for details.
In the Red-Black Tree Heap the administration data structures are not
contained in the managed memory area. This can be used for example in a
task stack allocator which protects the task stacks from access by other
tasks.
o Move rtems_bsdnet_fdToSocket() and rtems_bsdnet_makeFdForSocket() to
"cpukit/libnetworking/rtems/rtems_syscall.c".
o The rtems_bsdnet_makeFdForSocket() function is now static.
o Check in rtems_bsdnet_fdToSocket() function that the file descriptor
uses the socket handlers, otherwise an error status will be returned
and errno set to ENOTSOCK.
o New test libtests/syscall01.
New functions
o rtems_blkdev_create(), and
o rtems_blkdev_create_partition().
New test libtests/block11.
The functions
o rtems_bdbuf_get(),
o rtems_bdbuf_read(),
o rtems_bdbuf_syncdev(), and
o rtems_bdbuf_purge_dev(),
use now the disk device instead of the device identifier. This makes
bdbuf independent of rtems_disk_obtain() and rtems_disk_release(). It
is the responsiblity of the file system to obtain the disk device. This
also reduces the overhead to get a buffer.
The key for the AVL tree uses now the disk device instead of the device
identifier. The pointer is interpreted as an unsigned integer. This
reduces the memory overhead and makes the comparison operation a bit
faster.
Removed function rtems_bdbuf_purge_major(). This function was too
destructive and could have unpredictable side effects.
o A new data structure rtems_filesystem_global_location_t was
introduced to be used for
o the mount point location in the mount table entry,
o the file system root location in the mount table entry,
o the root directory location in the user environment, and
o the current directory location in the user environment.
During the path evaluation global start locations are obtained to
ensure that the current file system instance will be not unmounted in
the meantime.
o The user environment uses now reference counting and is protected
from concurrent access.
o The path evaluation process was completely rewritten and simplified.
The IMFS, RFS, NFS, and DOSFS use now a generic path evaluation
method. Recursive calls in the path evaluation have been replaced
with iteration to avoid stack overflows. Only the evaluation of
symbolic links is recursive. No dynamic memory allocations and
intermediate buffers are used in the high level path evaluation. No
global locks are held during the file system instance specific path
evaluation process.
o Recursive symbolic link evaluation is now limited by
RTEMS_FILESYSTEM_SYMLOOP_MAX. Applications can retrieve this value
via sysconf().
o The device file system (devFS) uses now no global variables and
allocation from the workspace. Node names are allocated from the
heap.
o The upper layer lseek() performs now some parameter checks.
o The upper layer ftruncate() performs now some parameter checks.
o unmask() is now restricted to the RWX flags and protected from
concurrent access.
o The fchmod_h and rmnod_h file system node handlers are now a file
system operation.
o The unlink_h operation has been removed. All nodes are now destroyed
with the rmnod_h operation.
o New lock_h, unlock_h, clonenod_h, and are_nodes_equal_h file system
operations.
o The path evaluation and file system operations are now protected by
per file system instance lock and unlock operations.
o Fix and test file descriptor duplicate in fcntl().
o New test fstests/fsnofs01.
* termios01/init.c: Update due to API changes. Fixed integer types.
Make functions static. Added const qualifier.
* math/init.c, mathf/init.c, mathl/init.c: Move configuration section.
* math/domath.c, mathf/domathf.c, mathl/domathl.c: Regenerate.
* math/domath.in: Generate domath* prototype.
* complex/init.c: Move configuration section.
* complex/docomplex.c, complex/docomplexf.c, complex/docomplexl.c:
Regenerate.
* complex/docomplex.in: Generate prototype docomplex* prototype.
* ftp01/Makefile.am:
Re-add ftpd01_LDADD (Fix breakage introduced by previous patch).
PR 1589/build
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am,
devfs04/Makefile.am, deviceio01/Makefile.am,
devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am,
gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am,
malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am,
malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am,
mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am,
tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am,
termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am,
termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional
manager capability.
* monitor02/init.c: Remove re-declaration of rtems_shell_main_monitor.
* mouse01/init.c: Account for extra message buffer size.
* ftp01/init.c: Account for extra FTP worker task stack sizes.
* malloc04/init.c: Define p1, p2, p3, p4 extern (Avoid warnings).
* mouse01/init.c, mouse01/msmouse.c, mouse01/serial_mouse_config.c:
Add HAVE_CONFIG_H.
* monitor/monitor.scn, termios/termios.scn: New files.
* monitor/init.c, termios01/init.c: Use rtems_shell_wait_for_input().
* stackchk/init.c, stackchk/system.h, stackchk/stackchk.scn: Print end
of test message.
PR 1865/tests
* stringto01/Makefile.am, stringto01/init.c, stringto01/stringto01.doc,
stringto01/stringto01.scn, stringto01/stringto_test_template.h:
Improve coverage of string conversion routines.
* POSIX/iconv.c, POSIX/iconv_open.c, POSIX/iconv_close.c: New.
* POSIX/Makefile.am: Add iconv, iconv_open, iconv_close.
* malloc04/init.c, malloc04/malloc04.scn: Remove test cases which are
obsolete.
* devfs04/Makefile.am, deviceio01/Makefile.am,
monitor02/Makefile.am, stackchk01/Makefile.am,
tar02/Makefile.am, termios01/Makefile.am,
tztest/Makefile.am: Add missing files.
* mouse01/serial_mouse_config.c: Avoid output due to execution context.
* termios08/init.c: Fixed parameter to avoid test failure.
* rtems++/Init.cc, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc: Added HAVE_CONFIG_H.
* malloc04/init.c: Fix tests broken in warning pass.
* ftp01/.cvsignore, ftp01/Makefile.am, ftp01/ftp01.doc,
ftp01/ftp01.scn, ftp01/init.c: New files.
* Makefile.am, configure.ac: Reflect changes above.
* devnullfatal01/testcase.h, malloc02/init.c, malloc04/init.c,
malloctest/init.c, termios03/termios_testdriver_polled.c,
termios04/termios_testdriver_intr.c: Remove warnings.
* tar01/init.c: Fixed integer types.
* Makefile.am, configure.ac: Add test for Mouse Parser Engine
(Microsoft Mouse paths) and Serial Mouse Driver.
* mouse01/.cvsignore, mouse01/Makefile.am, mouse01/init.c,
mouse01/mouse01.doc, mouse01/mouse01.scn, mouse01/msmouse.c,
mouse01/serial_mouse_config.c: New files.
* heapwalk/init.c: Improve coverage.
* heapwalk/heapwalk.scn: Update.
* devfs04/devfs04.scn, devfs04/init.c: Increase configuration so this
passes on sis.
* malloctest/init.c: Improve coverage.
* malloctest/malloctest.scn: Update.
* configure.ac: Add AC_CONFIG_HEADER(config.h).
* POSIX/calloc.c, POSIX/clock_gettime.c, POSIX/close.c, POSIX/dup2.c,
POSIX/fcntl.c, POSIX/flockfile.c, POSIX/fork.c, POSIX/free.c,
POSIX/fstat.c, POSIX/ftrylockfile.c, POSIX/funlockfile.c,
POSIX/getdents.c, POSIX/getlogin.c, POSIX/getpwnam.c, POSIX/getpwuid.c,
POSIX/gettimeofday.c, POSIX/getuid.c, POSIX/htonl.c, POSIX/issetugid.c,
POSIX/kill.c, POSIX/longjmp.c, POSIX/lseek.c, POSIX/lstat.c,
POSIX/malloc.c, POSIX/nanosleep.c, POSIX/open.c, POSIX/pipe.c,
POSIX/posix_memalign.c, POSIX/read.c, POSIX/readv.c, POSIX/realloc.c,
POSIX/setjmp.c, POSIX/sigaddset.c, POSIX/sigdelset.c,
POSIX/sigemptyset.c, POSIX/sigfillset.c, POSIX/sigismember.c,
POSIX/sigprocmask.c, POSIX/stat.c, POSIX/unlink.c, POSIX/vfork.c,
POSIX/wait.c, POSIX/waitpid.c, POSIX/write.c, POSIX/writev.c,
block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block08/bdbuf_test1_1.c,
block08/bdbuf_test1_2.c, block08/bdbuf_test1_3.c,
block08/bdbuf_test1_4.c, block08/bdbuf_test1_5.c,
block08/bdbuf_test2_1.c, block08/bdbuf_test2_2.c,
block08/bdbuf_test3_1.c, block08/bdbuf_test3_2.c,
block08/bdbuf_test3_3.c, block08/bdbuf_test4_1.c,
block08/bdbuf_test4_2.c, block08/bdbuf_test4_3.c, block08/bdbuf_tests.c,
block08/init.c, block09/init.c, block10/init.c, bspcmdline01/init.c,
complex/docomplex.c, complex/docomplex.in, complex/docomplexf.c,
complex/docomplexl.c, complex/init.c, cpuuse/init.c, cpuuse/task1.c,
cpuuse/task2.c, cpuuse/task3.c, cpuuse/tswitch.c, devfs01/init.c,
devfs02/init.c, devfs03/init.c, devfs04/init.c, deviceio01/init.c,
dumpbuf01/init.c, gxx01/init.c, heapwalk/init.c, malloc02/init.c,
malloc03/init.c, malloc04/init.c, malloc05/init.c, malloctest/init.c,
malloctest/task1.c, math/domath.c, math/domath.in, math/init.c,
mathf/domathf.c, mathf/init.c, mathl/domathl.c, mathl/init.c,
monitor/init.c, monitor02/init.c, putenvtest/init.c, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/task1.c, stackchk/blow.c, stackchk/init.c,
stackchk/task1.c, stackchk01/init.c, stringto01/init.c, tar01/init.c,
tar02/init.c, tar03/init.c, termios/init.c, termios01/init.c,
termios01/termios_testdriver.c, termios02/init.c, termios03/init.c,
termios03/termios_testdriver_polled.c, termios04/init.c,
termios04/termios_testdriver_intr.c, termios05/init.c,
termios05/termios_testdriver_taskdriven.c, termios06/init.c,
termios06/test_pppd.c, termios07/init.c, termios08/init.c,
tztest/init.c: Add HAVE_CONFIG_H.
* math/init.c, mathf/init.c, mathl/init.c: Now run.
* complex/Makefile.am, complex/init.c: Test now runs.
* monitor/Makefile.am, monitor02/Makefile.am: Switch to all managers
since this is all of them.
* stringto01/init.c: Redefine LONG_LONG_MAX and LONG_LONG_MIN
for c99.
* cpuuse/tswitch.c: Shrink memory requirements.
