* malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.
* termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* cpuuse/system.h, cpuuse/task1.c, cpuuse/tswitch.c, monitor/init.c,
monitor/system.h, rtems++/System.h, rtems++/Task1.cc,
rtems++/Task2.cc, rtems++/Task3.cc, rtmonuse/init.c,
rtmonuse/system.h, rtmonuse/task1.c, stackchk/blow.c: Convert to
using c99 fixed size types.
* configure.ac: Add 2nd arg to RTEMS_TOP.
* cpuuse/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES.
* malloctest/Makefile.am: Ditto.
* monitor/Makefile.am: Ditto.
* putenvtest/Makefile.am: Ditto.
* rtems++/Makefile.am: Ditto.
* rtmonuse/Makefile.am: Ditto.
* stackchk/Makefile.am: Ditto.
* termios/Makefile.am: Ditto.
* libtests.am: Add dirstamp support.
* libtests.am: Use $(mkdir_p) instead of $(mkinstalldirs).
PR 544/tests
* malloctest/system.h, rtmonuse/system.h: Various modifications to make
tests account for resources and not print at inappropriate times.
* cpuuse/Makefile.am: Remove all-local: $(ARCH).
* malloctest/Makefile.am: Remove all-local: $(ARCH).
* monitor/Makefile.am: Remove all-local: $(ARCH).
* putenvtest/Makefile.am: Remove all-local: $(ARCH).
* rtems++/Makefile.am: Remove all-local: $(ARCH).
* rtmonuse/Makefile.am: Remove all-local: $(ARCH).
* stackchk/Makefile.am: Remove all-local: $(ARCH).
* termios/Makefile.am: Remove all-local: $(ARCH).
* configure.ac: Reflect having moved to testsuites/.
* configure.ac: Remove RTEMS_CANONICAL_HOST.
* configure.ac:Remove RTEMS_CHECK_CPU.
* cpuuse/init.c, cpuuse/system.h, cpuuse/task1.c, cpuuse/task2.c,
cpuuse/task3.c, cpuuse/tswitch.c, malloctest/init.c,
malloctest/system.h, malloctest/task1.c, monitor/init.c,
monitor/system.h, putenvtest/init.c, rtems++/Init.cc,
rtems++/System.h, rtems++/Task1.cc, rtems++/Task2.cc,
rtems++/Task3.cc, rtems++/rtems++.doc, rtmonuse/getall.c,
rtmonuse/init.c, rtmonuse/system.h, rtmonuse/task1.c,
stackchk/blow.c, stackchk/init.c, stackchk/system.h,
stackchk/task1.c: URL for license changed.
cpuuse/Makefile.am: Reflect having moved automake.
malloctest/Makefile.am: Reflect having moved automake.
monitor/Makefile.am: Reflect having moved automake.
putenvtest/Makefile.am: Reflect having moved automake.
rtems++/Makefile.am: Reflect having moved automake.
rtmonuse/Makefile.am: Reflect having moved automake.
stackchk/Makefile.am: Reflect having moved automake.
termios/Makefile.am: Reflect having moved automake.
* configure.ac: Unconditionally check for CXX.
Require autoconf-2.57, automake-1.7.2.
* rtems++: Eliminate CC_O_FILES.
* malloctest/init.c: Tasks should be floating point.
* .cvsignore: Reformat.
Add autom4te*cache.
Remove autom4te.cache.
* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c,
rtmonuse/task1.c, termios/init.c: Modified.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Make sure debug variant of librtems++
is linked against. Reported by Jerry Needell <jerry.needell@unh.edu>
and processed as PR78.
* rtems++/Makefile.am: Pick up -lrtems++ even when debug.
* configure.in: Remove.
* libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* rtems++/Makefile: Remove LD_LIBS.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and now must
be referenced as <rtems/XXX.h>.
* libtests.am: Remove DEFS.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is a hack to workaround a switch generation compiler bug for the
SH2 and cleaned up some warnings.
significant things:
and PowerPC
same code base.
