* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Make sure debug variant of librtems++
is linked against. Reported by Jerry Needell <jerry.needell@unh.edu>
and processed as PR78.
* rtems++/Makefile.am: Pick up -lrtems++ even when debug.
* configure.in: Remove.
* libtests.am: Use TMPINSTALL_FILES = to make automake-1.5 happy.
* rtems++/Makefile.am: LD_FLAGS = -lrtems++.
* rtems++/Makefile: Remove LD_LIBS.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* malloctest/task1.c: assoc.h, error.h, libio_.h, libio.h, and
libcsupport.h moved from libc to lib/include/rtems and now must
be referenced as <rtems/XXX.h>.
* libtests.am: Remove DEFS.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
cpuopts.h.
exec/configure.in, only.
quoting bugs in autoconf).
formating changes :)
that is a hack to workaround a switch generation compiler bug for the
SH2 and cleaned up some warnings.
significant things:
and PowerPC
same code base.
I have a few patches for the efi332 bsp. If you let me know when you
expect the next snapshot release, I will try to have them to you
before then. Also, the malloctest has some problems that I would think
would prevent it from running on almost any platform. I have enclose
patches below to fix (1) Task_id and Task_name dimensioning, (2) end
of test message, (3) the amount of memory malloc'ed, and (4) retry on
unsuccessful (out of memory) molloc's.
more accurate.
enclose.
tasks table.
