utf8proc is a library for processing UTF-8 encoded Unicode strings.
Some features are Unicode normalization, stripping of default ignorable characters, case folding and detection of grapheme cluster boundaries.
For now utf8proc is intended for normalizing and folding strings for comparison purposes within the UTF-8 support of the FAT file system.
This test will call interface methods of library utf8proc in order to make sure they compiled and linked ok.
The library is third party, thus it should be sufficient for us to make sure we can build it correctly.
16bit targets)
It is invalid to issue a SIZE command once a data transfer is
in progress. For reads we issue the SIZE command before the RETR
command and get a snapshot of the file size. For writes the file size
is initialized to zero and incremented for each write chunk.
New IO control RTEMS_IO_TCFLUSH.
This reduces the start-up time of the network stack.
With a 1ms tick the ticks since boot value overflows after approximately
50 days. This problem is avoided with the
rtems_clock_get_uptime_seconds() function.
Include <bsp.h> for proper BSP specific <rtems/confdefs.h>
initialization.
Add and use rtems_blkdev_request_done(). Block device transfer requests
must signal the completion status now with rtems_blkdev_request_done().
The return value of the block device IO control will be ignored for
transfer requests.
The first parameter of rtems_blkdev_request_cb is now the transfer
request structure.
Renamed rtems_blkdev_request::req_done to rtems_blkdev_request::done to
break third party drivers at compile time, otherwise this API change
would result in runtime errors.
The set block size must synchronize and purge the disk to avoid an
inconsistent cache state and data corruption. The synchronization is
optional depending on the new sync parameter. In some contexts a
synchronization must not be performed, e.g. during disk creation.
The work areas (RTEMS work space and C program heap) will be initialized
now in a separate step and are no longer part of
rtems_initialize_data_structures(). Initialization is performed with
tables of Heap_Area entries. This allows usage of scattered memory
areas present on various small scale micro-controllers.
The sbrk() support API changes also. The bsp_sbrk_init() must now deal
with a minimum size for the first memory chunk to take the configured
work space size into account.
The _Heap_Extend() has now the same signature as _Heap_Initialize().
The 4th parameter is ignored (page size in _Heap_Initialize()).
Add Heap_Area and Heap_Initialization_or_extend_handler.
Add and test _Heap_No_extend().
This helps to do a table based heap initialization and extension.
Create a table of Heap_Area elements and iterate through it. Set the
handler to _Heap_Initialize() in the first iteration and then to
_Heap_Extend().
std-header inclusion.
Formerly, mghttpd was conditional only on networking being
enabled. It uses on pthread and must also be conditional
on POSIX threads support being enabled.
This reverts commit cf42a6ea9dbb6ebee498ae8db319d3e475bcd6be.
The previous version was sub-optimal for read-ahead transfer counts of
one.
Read-ahead requests were previously executed in the context of the
reading task. This blocks the reading task until the complete read
with read-ahead transfer is finished. A read-ahead task is introduced
to off-load the read-ahead transfer. This allows the reading task to
work with the requested block more quickly. The read-ahead is triggered
after two misses of ascending consecutive blocks or a read hit of a
block read by the most-recent read-ahead transfer. The read-ahead
feature is configurable and can be disabled.
This reverts commit 0c2d8ec48a116cadb86564bc1226e308e197d4c1.
This reverts commit 87c8d8aba6a9582ca5eeacd332b5b107e26ea50f.
