The $(PAX) variable is used unconditionally so it shouldn't be
left empty if not found at configure time. Fixes #2437.
Remove unused descriptor of merged free chunks from the free chain and
add them to the spare descriptors.
Update #2417.
Update #2417.
Drop the <rtems/score/percpu.h> include since this file exposes a lot of
implementation details.
Add rtems_interrupt_local_disable|enable() as suggested by Pavel Pisa to
emphasize that interrupts are only disabled on the current processor.
Do not define the rtems_interrupt_disable|enable|flash() macros and
functions on SMP configurations since they don't ensure system wide
mutual exclusion.
Deprecate Classic API Notepads. Mark task_set/get_note() with
the deprecated attribute, and also mark the notepads field.
Replace disable with enable option for notepads in confdefs.h,
and make notepads disabled by default. The previous option
CONFIGURE_DISABLE_CLASSIC_API_NOTEPADS is now unused and
will emit a compile-time warning. A new option
CONFIGURE_ENABLE_CLASSIC_API_NOTEPADS is available to turn
on notepads, but it also will emit a compile-time warning
to indicate that notepads are deprecated.
Closes #2265
The h8300 gets a linking error for the dl0* tests. This temporarily
disables libdl until that can be investigated.
updates 2284.
There is a GCC ICE when building libdl. This temporarily disables
building libdl until that is resolved.
updates 2283.
There is an issue linking dl0* which has not been resolved.
This issue is being tracked but is not considered a release
blocker. This patch is a workaround which disables libdl
for the v850 until the ticket is resolved.
updates 2260.
for the bfin until the ticket is resolved.
updates 2252.
Remove miniIMFS. Statically initialize the root IMFS.
Add configuration options to disable individual
features of the root IMFS, e.g.
o CONFIGURE_IMFS_DISABLE_CHOWN,
o CONFIGURE_IMFS_DISABLE_FCHMOD,
o CONFIGURE_IMFS_DISABLE_LINK,
o CONFIGURE_IMFS_DISABLE_MKNOD,
o CONFIGURE_IMFS_DISABLE_MOUNT,
o CONFIGURE_IMFS_DISABLE_READLINK,
o CONFIGURE_IMFS_DISABLE_RENAME,
o CONFIGURE_IMFS_DISABLE_RMNOD,
o CONFIGURE_IMFS_DISABLE_SYMLINK,
o CONFIGURE_IMFS_DISABLE_UNMOUNT, and
o CONFIGURE_IMFS_DISABLE_UTIME.
This reduces the average node size.
Add and use IMFS_GENERIC_INITIALIZER().
Send a special event to notify tasks waiting for a socket state change
in case this socket gets closed. This prevents a use after free.
Close #785.
The dummy.c was a de-facto default configuration. Rename it to
default-configuration.c. Use unlimited objects and the stack checker.
This makes it easier for new RTEMS users which will likely use this file
if they just work with the usual main() function as the application
entry point. Provide proper arguments for main() using the BSP command
line. Add spare user extensions and drivers.
Do not initialize the network by default. Delete bspinit.c.
The LEON3 BSP have support for up to 8 termios consoles, the
LEON3-FT GR712RC uses 6 UARTs.
This does not take into account the BSP maximum devices instead
it is hardcoded to 6. This patch increases it the maximum
devices of DEVFS04 from 6 to 10.
For constant arguments GCC calculates the values of the math library
functions at compile-time.
close #1741
Use the heap handler statistics instead. Add heap walk option to MALLOC
shell command.
close #1367
The functionality was conditionally compiled into a shared file
and these were not removed.
close #1821
posix_memalign() is prototyped to take a non-NULL parameter. But our
test is deliberately passing one in. With the -Wnon-null warning flag
enabled, we will always get warnings on this test unless we disable
that warning for this single test case.
Use '*" to disable shell login instead of '!' according to the Linux man
page. Use getpwnam_r() instead of getpwnam(). Do not access the user
environment directly. Update the user environment only after a
successful login check.
Add crypt_add_format(), crypt_r(), crypt_md5_r(), crypt_sha256_r() and
crypt_sha512_r().
This I2C driver framework has some major differences compared to libi2c.
* It is compatible to the Linux I2C user-space API.
* It uses generic IMFS nodes and thus reduces the levels of indirection.
* The drivers don't have to mess around with minor numbers to get their
state information.
* No arbitrary bus controller model is assumed. The main task of an I2C
bus controller driver is to process I2C messages. How this is done is
private to the driver.
* Scatter/gather operations are supported (I2C_M_NOSTART).
This should have been added.
