* | libtests/ttest01: Fix typos | Sebastian Huber | 2019-10-02 | 1 | -3/+3 |
* | ttest01: New test | Sebastian Huber | 2019-03-27 | 1 | -0/+19 |
This is an example test using the RTEMS Test Framework. It tests also the framework itself. Add T_FILE_NAME command line define to get rid of the full file path. This is important to reduce the read-only data of test files and make them build system independent. Update #3199. |
