Makefile.am: Reformat.
* mp12/node1/Makefile.am: Remove all-local: $(ARCH).
* mp12/node2/Makefile.am: Remove all-local: $(ARCH).
* mp13/Makefile.am: Reformat.
* mp13/node1/Makefile.am: Remove all-local: $(ARCH).
* mp13/node2/Makefile.am: Remove all-local: $(ARCH).
* mp14/Makefile.am: Reformat.
* mp14/node1/Makefile.am: Remove all-local: $(ARCH).
* mp14/node2/Makefile.am: Remove all-local: $(ARCH).
* mp01/init.c, mp01/system.h, mp01/task1.c, mp01/node1/mp01.doc,
mp01/node2/mp01.doc, mp02/init.c, mp02/system.h, mp02/task1.c,
mp02/node1/mp02.doc, mp02/node2/mp02.doc, mp03/delay.c, mp03/init.c,
mp03/system.h, mp03/task1.c, mp03/node1/mp03.doc,
mp03/node2/mp03.doc, mp04/init.c, mp04/system.h, mp04/task1.c,
mp04/node1/mp04.doc, mp04/node2/mp04.doc, mp05/asr.c, mp05/init.c,
mp05/system.h, mp05/task1.c, mp05/node1/mp05.doc,
mp05/node2/mp05.doc, mp06/init.c, mp06/system.h, mp06/task1.c,
mp06/node1/mp06.doc, mp06/node2/mp06.doc, mp07/init.c, mp07/system.h,
mp07/task1.c, mp07/node1/mp07.doc, mp07/node2/mp07.doc, mp08/init.c,
mp08/system.h, mp08/task1.c, mp08/node1/mp08.doc,
mp08/node2/mp08.doc, mp09/init.c, mp09/recvmsg.c, mp09/sendmsg.c,
mp09/system.h, mp09/task1.c, mp09/node1/mp09.doc,
mp09/node2/mp09.doc, mp10/init.c, mp10/system.h, mp10/task1.c,
mp10/task2.c, mp10/task3.c, mp10/node1/mp10.doc, mp10/node2/mp10.doc,
mp11/init.c, mp11/system.h, mp11/node1/mp11.doc, mp11/node2/mp11.doc,
mp12/init.c, mp12/system.h, mp12/node1/mp12.doc, mp12/node2/mp12.doc,
mp13/init.c, mp13/system.h, mp13/task1.c, mp13/task2.c,
mp13/node1/mp13.doc, mp13/node2/mp13.doc, mp14/delay.c,
mp14/evtask1.c, mp14/evtmtask.c, mp14/exit.c, mp14/init.c,
mp14/msgtask1.c, mp14/pttask1.c, mp14/smtask1.c, mp14/system.h,
mp14/node1/mp14.doc, mp14/node2/mp14.doc: URL for license changed.
mp01/Makefile.am: Reflect having moved automake.
mp01/node1/Makefile.am: Reflect having moved automake.
mp01/node2/Makefile.am: Reflect having moved automake.
mp02/Makefile.am: Reflect having moved automake.
mp02/node1/Makefile.am: Reflect having moved automake.
mp02/node2/Makefile.am: Reflect having moved automake.
mp03/Makefile.am: Reflect having moved automake.
mp03/node1/Makefile.am: Reflect having moved automake.
mp03/node2/Makefile.am: Reflect having moved automake.
mp04/Makefile.am: Reflect having moved automake.
mp04/node1/Makefile.am: Reflect having moved automake.
mp04/node2/Makefile.am: Reflect having moved automake.
mp05/Makefile.am: Reflect having moved automake.
mp05/node1/Makefile.am: Reflect having moved automake.
mp05/node2/Makefile.am: Reflect having moved automake.
mp06/Makefile.am: Reflect having moved automake.
mp06/node1/Makefile.am: Reflect having moved automake.
mp06/node2/Makefile.am: Reflect having moved automake.
mp07/Makefile.am: Reflect having moved automake.
mp07/node1/Makefile.am: Reflect having moved automake.
mp07/node2/Makefile.am: Reflect having moved automake.
mp08/Makefile.am: Reflect having moved automake.
mp08/node1/Makefile.am: Reflect having moved automake.
mp08/node2/Makefile.am: Reflect having moved automake.
mp09/Makefile.am: Reflect having moved automake.
mp09/node1/Makefile.am: Reflect having moved automake.
mp09/node2/Makefile.am: Reflect having moved automake.
mp10/Makefile.am: Reflect having moved automake.
mp10/node1/Makefile.am: Reflect having moved automake.
mp10/node2/Makefile.am: Reflect having moved automake.
mp11/Makefile.am: Reflect having moved automake.
mp11/node1/Makefile.am: Reflect having moved automake.
mp11/node2/Makefile.am: Reflect having moved automake.
mp12/Makefile.am: Reflect having moved automake.
mp12/node1/Makefile.am: Reflect having moved automake.
mp12/node2/Makefile.am: Reflect having moved automake.
mp13/Makefile.am: Reflect having moved automake.
mp13/node1/Makefile.am: Reflect having moved automake.
mp13/node2/Makefile.am: Reflect having moved automake.
mp14/Makefile.am: Reflect having moved automake.
mp14/node1/Makefile.am: Reflect having moved automake.
mp14/node2/Makefile.am: Reflect having moved automake.
* mp01/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp01/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp02/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp03/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp04/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp05/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp06/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp07/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp08/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp09/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp10/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp11/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp12/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp13/node2/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node1/Makefile.am: Use $(OBJEXT) instead of .o.
* mp14/node2/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* mp01/task1.c, mp02/task1.c, mp03/task1.c, mp04/task1.c, mp05/task1.c,
mp06/task1.c, mp07/task1.c, mp08/task1.c, mp09/task1.c, mp10/init.c,
mp11/init.c, mp12/init.c, mp13/init.c, mp13/task2.c: Modified.
* mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg.
* mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
which does minor cleanup for Makefile.ams below mptests, which only
removes some bogus comments from the Makefile.ams.
patch -p1 < rtems-rc-19991203-8.diff
./bootstrap
