* malloctest/init.c: Convert to "bool".
* rtems++/System.h: Account for extra task stacks properly.
* malloctest/init.c: Fix return status check.
* cpuuse/init.c, malloctest/init.c, monitor/init.c, monitor02/init.c,
putenvtest/init.c, rtems++/Init.cc, rtmonuse/init.c, stackchk/init.c:
Change TEST_INIT to CONFIGURE_INIT. Make tmacros.h available to all
POSIX tests. Add a clock_settime case for < 1988.
* malloctest/init.c: Add more test cases to cover heap better.
* malloctest/init.c: Add new test cases per Sergei. Make some of the
stranger cases operate directly on a freshly initialized heap. This
should make them more reproducible.
* malloctest/init.c: Add more tests per suggestions from Sergei
Organov.
* malloctest/init.c: Add include to remove warning.
* malloctest/init.c: Remove debug print.
* monitor02/.cvsignore: New file.
* Makefile.am, configure.ac: Added automatic test for monitor shell
* monitor02/Makefile.am, monitor02/init.c, monitor02/monitor02.scn,
monitor02/system.h: New files.
* malloctest/init.c: Add test cases suggested by Sergei Organov
<s.organov@javad.com>.
* malloctest/init.c, malloctest/task1.c: Add test for posix_memalign.
* rtmonuse/init.c, rtmonuse/task1.c: Add period which is unused to
exericise another path in the period statistics code.
* malloctest/init.c: Add some primitive testing of realloc() which also
does some positive path testing on the SuperCore heap.
* cpuuse/task2.c, rtmonuse/rtmonuse.scn, rtmonuse/task1.c: Add new
cases for untested routines.
* cpuuse/init.c: Do not delete the Init task. Leaving it suspended lets
the CPU Usage Report include it. If it is deleted, the CPU time it
had consumed is not listed later in the report.
* tztest/init.c: Build when using buffered test IO.
* ChangeLog, rtmonuse/task1.c: Clean up output and use FLUSH_OUTPUT()
macro instead of fflush() directly.
* rtmonuse/init.c, rtmonuse/task1.c: Integrate Rate Monotonic
Statistics and Period Usage into Rate Monotonic Manager. Added the
following directives: rtems_rate_monotonic_get_statistics,
rtems_rate_monotonic_reset_statistics,
rtems_rate_montonic_reset_all_statistics,
rtems_rate_montonic_report_statistics, and rtems_object_get_name.
Obsoleted the rtems/rtmonuse.h file as a public interface.
* cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add
optional managers to Makefiles. Clean up test cases so last output
line follows END OF pattern. Make sure test case all run. All tests
appeared ok on sis.
* monitor/init.c, rtmonuse/task1.c: Use rtems_task_argument.
* tztest/init.c: Call tzset() even though it may be called for us
implicitly along the way.
* tztest/.cvsignore: New file.
* Makefile.am, configure.ac: Added timezone test.
* tztest/Makefile.am, tztest/init.c, tztest/tztest.doc,
tztest/tztest.scn: New files.
* malloctest/init.c: Be explicit about need for default and floating
point attributes. This is just a style change.
* rtems++/Task1.cc, rtems++/Task3.cc: Address size_t/uint32_t typing
issues in message queue tests.
* cpuuse/Makefile.am, malloctest/Makefile.am, rtems++/Makefile.am,
rtmonuse/Makefile.am, stackchk/Makefile.am: Eliminate scndir,
docdir. Use rtems_testsdir instead.
* rtems++/Task1.cc: Fix warnings.
* configure.ac: Remove RTEMS_ENABLE_BARE,
BARE_CPU_CFLAGS, BARE_CPU_MODEL.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
Convert to using *_PROGRAMS.
* malloctest/Makefile.am: Rework.
* monitor/Makefile.am: Rework.
* putenvtest/Makefile.am: Rework.
* rtems++/Makefile.am: Rework.
* rtmonuse/Makefile.am: Rework.
* stackchk/Makefile.am: Rework.
* termios/Makefile.am: Rework.
stackchk/Makefile.am, termios/Makefile.am: Expand libtests.am.
* libtests.am: Remove.
