An invalid heap usage such as a double free is usually a fatal error
since this indicates a use after free. Replace the use of printk() in
free() with a fatal error.
Update #3437.
Update #3358.
Update #3358.
Move FTP client filesystem to separate library libftpfs.a.
Update #3419.
Always build remote TCP support since it depends only on the POSIX
socket API. It works with the legacy network stack and libbsd. Move it
to a separate libdebugger.a library to allow an easy use with libbsd via
"-ldebugger -lbsd" otherwise we would have a cyclic dependency between
libbsd.a and librtemscpu.a.
Update #3419.
Update #3409.
This test loads a RAP format file that contains calls that are not
in the kernel and linked from libm. It uses and test rtems-ld.
Update #2769
upgrade to that version.
Close #3387.
Update #3382
Update #2843.
Update #2843.
Update #2840.
line option.
may suppress warnings.
erc32, imx, qoriq, etc.
* cpukit/include
* cpukit/libnetworking
* bsps/include
* bsps/@RTEMS_CPU@/include
order.
Update #3254.
This test uses sprintf().
Update #3082.
Update #3082.
Update #3239.
The link time wrap of printf leads to unresolved symbols in the loadable
modules. This resulted in infinite loops and test timeouts. Use
rtems_printf() for output.
Update #3199.
- Remove the macro defines and the need for tmacro.h by remapping the
symbols using ld's wrap option.
- Remove FLUSH_OUTPUT, it was empty.
- Move rtems_test_exit to libmisc/testsupport as a function.
Update #3199.
In canonical mode, input is made available line by line. We must stop
the canonical buffer filling upon reception of an end-of-line character.
Close #3218.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
CONFIGURE_INIT appropriately.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Use rtems_print_printer_fprintf_putc() instead of
rtems_print_printer_printf() to output via rtems_putc().
Update #3170.
Update #3199.
Update #3170.
Update #3199.
Statically initialize it to use printk().
Update #3170.
Update #3199.
call to printk.
Updates #3170.
Update #3136.
These tests directly or indirectly use fprintf(), etc. which may use the
floating point unit.
Update #3076.
Update #3076.
With global stdio streams, a freopen() would close the global stream
object.
Update #3012.
