path: root/testsuites/mptests/mp04 (follow)
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-052-0/+2
| | | | | | | | | | | | | | | | | * mp01/node1/Makefile.am, mp01/node2/Makefile.am, mp02/node1/Makefile.am, mp02/node2/Makefile.am, mp03/node1/Makefile.am, mp03/node2/Makefile.am, mp04/node1/Makefile.am, mp04/node2/Makefile.am, mp05/node1/Makefile.am, mp05/node2/Makefile.am, mp06/node1/Makefile.am, mp06/node2/Makefile.am, mp07/node1/Makefile.am, mp07/node2/Makefile.am, mp08/node1/Makefile.am, mp08/node2/Makefile.am, mp09/node1/Makefile.am, mp09/node2/Makefile.am, mp10/node1/Makefile.am, mp10/node2/Makefile.am, mp11/node1/Makefile.am, mp11/node2/Makefile.am, mp12/node1/Makefile.am, mp12/node2/Makefile.am, mp13/node1/Makefile.am, mp13/node2/Makefile.am, mp14/node1/Makefile.am, mp14/node2/Makefile.am: Include compile.am
* Patch rtems-rc-20000713-1-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-132-4/+4
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | that is yet another multilib-related structual cleanup patch: Changes: * Make RTEMS_TEST_NO_PAUSE a tests/ subpackage specific option. - Remove RTEMS_TEST_NO_PAUSE from custom/*.cfg, targopts.h and cpuopts.h. - Add autoconf macros RTEMS_*_RTEMS_TEST_NO_PAUSE (aclocal/rtems-test-no-pause.m4). - Add RTEMS_*_RTEMS_TEST_NO_PAUSE support to sptests/configure.ins and tmtests/configure.in. These are the only subdirectories which currently apply RTEMS_TEST_NO_PAUSE. - Add autoconf-DEFS support to all test subpackages' configure.ins below tests/. I.e. AC_DEFINES now get explicitly propagated as preprocessor defines into Makefiles, cf. AM_CPPFLAGS in tests/*/*.am, instead of using a global config-files. - Remove NDEBUG from custom/*.cfg. * AC_DEFINE POSIX_API, ITRON_API and MULTIPROCESSING in exec/configure.in, only. - All other sources now should relay on the values from cpuopts.h and should not define them themselves. - Several related changes to many configure.ins * Bug-fixes to RTEMS_*_RTEMS_DEBUG macros (Actually workarounds to quoting bugs in autoconf). Notes: * This patch is rather immature and only tested for a small subset of BSPs (requires the tests to be enabled and therefore takes an tremendous amount of disc space and time.) * The patches to *cfg were generated by a script. Expect file formating changes :)
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-9/+10
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-133-0/+6
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-312-2/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Patch rtems-rc-19991203-7.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-12-212-14/+0
| | | | | | | | | which does minor cleanup for Makefile.ams below mptests, which only removes some bogus comments from the Makefile.ams. To apply: patch -p1 < rtems-rc-19991203-8.diff ./bootstrap
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-243-0/+128
| | | | which (among other things) converted the mptests to automake.
* Updated copyright notice.Joel Sherrill1999-11-175-10/+5
* updated copyright to 1998Joel Sherrill1998-02-175-5/+5
* Fixed typo in the pointer to the license terms.Joel Sherrill1997-10-085-10/+10
* headers updated to reflect new style copyright notice as partJoel Sherrill1997-04-225-25/+25
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-1/+1
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+22
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-231-1/+1
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-3/+2
* Initial revisionJoel Sherrill1995-05-117-0/+246
