path: root/testsuites/mptests/mp01/Makefile.am (follow)
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-111-4/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+4
* Remove CVS-Ids.Ralf Corsépius2012-05-041-4/+0
* Misc. bugfixes.Ralf Corsepius2005-11-071-2/+0
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-1/+0
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * mp01/Makefile.am: Reformat. * mp01/node1/Makefile.am: Remove all-local: $(ARCH). * mp01/node2/Makefile.am: Remove all-local: $(ARCH). * mp02/Makefile.am: Reformat. * mp02/node1/Makefile.am: Remove all-local: $(ARCH). * mp02/node2/Makefile.am: Remove all-local: $(ARCH). * mp03/Makefile.am: Reformat. * mp03/node1/Makefile.am: Remove all-local: $(ARCH). * mp03/node2/Makefile.am: Remove all-local: $(ARCH). * mp04/Makefile.am: Reformat. * mp04/node1/Makefile.am: Remove all-local: $(ARCH). * mp04/node2/Makefile.am: Remove all-local: $(ARCH). * mp05/Makefile.am: Reformat. * mp05/node1/Makefile.am: Remove all-local: $(ARCH). * mp05/node2/Makefile.am: Remove all-local: $(ARCH). * mp06/Makefile.am: Reformat. * mp06/node1/Makefile.am: Remove all-local: $(ARCH). * mp06/node2/Makefile.am: Remove all-local: $(ARCH). * mp07/Makefile.am: Reformat. * mp07/node1/Makefile.am: Remove all-local: $(ARCH). * mp07/node2/Makefile.am: Remove all-local: $(ARCH). * mp08/Makefile.am: Reformat. * mp08/node1/Makefile.am: Remove all-local: $(ARCH). * mp08/node2/Makefile.am: Remove all-local: $(ARCH). * mp09/Makefile.am: Reformat. * mp09/node1/Makefile.am: Remove all-local: $(ARCH). * mp09/node2/Makefile.am: Remove all-local: $(ARCH). * mp10/Makefile.am: Reformat. * mp10/node1/Makefile.am: Remove all-local: $(ARCH). * mp10/node2/Makefile.am: Remove all-local: $(ARCH). * mp11/Makefile.am: Reformat. * mp11/node1/Makefile.am: Remove all-local: $(ARCH). * mp11/node2/Makefile.am: Remove all-local: $(ARCH). * mp12/Makefile.am: Reformat. * mp12/node1/Makefile.am: Remove all-local: $(ARCH). * mp12/node2/Makefile.am: Remove all-local: $(ARCH). * mp13/Makefile.am: Reformat. * mp13/node1/Makefile.am: Remove all-local: $(ARCH). * mp13/node2/Makefile.am: Remove all-local: $(ARCH). * mp14/Makefile.am: Reformat. * mp14/node1/Makefile.am: Remove all-local: $(ARCH). * mp14/node2/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-2/+2
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | Makefile.am: Reflect having moved automake. mp01/Makefile.am: Reflect having moved automake. mp01/node1/Makefile.am: Reflect having moved automake. mp01/node2/Makefile.am: Reflect having moved automake. mp02/Makefile.am: Reflect having moved automake. mp02/node1/Makefile.am: Reflect having moved automake. mp02/node2/Makefile.am: Reflect having moved automake. mp03/Makefile.am: Reflect having moved automake. mp03/node1/Makefile.am: Reflect having moved automake. mp03/node2/Makefile.am: Reflect having moved automake. mp04/Makefile.am: Reflect having moved automake. mp04/node1/Makefile.am: Reflect having moved automake. mp04/node2/Makefile.am: Reflect having moved automake. mp05/Makefile.am: Reflect having moved automake. mp05/node1/Makefile.am: Reflect having moved automake. mp05/node2/Makefile.am: Reflect having moved automake. mp06/Makefile.am: Reflect having moved automake. mp06/node1/Makefile.am: Reflect having moved automake. mp06/node2/Makefile.am: Reflect having moved automake. mp07/Makefile.am: Reflect having moved automake. mp07/node1/Makefile.am: Reflect having moved automake. mp07/node2/Makefile.am: Reflect having moved automake. mp08/Makefile.am: Reflect having moved automake. mp08/node1/Makefile.am: Reflect having moved automake. mp08/node2/Makefile.am: Reflect having moved automake. mp09/Makefile.am: Reflect having moved automake. mp09/node1/Makefile.am: Reflect having moved automake. mp09/node2/Makefile.am: Reflect having moved automake. mp10/Makefile.am: Reflect having moved automake. mp10/node1/Makefile.am: Reflect having moved automake. mp10/node2/Makefile.am: Reflect having moved automake. mp11/Makefile.am: Reflect having moved automake. mp11/node1/Makefile.am: Reflect having moved automake. mp11/node2/Makefile.am: Reflect having moved automake. mp12/Makefile.am: Reflect having moved automake. mp12/node1/Makefile.am: Reflect having moved automake. mp12/node2/Makefile.am: Reflect having moved automake. mp13/Makefile.am: Reflect having moved automake. mp13/node1/Makefile.am: Reflect having moved automake. mp13/node2/Makefile.am: Reflect having moved automake. mp14/Makefile.am: Reflect having moved automake. mp14/node1/Makefile.am: Reflect having moved automake. mp14/node2/Makefile.am: Reflect having moved automake.
| | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * mp01/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp01/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp02/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp03/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp04/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp05/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp06/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp07/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp08/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp09/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp10/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp11/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp12/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp13/node2/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node1/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/Makefile.am: Remove AUTOMAKE_OPTIONS. * mp14/node2/Makefile.am: Remove AUTOMAKE_OPTIONS.
* Patch rtems-rc-19991123-rc-0.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-241-0/+12
