* cpuuse/Makefile.am: Use $(OBJEXT) instead of .o.
* malloctest/Makefile.am: Use $(OBJEXT) instead of .o.
* monitor/Makefile.am: Use $(OBJEXT) instead of .o.
* putenvtest/Makefile.am: Use $(OBJEXT) instead of .o.
* rtems++/Makefile.am: Use $(OBJEXT) instead of .o.
* rtmonuse/Makefile.am: Use $(OBJEXT) instead of .o.
* stackchk/Makefile.am: Use $(OBJEXT) instead of .o.
* termios/Makefile.am: Use $(OBJEXT) instead of .o.
enable this support.
* cpuuse/task2.c, malloctest/task1.c, putenvtest/init.c,
rtmonuse/task1.c, termios/init.c: Modified.
* malloctest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* putenvtest/Makefile.am: Remove AUTOMAKE_OPTIONS.
* rtems++/Makefile.am: Remove AUTOMAKE_OPTIONS.
* termios/Makefile.am: Remove AUTOMAKE_OPTIONS.
* malloctest/Makefile.am: include leaf.am instead of leaf.cfg.
* monitor/Makefile.am: include leaf.am instead of leaf.cfg.
* termios/Makefile.am: include leaf.am instead of leaf.cfg.
* putenvtest/Makefile.am: include leaf.am instead of leaf.cfg.
* rtems++/Makefile.am: include leaf.am instead of leaf.cfg, use
make-cxx-exe.
* stackchk/Makefile.am: include leaf.am instead of leaf.cfg.
* rtmonuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am: include leaf.am instead of leaf.cfg.
* cpuuse/Makefile.am, malloctest/Makefile.am, monitor/Makefile.am,
putenvtest/Makefile.am, rtems++/Makefile.am, rtmonuse/Makefile.am,
stackchk/Makefile.am, termios/Makefile.am: Include compile.am
that is a hack to workaround a switch generation compiler bug for the
SH2 and cleaned up some warnings.
significant things:
and PowerPC
same code base.
enclose.
