path: root/testsuites/mptests/mp08 (follow)
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-192-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp02/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp02/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp04/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp14/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp06/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp08/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp03/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp10/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp05/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp13/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp01/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp07/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp11/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp12/node1/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node2/Makefile.am: include leaf.am instead of leaf.cfg. * mp09/node1/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+2
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-132-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-9/+10
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-133-0/+6
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-312-2/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-212-14/+0
| | | | | | | | | which does minor cleanup for Makefile.ams below mptests, which only removes some bogus comments from the Makefile.ams. To apply: patch -p1 < rtems-rc-19991203-8.diff ./bootstrap
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-243-0/+128
| | | | which (among other things) converted the mptests to automake.
* Updated copyright notice.Joel Sherrill1999-11-175-10/+5
* updated copyright to 1998Joel Sherrill1998-02-175-5/+5
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-085-10/+10
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-225-25/+25
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+26
* Added unused priority ceiling parameter to rtems_semaphore_create.Joel Sherrill1995-08-281-0/+1
| | | | | | | | | | | | | | | Rearranged code to created thread handler routines to initialize, start, restart, and "close/delete" a thread. Made internal threads their own object class. This now uses the thread support routines for starting and initializing a thread. Insured deleted tasks are freed to the Inactive pool associated with the correct Information block. Added an RTEMS API specific data area to the thread control block. Beginnings of removing the word "rtems" from the core.
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-117-0/+283
