* tar01/Makefile.am, tar02/Makefile.am: Fix dependencies for parallel
build.
* tar01/Makefile.am, tar02/Makefile.am: Replace mkdir cascade
with $(MKDIR_P).
* tar01/Makefile.am, tar02/Makefile.am: Misc. fixes.
* tar01/Makefile.am, tar03/Makefile.am: Remove MANAGERS.
PR 1532/testing
* Makefile.am, configure.ac: Add initial tests for untar capabilities.
* tar01/.cvsignore, tar01/Makefile.am, tar01/init.c, tar01/tar01.doc,
tar01/tar01.scn, tar02/.cvsignore, tar02/Makefile.am, tar02/init.c,
tar02/tar02.doc, tar02/tar02.scn: New files.
PR 1631/testing
* gxx02/init.c, gxx02/gxx02.scn, gxx02/gxx02.doc,
gxx02/Makefile.am, gxx02/gxx_wrappers.h: New test added
* Makefile.am, configure.ac: Changes to accommodate new tests
PR 1632/testing
* Makefile.am, configure.ac: Make dedicated fatal error test for
/dev/null already registered. Using code from Bharath in new test
framework.
* devnullfatal01/.cvsignore, devnullfatal01/Makefile.am,
devnullfatal01/devnullfatal01.doc, devnullfatal01/devnullfatal01.scn,
devnullfatal01/testcase.h: New files.
PR 1632/testing
* devfs04/init.c, devfs04/test_driver.c: Added cases to exercise
null_initialize() and null_write().
* gxx01/gxx01.scn, gxx01/init.c: Remove local _exit().
* gxx01/gxx01.scn, gxx01/init.c: Add test f0r rtems_gxx_key_dtor().
* gxx01/gxx01.scn, gxx01/init.c: Add more testcases.
* devfs02/init.c, devfs02/devfs02.doc, devfs02/devfs02.scn,
devfs02/Makefile.am: New tests added
* devfs03/init.c, devfs03/devfs03.doc, devfs03/devfs03.scn,
devfs03/Makefile.am: New tests added
* devfs04/init.c, devfs04/devfs04.doc, devfs04/devfs04.scn,
devfs04/Makefile.am: New tests added
* Makefile.am, configure.ac: Changes to accommodate the above
newly added tests.
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for
XON/XOFF and VMIN/VMAX cases.
* termios07/.cvsignore, termios07/Makefile.am, termios07/init.c,
termios07/termios07.doc, termios07/termios07.scn,
termios08/.cvsignore, termios08/Makefile.am, termios08/init.c,
termios08/termios08.doc, termios08/termios08.scn: New files.
* Makefile.am, configure.ac: Add tar test for error cases.
* tar03/.cvsignore, tar03/Makefile.am, tar03/init.c, tar03/tar03.doc,
tar03/tar03.scn: New files.
* stringto01/init.c, stringto01/stringto01.scn,
stringto01/stringto_test_template.h: Attempt to pick up a few more
error paths.
PR 1617/testing
* malloctest/init.c: Added new case to exercise _realloc_r.
* malloctest/init.c: Added test for
rtems_heap_allocate_aligned_with_boundary().
* Makefile.am, configure.ac: Add new test to exercise devFS_Show().
* devfs01/.cvsignore, devfs01/Makefile.am, devfs01/devfs01.doc,
devfs01/devfs01.scn, devfs01/init.c: New files.
malloc_get_statistics().
* malloc05/.cvsignore, malloc05/Makefile.am, malloc05/init.c,
malloc05/malloc05.doc, malloc05/malloc05.scn: New files.
PR 1535/tests
* malloc04/init.c, malloc04/malloc04.scn: Address issues in test. A mix
of work by Ralf and Joel.
* termios01/init.c, termios01/termios01.scn: Fully exercise tcsetattr.
* Makefile.am, configure.ac: Add test for exercising sbrk() extension
to Malloc Family.
* malloc04/.cvsignore, malloc04/Makefile.am, malloc04/init.c,
malloc04/malloc04.doc, malloc04/malloc04.scn: New files.
* termios06/init.c, termios06/termios06.scn: Add a couple more PPPDISC
cases. Coverage of these paths is near complete.
* malloctest/system.h: Enable malloc statistics.
* Makefile.am, configure.ac: tar01 and tar02 not merged yet.
* Makefile.am, configure.ac, malloc03/init.c: Add test for PPPDDISC.
* termios06/.cvsignore, termios06/Makefile.am, termios06/init.c,
termios06/termios06.doc, termios06/termios06.scn,
termios06/test_pppd.c: New files.
* Makefile.am, configure.ac: Add test for GCC C++ library helpers.
* gxx01/.cvsignore, gxx01/Makefile.am, gxx01/gxx01.doc,
gxx01/gxx01.scn, gxx01/gxx_wrappers.h, gxx01/init.c: New files.
* termios04/termios_testdriver_intr.c: Task driven IO now works.
* Makefile.am, configure.ac: Add test for task driven drivers.
* termios05/.cvsignore, termios05/Makefile.am, termios05/init.c,
termios05/termios05.doc, termios05/termios05.scn,
termios05/termios_testdriver_taskdriven.c,
termios05/termios_testdriver_taskdriven.h: New files.
* Makefile.am, configure.ac: Revert changes related to uncommitted test
under development.
* Makefile.am, configure.ac, malloctest/init.c, termios03/init.c,
termios03/termios03.scn: Handle some of the VKILL and VERASE cases.
* Makefile.am, configure.ac: Add new test to exercise termios RX and TX
interrupt driven IO support.
* termios04/.cvsignore, termios04/Makefile.am, termios04/init.c,
termios04/termios04.doc, termios04/termios04.scn,
termios04/termios_testdriver_intr.c,
termios04/termios_testdriver_intr.h: New files.
* termios03/init.c, termios03/termios03.doc, termios03/termios03.scn,
termios03/termios_testdriver_polled.c,
termios03/termios_testdriver_polled.h: Add more test cases.
* malloc02/Makefile.am, malloc03/Makefile.am: Tests do not need spin.c
* termios03/.cvsignore, termios03/Makefile.am, termios03/init.c,
termios03/termios_testdriver_polled.h: New files.
* Makefile.am, configure.ac: Add initial version of new test for polled
IO support in termios.
* block01/Makefile.am, block02/Makefile.am, block03/Makefile.am,
block04/Makefile.am, block05/Makefile.am, block06/Makefile.am,
block07/Makefile.am, block08/Makefile.am, block09/Makefile.am,
block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am,
heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am,
stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am,
termios02/Makefile.am: Revert.
* termios01/termios01.scn: Fix bug so existing test code for
rtems_termios_baud_to_index() is executed.
termios01/init.c, termios02/Makefile.am: Fix bug so existing test
code for rtems_termios_baud_to_index() is executed.
* stackchk/blow.c, stackchk/stackchk.scn: Print a stack check report
before blowing stack.
* Makefile.am, configure.ac: Added test that attempts to free stack
memory. This causes a error to be printed from the free function.
* malloc03/.cvsignore, malloc03/Makefile.am, malloc03/init.c,
malloc03/malloc03.doc, malloc03/malloc03.scn: New files.
* malloctest/init.c: Added error case with malloc of size 0.
* malloctest/init.c: Added test to check failure branch on calloc.
* malloc02/init.c, malloc02/malloc02.doc: Enable malloc dirty helper.
* Makefile.am, configure.ac: Add test for deferring free() from ISR and
for deferred free() processing.
* malloc02/.cvsignore, malloc02/Makefile.am, malloc02/init.c,
malloc02/malloc02.doc, malloc02/malloc02.scn: New files.
* termios01/init.c, termios01/termios01.scn, termios02/init.c,
termios02/termios02.scn: Add tests for cfigetspeed(), cfogetspeed(),
cfisetspeed(), cfosetspeed(), ctermid(), tcflow(), tcflush(),
tcsendbreak(), tcsetpgrp(), and tcgetpgrp(). Some of these methods
are minimal implementations so the tests will have to grow as the
methods grow.
* heapwalk/init.c, malloctest/init.c: Update for heap extend changes.
PR 1433/cpukit
* block08/bdbuf_tests.c: Enabled tests 1.1, 1.2 and 1.3.
* block08/bdbuf_test1_1.c, block08/bdbuf_test1_2.c,
block08/bdbuf_test1_3.c: Use RTEMS_IO_ERROR instead of
RTEMS_NO_MEMORY.
* block01/init.c, block02/init.c, block03/init.c, block04/init.c,
block05/init.c, block06/init.c, block07/init.c, block09/init.c,
block10/init.c: Changed CONFIGURE_MAXIMUM_SEMAPHORES defines.
