path: root/testsuites/mptests/mp01 (follow)
* Minor bug fixes to get all targets compilable and running. TheJoel Sherrill1995-09-191-3/+3
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-112-9/+22
* Support for variable length names added to Object Handler. This supportsJoel Sherrill1995-08-232-2/+2
* maximum number of messages removed and include statement cleanupJoel Sherrill1995-08-171-4/+3
* Fully tested on all in-house targetsJoel Sherrill1995-05-241-2/+2
* Initial revisionJoel Sherrill1995-05-117-0/+309
