* termios01/init.c: Fix parity_table_Entry type.
Correct parity_table initialization.
Add PRIdrtems_termios_baud_t.
Use PRIdrtems_termios_baud_t to print rtems_termios_baud_t's.
* rtmonuse/task1.c: Use PRIu32 to print uint32_t's.
* malloctest/init.c: Use %zu instead of %d to print size_t's.
* rtmonuse/init.c, rtmonuse/task1.c:
Use PRIxrtems_id to print rtems_ids.
* malloctest/init.c: Fix _Heap_Resize_block args.
* malloctest/init.c, termios01/init.c,
termios01/termios_testdriver.c: Eliminate unused vars.
* heapwalk/init.c: Comment out unused vars.
* termios01/termios_testdriver.c: Include <rtems/termiostypes.h.
* malloctest/init.c: Add local prototype for malloc_walk,
malloc_info.
* malloctest/task1.c: Add local prototype for malloc_walk.
* monitor02/init.c: Remove unused vars.
* stackchk01/init.c: Remove unused vars.
* heapwalk/init.c, malloctest/init.c, stackchk/blow.c,
termios/init.c: Add missing prototypes.
* configure.ac: Don't add -fasm to CFLAGS.
* block01/.cvsignore: New file.
* cpuuse/init.c, cpuuse/system.h: Use minimum stack size.
* Makefile.am, configure.ac, termios01/termios_testdriver.c: Do not use
CONSOLE_USE_INTERRUPTS. That is in use by BSPs and we should not use
it.
* termios02/.cvsignore, termios02/Makefile.am, termios02/init.c,
termios02/termios02.doc, termios02/termios02.scn: New files.
termios02 is a test for tcdrain().
* termios01/init.c, termios01/termios_testdriver.c:
Reflect changes to termios.
* cpuuse/tswitch.c: Eliminate use of deprecated rtems_extension.
* stackchk01/stackchk01.doc: Add content.
* Makefile.am, configure.ac: Add initial test for
rtems_stack_checker_is_blown.
* stackchk01/.cvsignore, stackchk01/Makefile.am, stackchk01/init.c,
stackchk01/stackchk01.doc, stackchk01/stackchk01.scn: New files.
* heapwalk/heapwalk.scn, heapwalk/init.c: Add missing _Heap_Walk test
cases to get back to 100% object coverage.
* heapwalk/init.c, heapwalk/heapwalk.scn, malloctest/init.c,
malloctest/malloctest.scn: New test cases.
* stackchk/blow.c, stackchk/stackchk.scn: Update for heap API changes.
* malloctest/init.c: New test cases. Update for heap API changes.
* stackchk/blow.c: Update for heap API changes.
* heapwalk/init.c, stackchk/blow.c: Update for heap API changes.
* termios01/init.c, termios01/termios01.scn: Add a few error paths to
complete coverage of termios_XXX_to_YYY() methods.
* Makefile.am, configure.ac: Add new test to exercise tcgetattr and
tcsetattr. Does a variety of baud, parity, stop bits, and bits per
character with the assistance of a special test driver which prints
the requests.
* termios01/.cvsignore, termios01/Makefile.am, termios01/init.c,
termios01/termios01.doc, termios01/termios01.scn,
termios01/termios_testdriver.c, termios01/termios_testdriver.h: New files.
* malloctest/task1.c, stackchk/task1.c: Eliminate test routines
TICKS_PER_SECOND and get_ticks_per_second() in favor of new
rtems_clock_get_ticks_per_second().
* cpuuse/task1.c, termios/init.c: Convert calls to legacy routine
rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* cpuuse/task1.c, cpuuse/tswitch.c, malloctest/task1.c,
stackchk/task1.c: Convert calls to legacy routine rtems_clock_get(
RTEMS_CLOCK_GET_TOD, ..) to rtems_clock_get_tod(..).
* malloctest/init.c: Adjust allocation in test so it passes now that
heap overhead constant has been increased.
* bspcmdline01/init.c: Do not violate visibility.
* bspcmdline01/bspcmdline01.scn, bspcmdline01/init.c: Add rtems_ as
prefix to all routines.
* Makefile.am, configure.ac: Add test for new BSP Boot Command Line
helper routines.
* bspcmdline01/.cvsignore, bspcmdline01/Makefile.am,
bspcmdline01/bspcmdline01.doc, bspcmdline01/bspcmdline01.scn,
bspcmdline01/init.c, bspcmdline01/test.c: New files.
* malloctest/init.c, malloctest/malloctest.scn: Add heap resize test
for shrinking a block enough to need to free the newly unused
portion.
