* malloc04/init.c: Fix tests broken in warning pass.
* ftp01/.cvsignore, ftp01/Makefile.am, ftp01/ftp01.doc,
ftp01/ftp01.scn, ftp01/init.c: New files.
* Makefile.am, configure.ac: Reflect changes above.
* devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c,
malloctest/init.c, termios03/termios_testdriver_polled.c,
termios04/termios_testdriver_intr.c: Remove warnings.
* tar01/init.c: Fixed integer types.
* Makefile.am, configure.ac: Add test for Mouse Parser Engine
(Microsoft Mouse paths) and Serial Mouse Driver.
* mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c,
mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c,
mouse01/serial_mouse_config.c: New files.
* heapwalk/init.c: Improve coverage.
* heapwalk/heapwalk.scn: Update.
* devfs04/devfs04.scn, devfs04/init.c: Increase configuration so this
passes on sis.
* malloctest/init.c: Improve coverage.
* malloctest/malloctest.scn: Update.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* POSIX/calloc.c, POSIX/clock_gettime.c, POSIX/close.c, POSIX/dup2.c,
POSIX/fcntl.c, POSIX/flockfile.c, POSIX/fork.c, POSIX/free.c,
POSIX/fstat.c, POSIX/ftrylockfile.c, POSIX/funlockfile.c,
POSIX/getdents.c, POSIX/getlogin.c, POSIX/getpwnam.c, POSIX/getpwuid.c,
POSIX/gettimeofday.c, POSIX/getuid.c, POSIX/htonl.c, POSIX/issetugid.c,
POSIX/kill.c, POSIX/longjmp.c, POSIX/lseek.c, POSIX/lstat.c,
POSIX/malloc.c, POSIX/nanosleep.c, POSIX/open.c, POSIX/pipe.c,
POSIX/posix_memalign.c, POSIX/read.c, POSIX/readv.c, POSIX/realloc.c,
POSIX/setjmp.c, POSIX/sigaddset.c, POSIX/sigdelset.c,
POSIX/sigemptyset.c, POSIX/sigfillset.c, POSIX/sigismember.c,
POSIX/sigprocmask.c, POSIX/stat.c, POSIX/unlink.c, POSIX/vfork.c,
POSIX/wait.c, POSIX/waitpid.c, POSIX/write.c, POSIX/writev.c,
block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block08/bdbuf_test1_1.c,
block08/bdbuf_test1_2.c, block08/bdbuf_test1_3.c,
block08/bdbuf_test1_4.c, block08/bdbuf_test1_5.c,
block08/bdbuf_test2_1.c, block08/bdbuf_test2_2.c,
block08/bdbuf_test3_1.c, block08/bdbuf_test3_2.c,
block08/bdbuf_test3_3.c, block08/bdbuf_test4_1.c,
block08/bdbuf_test4_2.c, block08/bdbuf_test4_3.c, block08/bdbuf_tests.c,
block08/init.c, block09/init.c, block10/init.c, bspcmdline01/init.c,
complex/docomplex.c, complex/docomplex.in, complex/docomplexf.c,
complex/docomplexl.c, complex/init.c, cpuuse/init.c, cpuuse/task1.c,
cpuuse/task2.c, cpuuse/task3.c, cpuuse/tswitch.c, devfs01/init.c,
devfs02/init.c, devfs03/init.c, devfs04/init.c, deviceio01/init.c,
dumpbuf01/init.c, gxx01/init.c, heapwalk/init.c, malloc02/init.c,
malloc03/init.c, malloc04/init.c, malloc05/init.c, malloctest/init.c,
malloctest/task1.c, math/domath.c, math/domath.in, math/init.c,
mathf/domathf.c, mathf/init.c, mathl/domathl.c, mathl/init.c,
monitor/init.c, monitor02/init.c, putenvtest/init.c, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/task1.c, stackchk/blow.c, stackchk/init.c,
stackchk/task1.c, stackchk01/init.c, stringto01/init.c, tar01/init.c,
tar02/init.c, tar03/init.c, termios/init.c, termios01/init.c,
termios01/termios_testdriver.c, termios02/init.c, termios03/init.c,
termios03/termios_testdriver_polled.c, termios04/init.c,
termios04/termios_testdriver_intr.c, termios05/init.c,
termios05/termios_testdriver_taskdriven.c, termios06/init.c,
termios06/test_pppd.c, termios07/init.c, termios08/init.c,
tztest/init.c: Add HAVE_CONFIG_H.
* math/init.c, mathf/init.c, mathl/init.c: Now run.
* complex/Makefile.am, complex/init.c: Test now runs.
* monitor/Makefile.am, monitor02/Makefile.am: Switch to all managers
since this is all of them.
* stringto01/init.c: Redefine LONG_LONG_MAX and LONG_LONG_MIN
for c99.
* cpuuse/tswitch.c: Shrink memory requirements.
* math/math.scn, mathf/mathf.scn, mathl/mathl.scn: Regenerate.
* Makefile.am, configure.ac: Add mathf/, mathl/.
* math/init.c, math/Makefile.am: Reflect having split-out
mathl and mathf.
* math/domathf.c, math/domathl.c: Remove.
* mathf/Makefile.am, mathf/domathf.c, mathf/init.c,
mathf/mathf.scn: New (Split out from math/).
* mathl/Makefile.am, mathf/domathl.c, mathl/init.c,
mathl/mathl.scn: New (Split out from math/).
* math/init.c, complex/init.c:
Use fprintf(stdout,..) instead of printf.
Use CONFIGURE_APPLICATION_DISABLE_FILESYSTEM.
* POSIX/clock_gettime.c, POSIX/gettimeofday.c: New.
* POSIX/Makefile.am: Add clock_gettime, gettimeofday.c.
* Makefile.am: Add clock_gettime, gettimeofday.c.
PR 1661/testing
* termios06/init.c: Extend the test to cover sections related to
flow control in termios.c
* termios06/termios06.doc: Updated test concept
* termios06/termios06.scn: Updated test run log
* math/domath.in: Fix typo in printf.
* math/domath.c, math/domathf.c, math/domathl.c: Regenerate.
* math/math.scn: Regenerate.
* configure.ac: Use ac_cv_header_complex_h.
* math/Makefile.am, math/init.c: Init task has to be floating point and
there is no point in using optional manager stubs since libio needs
semaphores.
* configure.ac: Check for complex.h.
Add AM_CONDITIONAL(HAS_COMPLEX) to allow building with outdated
toolchains.
* complex/Makefile.am: Apply HAS_COMPLEX.
* Makefile.am: Add complex, math subdirs.
* configure.ac: Add complex, math subdirs.
* complex/Makefile.am, complex/init.c, complex/docomplex.c,
complex/docomplexf.c, complex/complex.scn, complex/docomplex.in,
complex/complex.doc, complex/docomplexl.c: New.
* math/Makefile.am, math/init.c, math/domath.c,
math/domathf.c, math/math.scn, math/domath.in,
math/math.doc, math/domathl.c: New.
* POSIX/Makefile.am: Add htonl.
* POSIX/htonl.c: New.
* malloctest/init.c: Update for heap API changes.
* gxx01/gxx_wrappers.h, gxx02/.cvsignore, gxx02/Makefile.am,
gxx02/gxx02.doc, gxx02/gxx02.scn, gxx02/init.c: Removed files.
* gxx01/init.c: Removed fatal error test case.
PR 1661/testing
* termios01/init.c, termios01/termios01.scn: Added a test case to
hit a case in rtems_termios_read.
PR 1664/testing
* termios01/init.c: Use INT_MAX instead of hard-coded number for error
case to avoid warning on 16-bit targets.
PR 1661/testing
* malloc04/init.c: Add public methods to get/set malloc heap pointer so
the tests do not have to peer behind the API.
PR 1661/testing
* termios01/init.c, termios01/termios_testdriver.c,
termios01/termios01.scn: Changes to improve coverage of
rtems_termios_open routine.
PR 1654/testing
* deviceio01/init.c, deviceio01/deviceio01.doc,
deviceio01/deviceio01.scn, deviceio01/test_driver.c,
deviceio01/test_driver.h, deviceio01/Makefile.am: New test added.
* Makefile.am, configure.ac: Changes to added above test.
* tar02/init.c, tar02/tar02.scn: New test case added: IMFS_dump().
* Makefile.am, configure.ac: Add test for rtems_print_buffer().
* dumpbuf01/.cvsignore, dumpbuf01/Makefile.am, dumpbuf01/dumpbuf01.doc,
dumpbuf01/dumpbuf01.scn, dumpbuf01/init.c: New files.
* bspcmdline01/bspcmdline01.scn, bspcmdline01/init.c: Add test cases to
improve coverage.
* tar01/Makefile.am, tar02/Makefile.am: Apply clean-local to remove
intital_fs directory.
* tar01/Makefile.am, tar02/Makefile.am: Apply TARTESTS.
* tar01/Makefile.am:
Apply $LN_S, $PAX. Use subshell for tarball creation.
Don't add initial_fs to CLEANFILES.
* tar02/Makefile.am:
* configure.ac: Add AC_PROG_LN_S.
Add AC_PATH_PROG([PAX]).
Add AM_CONDITIONAL(TARTESTS).
