2023-05-20 | Update company name | Sebastian Huber | 1 | -1/+1 | |
The embedded brains GmbH & Co. KG is the legal successor of embedded brains GmbH. | |||||
2020-07-23 | libtest: Move <t.h> to <rtems/test.h> | Sebastian Huber | 1 | -1/+1 | |
Update #3199. | |||||
2019-10-11 | ttest01: Add test outputs all test cases | Mikail Yayla | 1 | -0/+7 | |
2019-10-11 | ttest01: Add more test cases | Sebastian Huber | 1 | -20/+4 | |
2019-10-11 | ttest01: Adjust SPDX-License-Identifier | Sebastian Huber | 1 | -2/+7 | |
2019-03-27 | ttest01: New test | Sebastian Huber | 1 | -26/+32 | |
This is an example test using the RTEMS Test Framework. It tests also the framework itself. Add T_FILE_NAME command line define to get rid of the full file path. This is important to reduce the read-only data of test files and make them build system independent. Update #3199. | |||||
2019-03-27 | Add RTEMS Test Framework | Sebastian Huber | 1 | -10/+18 | |
2019-01-10 | memalign: Add missing attributes to fix warning | Sebastian Huber | 1 | -1/+3 | |
Update #3666. | |||||
2018-12-21 | Add aligned_alloc() and memalign() | Sebastian Huber | 1 | -3/+8 | |
Ensure that the C++17 aligned new operator works. Close #3666. | |||||
2018-12-14 | score: Static Objects_Information initialization | Sebastian Huber | 1 | -14/+6 | |
Statically allocate the objects information together with the initial set of objects either via <rtems/confdefs.h>. Provide default object informations with zero objects via librtemscpu.a. This greatly simplifies the workspace size estimate. RTEMS applications which do not use the unlimited objects option are easier to debug since all objects reside now in statically allocated objects of the right types. Close #3621. | |||||
2018-12-11 | psxhdrs/: Changed boilerplate licenses to BSD-2 (GCI 2018) | zehata | 1 | -12/+23 | |
2018-12-08 | psxhdrs: Added POSIX Compliance Test for wchar.h (GCI 2018) | zehata | 1 | -7/+4 | |
2018-12-06 | Added POSIX Compliance Test for <ctype.h> (GCI 2018) | zehata | 1 | -7/+6 | |
2018-12-05 | POSIX Compliance Signature Test for glob.h (GCI 2018) | ABR290B | 1 | -7/+9 | |
2018-12-05 | psxhdrs: Fix spacing | Joel Sherrill | 1 | -16/+16 | |
2018-12-05 | psxhdrs: POSIX API Signature Compliance Tests for assert.h (GCI 2018) | Jacob Shin | 1 | -6/+4 | |
2018-12-04 | psxhdrs: POSIX API Signature Compliance Tests for ulimit.h (GCI 2018) | Jacob Shin | 1 | -5/+6 | |
2018-12-04 | psxhdrs: Implement POSIX API Signature Compliance Tests for iconv.h (GCI 2018) | Jacob Shin | 1 | -4/+6 | |
2018-12-03 | psxhdrs: Implement POSIX API Signature Compliance Tests for fnmatch.h (GCI 2018) | Jacob Shin | 1 | -14/+7 | |
GCI Username: deuteriumoxide | |||||
2018-12-02 | psxhdrs:Add POSIX conformance test for utime.h (GCI 2018) | Shashvat Jain | 1 | -15/+17 | |
2018-11-27 | psxtests: add POSIX API signature compliance tests for dirent.h file (GCI 2018) | Himanshu40 | 1 | -0/+39 | |
