* | testsuite: Use printk for all test output where possible. | Chris Johns | 2017-10-23 | 1 | -0/+2 |
| | | | | | | | | | | - Remove the printf support leaving the direct printk support configured with TESTS_USE_PRINTK and all other output goes via a buffered vsniprintf call to printk. - Control the test's single init for functions and global data with TEST_INIT and not CONFIGURE_INIT. They are now separate. Updates #3170. | ||||
* | tests/libtests: Use <rtems/test.h> | Sebastian Huber | 2014-03-20 | 1 | -2/+6 |
* | libtmtests - Eliminate missing prototype warnings | Joel Sherrill | 2012-05-11 | 1 | -4/+11 |
* | 2011-05-20 Sebastian Huber <sebastian.huber@embedded-brains.de> | Sebastian Huber | 2011-05-20 | 1 | -1/+1 |
| | | | | * termios08/init.c: Fixed parameter to avoid test failure. | ||||
* | Add HAVE_CONFIG_H. | Ralf Corsepius | 2011-02-22 | 1 | -0/+4 |
* | 2010-07-19 Joel Sherrill <joel.sherrill@oarcorp.com> | Joel Sherrill | 2010-07-19 | 1 | -0/+158 |
* Makefile.am, configure.ac, termios06/init.c: Add initial tests for XON/XOFF and VMIN/VMAX cases. * termios07/.cvsignore, termios07/Makefile.am, termios07/init.c, termios07/termios07.doc, termios07/termios07.scn, termios08/.cvsignore, termios08/Makefile.am, termios08/init.c, termios08/termios08.doc, termios08/termios08.scn: New files. |
