path: root/testsuites/libtests/termios (follow)
* tests/libtests: Use <rtems/test.h>Sebastian Huber2014-03-201-3/+7
* libtmtests - Eliminate missing prototype warningsJoel Sherrill2012-05-111-16/+35
* Remove All CVS Id Strings Possible Using a ScriptJoel Sherrill2012-05-113-10/+0
* Revert: Remove CVS IdsJoel Sherrill2012-05-071-0/+5
* Remove CVS-Ids.Ralf Corsépius2012-05-041-5/+0
* Remove all .cvsignore files.Joel Sherrill2012-02-011-2/+0
* 2011-12-08 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2011-12-081-3/+1
| | | | | | | | | | | | | | | | | | | | | | PR 1589/build * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, devfs01/Makefile.am, devfs02/Makefile.am, devfs03/Makefile.am, devfs04/Makefile.am, deviceio01/Makefile.am, devnullfatal01/Makefile.am, dumpbuf01/Makefile.am, ftp01/Makefile.am, gxx01/Makefile.am, heapwalk/Makefile.am, malloc02/Makefile.am, malloc03/Makefile.am, malloc04/Makefile.am, malloc05/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, mouse01/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, tar01/Makefile.am, tar02/Makefile.am, tar03/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am, termios03/Makefile.am, termios04/Makefile.am, termios05/Makefile.am, termios06/Makefile.am, termios07/Makefile.am, termios08/Makefile.am, tztest/Makefile.am: Remove obsolete optional manager capability.
* 2011-09-16 Sebastian Huber <Sebastian.Huber@embedded-brains.de>Sebastian Huber2011-09-162-47/+90
| | | | | * monitor/monitor.scn, termios/termios.scn: New files. * monitor/init.c, termios01/init.c: Use rtems_shell_wait_for_input().
* Add HAVE_CONFIG_H.Ralf Corsepius2011-02-221-0/+4
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-0/+1
| | | | | | | | | | | | * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios02/Makefile.am: Revert.
* 2010-06-23 Joel Sherrill <joel.sherrilL@OARcorp.com>Joel Sherrill2010-06-231-1/+0
| | | | | | | | | | | | | * block01/Makefile.am, block02/Makefile.am, block03/Makefile.am, block04/Makefile.am, block05/Makefile.am, block06/Makefile.am, block07/Makefile.am, block08/Makefile.am, block09/Makefile.am, block10/Makefile.am, bspcmdline01/Makefile.am, cpuuse/Makefile.am, heapwalk/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, monitor02/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, stackchk01/Makefile.am, stringto01/Makefile.am, termios/Makefile.am, termios01/Makefile.am, termios01/init.c, termios02/Makefile.am: Fix bug so existing test code for rtems_termios_baud_to_index() is executed.
* Remove sh2 hacks.Ralf Corsepius2009-11-011-8/+1
* Eliminate TRUE/FALSE, use bool instead of int.Ralf Corsepius2009-10-301-6/+7
* Add missing prototypes.Ralf Corsepius2009-10-261-3/+3
* 2009-08-10 Joel Sherrill <joel.sherrill@oarcorp.com>Joel Sherrill2009-08-101-3/+3
| | | | | * cpuuse/task1.c, termios/init.c: Convert calls to legacy routine rtems_clock_get( RTEMS_CLOCK_GET_xxx, ..) to rtems_clock_get_xxx().
* Eliminate _exe_/.exe.Ralf Corsepius2009-04-031-7/+7
* 2007-05-11 Joel Sherrill <joel.sherrill@OARcorp.com>Joel Sherrill2007-05-111-1/+1
| | | | | | | | * cpuuse/Makefile.am, malloctest/Makefile.am, putenvtest/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Add optional managers to Makefiles. Clean up test cases so last output line follows END OF pattern. Make sure test case all run. All tests appeared ok on sis.
* Convert to using *_PROGRAMS.Ralf Corsepius2005-11-131-11/+7
* Rework.Ralf Corsepius2005-11-111-22/+4
* Cosmetics.Ralf Corsepius2005-11-111-3/+0
* Eliminate TEST.Ralf Corsepius2005-11-111-4/+3
* Expand libtests.am.Ralf Corsepius2005-11-111-1/+13
* Eliminate DOCTYPES.Ralf Corsepius2005-11-101-2/+1
* AM_CPPFLAGS += -I..../support/include.Ralf Corsepius2005-11-091-0/+2
* Remove SRC, PRINT_SRC.Ralf Corsepius2005-11-071-2/+0
* Switch back to include compile.am instead of amcompile.amRalf Corsepius2005-11-071-1/+1
* Partial conversion to automake.Ralf Corsepius2005-11-071-9/+6
* 2004-11-22 Ralf Corsepius <ralf_corsepius@rtems.org>Ralf Corsepius2004-11-221-3/+3
| | | | | | | * configure.ac: Remove -ansi to prevent folks from further damaging the code with broken prototypes. * putenvtest/init.c: Remove broken putenv prototype. * termios/init.c (print_c_cc): Don't loop over NCCS.
* Remove stray white spaces.Ralf Corsepius2004-04-201-81/+81
* Remove stray white spaces.Ralf Corsepius2004-04-151-1/+0
* * cpuuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>.Ralf Corsepius2004-04-011-1/+1
| | | | | | | | | | * malloctest/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * monitor/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * putenvtest/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>. * rtems++/System.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * rtmonuse/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * stackchk/system.h: Include <rtems/confdefs.h> instead of <confdefs.h>. * termios/init.c: Include <rtems/confdefs.h> instead of <confdefs.h>.
* 2004-01-14 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2004-01-141-0/+2
| | | | | | | | | | | | * cpuuse/Makefile.am: Re-add dirstamps to PRE/TMPINSTALL_FILES. Add PRE/TMPINSTALL_FILES to CLEANFILES. * malloctest/Makefile.am: Ditto. * monitor/Makefile.am: Ditto. * putenvtest/Makefile.am: Ditto. * rtems++/Makefile.am: Ditto. * rtmonuse/Makefile.am: Ditto. * stackchk/Makefile.am: Ditto. * termios/Makefile.am: Ditto.
* 2003-12-01 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-12-011-2/+1
| | | | | | | | | | | * cpuuse/Makefile.am: Remove all-local: $(ARCH). * malloctest/Makefile.am: Remove all-local: $(ARCH). * monitor/Makefile.am: Remove all-local: $(ARCH). * putenvtest/Makefile.am: Remove all-local: $(ARCH). * rtems++/Makefile.am: Remove all-local: $(ARCH). * rtmonuse/Makefile.am: Remove all-local: $(ARCH). * stackchk/Makefile.am: Remove all-local: $(ARCH). * termios/Makefile.am: Remove all-local: $(ARCH).
* 2003-08-16 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2003-08-161-3/+3
| | | | | | | | | | | | Makefile.am: Reflect having moved automake. cpuuse/Makefile.am: Reflect having moved automake. malloctest/Makefile.am: Reflect having moved automake. monitor/Makefile.am: Reflect having moved automake. putenvtest/Makefile.am: Reflect having moved automake. rtems++/Makefile.am: Reflect having moved automake. rtmonuse/Makefile.am: Reflect having moved automake. stackchk/Makefile.am: Reflect having moved automake. termios/Makefile.am: Reflect having moved automake.
* PR298. Made raw_input static.Chris Johns2002-10-311-1/+1
* 2002-08-11 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Ralf Corsepius2002-08-111-1/+1
| | | | | | | | | | | * cpuuse/Makefile.am: Use $(OBJEXT) instead of .o. * malloctest/Makefile.am: Use $(OBJEXT) instead of .o. * monitor/Makefile.am: Use $(OBJEXT) instead of .o. * putenvtest/Makefile.am: Use $(OBJEXT) instead of .o. * rtems++/Makefile.am: Use $(OBJEXT) instead of .o. * rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o. * stackchk/Makefile.am: Use $(OBJEXT) instead of .o. * termios/Makefile.am: Use $(OBJEXT) instead of .o.
* 2002-08-01 Joel Sherrill <joel@OARcorp.com>Joel Sherrill2002-08-021-5/+7
| | | | | | | | | | | | * Per PR47 add support for buffered test output. This involved adding defines to redirect output to a buffer and dump it when full, at "test pause", and at exit. To avoid problems when redefining exit(), all tests were modified to call rtems_test_exit(). Some tests, notable psxtests, had to be modified to include the standard test macro .h file (pmacros.h or tmacros.h) to enable this support. * cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c, rtmonuse/task1.c, termios/init.c: Modified.
| | | | | | | | | | | | | | | * configure.ac: AC_INIT(package,_RTEMS_VERSION,_RTEMS_BUGS). AM_INIT_AUTOMAKE([no-define foreign 1.6]). * cpuuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * Makefile.am: Remove AUTOMAKE_OPTIONS. * malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS. * monitor/Makefile.am: Remove AUTOMAKE_OPTIONS. * putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS. * rtmonuse/Makefile.am: Remove AUTOMAKE_OPTIONS. * stackchk/Makefile.am: Remove AUTOMAKE_OPTIONS. * termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* 2001-09-19 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2001-09-191-1/+1
| | | | | | | | | | | | * malloctest/Makefile.am: include leaf.am instead of leaf.cfg. * monitor/Makefile.am: include leaf.am instead of leaf.cfg. * termios/Makefile.am: include leaf.am instead of leaf.cfg. * putenvtest/Makefile.am: include leaf.am instead of leaf.cfg. * rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use make-cxx-exe. * stackchk/Makefile.am: include leaf.am instead of leaf.cfg. * rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg. * cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* 2000-09-04 Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-09-051-0/+1
| | | | | | * cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am, putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am, stackchk/Makefile.am, termios/Makefile.am: Include compile.am
* Patch rtems-rc-20000702-1.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-07-031-7/+15
| | | | | that is a hack to workaround a switch generation compiler bug for the SH2 and cleaned up some warnings.
* Patch from John Cotton <john.cotton@nrc.ca>, Charles-Antoine GauthierJoel Sherrill2000-06-121-1/+4
| | | | | | | | | | | | | | | <charles.gauthier@iit.nrc.ca>, and Darlene A. Stewart <Darlene.Stewart@nrc.ca> to add support for a number of very significant things: + BSPs for many variations on the Motorola MBX8xx board series + Cache Manager including initial support for m68040 and PowerPC + Rework of mpc8xx libcpu code so all mpc8xx CPUs now use same code base. + Rework of eth_comm BSP to utiltize above. John reports this works on the 821 and 860
* Merged from 4.5.0-beta3aJoel Sherrill2000-06-123-109/+787
* Patch rtems-rc-4.5.0-13-cvs.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>.Joel Sherrill2000-04-131-0/+2
| | | | adds .cvsignore.
* Patch rtems-rc-20000118-2.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill2000-01-311-1/+0
| | | | | that contains cosmetical changes to the Makefile.ams below tests (removes old, now invalid comments from these Makefile.ams).
* Was not actually installing the test.Joel Sherrill2000-01-051-6/+5
* Fixed warnings.Joel Sherrill2000-01-041-0/+2
* Patch rtems-rc-19991117-13.diff from Ralf Corsepius <corsepiu@faw.uni-ulm.de>Joel Sherrill1999-11-231-0/+43
| | | | to convert the libtests directory from Makefile.in to Makefile.am.
* Ralf Corsepius reported a number of missing CVS Id's:Joel Sherrill1998-01-161-0/+2
| | | | | | | | | | > RTEMS is under CVS control and has been since rtems 3.1.16 which was > around May 1995. So I just to add the $Id$. If you notice other files > with missing $Id$'s let me know. I try to keep w\up with it. Now that you have asked -- I'll attach a list of files lacking an RCS-Id to this mail. This list has been generated by a little sh-script I'll also enclose.
* New file.Joel Sherrill1997-11-181-0/+45
