path: root/testsuites/libtests (follow)
* new test submitted by Craig Lebakken (lebakken@minn.net) and Derrick OstertagJoel Sherrill1996-09-183-0/+230
| | | | (ostertag@transition.com)
* tests now specify whether using posix initialization threads tableJoel Sherrill1996-05-291-0/+2
| | | | or rtems initialization table in configuration table
* The word "RTEMS" almost completely removed from the core.Joel Sherrill1995-09-114-9/+53
* Initial revisionJoel Sherrill1995-05-115-0/+199
